Mounting a 308 engine on a stand | FerrariChat
Discussion in 'Technical Q&A' started by Gianluca, Dec 23, 2003.
  1. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    Well, my engine is finally out of the car. The whole process was pretty much uneventful tahnks to all the good recomandation from FChat. Thank you all for the help.
    By the way, I had absolutely no problems with the height of the ceiling. I do have 9.5 ft ceiling but could have done it with 8 ft too.
    I would like to put the engine on a stand and have removed the clutch cover as well as the clutch. Provided I can phisically do it, is it OK to mont the whole engine on a stand using the studs the clutch cover mounts on? I would have to use 3 of the larger studs and 1 of the smaller ones. My stand is rated for 750-1000 lbs but my worries are abut the engine itself.
  3. Jay GT4
    Jay GT4 F1 Rookie
    Oct 16, 2001
    4,995
    La mamma dei fessi
    e sempre incinta
    Here are some pics of how my engine was mounted both on a mount and a dolly (custom).
  4. Jay GT4
    Jay GT4 F1 Rookie
    Oct 16, 2001
    4,995
    La mamma dei fessi
    e sempre incinta
  5. Gianluca
    May 6, 2003
    349
    Gianluca Chegai
    I like the dolly!
    Would you mount the whole engine on a stand, though?
    Is it difficult to separate the trans from the block?
  6. Jay GT4
    Jay GT4 F1 Rookie
    Oct 16, 2001
    4,995
    La mamma dei fessi
    e sempre incinta
    Gianluca, I don't have any pics of what we did, but I'm pretty sure the engine was first placed on the dolly, then the tranny was unbolted and seperated, a hoist was used to lift the engine off and onto the stand where it was striped down and rebuilt. Then it went back onto the cleaned and inspected tranny and bolted back up.
    Here is the tranny stand.
