Move a 458 without starting the engine | FerrariChat
Discussion in '458 Italia/488/F8' started by nunojcmaia, Feb 13, 2024.
  1. nunojcmaia
    nunojcmaia Formula Junior
    Dec 16, 2004
    389
    porto - portugal
    nuno maia
    I need your help.
    Is it possible to move a 458, without starting the engine?
    Sometimes I need to move the car, in my garage, to remove others or access objects behind it, and this forces me to start the car for just a few seconds. I think this doesn't give the engine much health.
    Thank you for your answer
  2. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    640
    Austin, TX
    I vaguely recall there's a tool you can use to put the transmission in neutral, but I don't know how easy it is to use.
    stevdug likes this.
  3. mikey64
    mikey64 Formula Junior
    578
    TN
    mikey
    You could habitually leave the car in neutral and just set the park brake. Then you can release the park brake without starting engine.
    “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games” - Ernest Hemingway
    SD455TA and carnutdallas like this.
  4. PMiranda
    Jul 23, 2004
    640
    Austin, TX
    I thought the parking brake and transmission went to park as soon as you pull the key? If the owner's manual says otherwise it wouldn't be the first time I misunderstood it...
  5. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,928
    France
    According to the version of the owners manual I have, it's the case. You should be able to release the parking brake and to get from "P" to neutral you need to use what they call "car wash procedure":
    To perform the Carwash procedure, do the following:
    - with the engine running, select the first gear;
    - select neutral “N”;
    - switch off the engine;
    - turn the key to position II (key-on) within 3 seconds of switching
    off.
    The message “Carwash mode activation” will appear on the left
    TFT display.
    I just realize it may not really help, because to get to this mode you need to start with a running engine...
  6. Kent Adams
    Kent Adams F1 Rookie
    3,299
    Automotive wheel dollies work great.
    TR007 and Eric C like this.
  7. Viperjoe
    Viperjoe F1 Rookie
    Set "car wash" mode and use wheel chocks. Simple.
    docf likes this.
  8. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,296
    Yes that’s if you can’t turn it on and shift to neutral I tried once when it died and it was impossible. Ended up using the wheel dollies as Eric c suggested
  9. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,296
    I’m thinking every time you need to move it take it for a spirited drive! Better for the engine then sitting all the time and also better for your health!!!!
    Altoria F and Il Tifoso like this.
  10. PMiranda
    Jul 23, 2004
    640
    Austin, TX
    If car wash mode persists after removing the key and locking the car that would be great but I didn't think that was true?
  11. mikey64
    578
    TN
    mikey
