Moving 355 Spider Top Bypass Switches | FerrariChat
Discussion in '348/355' started by markcF355, Nov 17, 2015.
  1. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I got tired of pulling the plug for the top bypass switches and I wasn't going to spend $800+ on pots that would just fail. So I decided to rewire the top bypass switches to the top switch in the center console. It took a couple of relays, two diodes, and about two hours. All in all, well worth it.
    If anyone is interested, I can post info.
  2. Jogotz
    Jogotz Rookie
    Nov 21, 2012
    15
    Hi Mark,I sure would be interested in your post.My top has started to act up this year.Thanks
  3. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Thats a real easy way to do it
    Post up the pics Diodes confuse my old ass
  4. WATSON
    WATSON Two Time F1 World Champ Owner Rossa Subscribed
    Sep 9, 2010
    23,802
    WI
    I just pulled the wires to a small switch I put in the hole for the ABS cut out switch us US folks are not allowed to have. No diodes or relays necessary.
    Curious what you did....please post!
  5. taz355
    taz355 F1 Veteran Owner Silver Subscribed
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Yes post we need to add this to the diy sticky for people to have options. Thanks
  6. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    Western Snow Mexican
    Hate bringing an old thread back to life, but does anyone have the diagram for this? The top ECU on my car is fried (burnt board and melted contacts, non repairable)
    I'm also wanting to control the seats with relays from the factory switches, I think I have a handle on that using 2 relays per seat but if it's been done I'd like to see how others have accomplished it.
    Cheers
  7. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,423
    Ian Riddell
    Do you know which parts fried... seat circuits? These seem to be the only* circuits carrying any serious power as they are driving the seat motors directly. The roof motor is powered via external relays.
    If the seats are using too much power, perhaps the problem lies in the seat motors or seat tracks.
    Do you have this diagram for normal roof operation?
    Roof diagram
  8. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    Roof works properly with emergency switches. Seats wont move at all even after repairing the pots. No interest in trying to make the black box work, far too many issues with it. Btw even with the black box completely removed, top still works with emergency switch, and the windows drop when the top is pushed up
  9. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    What I will probably do is use the factory top switch to control the ground circuit on the respective relay for open and close
  10. Qavion
    Feb 20, 2015
    14,423
    Ian Riddell
    Thanks. Understood. The bypass switches bypass the ECU and seat/window/roof sensor input into the ECU. Only the handbrake switch remains in the bypass circuit. The windows still work because the left hand roof striker plate switch inputs directly into the window controller.
    I'm still worried that it could be a seat wiring/motor problem which caused the ECU to fry. Adding relays may not be a safe solution.
  11. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    I see what your saying now. I did power the motors under the seats and ran them forward and back. I dont think they are the problem but with all the problems I see with pots, controllers, microswitches etc, I completely agree with what one user said, the most over designed under performing piece of ka ka ferrari ever over engineered. I was surprised the windows still dropped with the black box completely removed
  12. tbakowsky
    tbakowsky Two Time F1 World Champ Consultant Professional Ferrari Technician
    Sep 18, 2002
    20,011
    The Cold North
    Tom
    Personally, I would just convert it to a manual top like the 348. There is no need for a power top in the 355..none. that top was a mistake from the start.
  13. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    I dont like the idea of having to get out and move each side a little at a time. Theres nothing wrong with the electrics or hydraulics, it's the overly complicated POS ECU that needs to go.
    taz355 likes this.
  14. Qavion
    Feb 20, 2015
    14,423
    Ian Riddell
    Would you have any photos of the damage? Boards can be hardwired, but I'm not sure what you mean by melted contacts (are these on the ECU plug?)
    These are the only photos of the internals I could find.
    96 Spider Power Seat not working?
    Just wondering what bespoke components are on the other side. There must be some relays for the seat motors mounted on the boards.
  15. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    Mine is very similar except the conductive strip has completely seperated from the board in several areas. I gave it to my brother in law who owns an electronic repair shop, he said it was too far gone to save.
  16. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    Yes on the other side of the board is two relays that are discontinued and very hard to source, there is a thread of someone who tried that route. For me, its overly complicated, I'd rather motor the seats forward then do the top and put the seats back, I know it will work everytime and not leave me stranded with a seat that wont move
    Qavion likes this.
  17. Qavion
    Feb 20, 2015
    14,423
    Ian Riddell
  18. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    I'm in the middle of my engine out, about to begin the teardown to replace a piston and sleeve, possibly more, so the top and seats are on the back burner for a bit. I will update this thread when I get back into it.
  19. WATSON
    Sep 9, 2010
    23,802
    WI
    As I posted three years ago (yikes) I pulled the wires from the emergency switch to a toggle I placed in the console.
    Pretty sure it has little to do with the top ECU now (although I have a second one I need to install to see)...perhaps an answer for you?
    It looks stock and operates just the top. I move the seats and windows manually and run the top.
    Better than manual operation and easier as well.
    I did the seat pot repair but it failed. Gluing them is a fools errand IMHO.
    If I can help in any way, let me know.
    krazykarguy likes this.
  20. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    I thought it would be this easy, but as it has 3 wires, black to red circuit is normally closed, when the switch is pressed that circuit opens and red to yellow are closed. Just jumping the red to yellow doesnt operate the top.. I welcome any insight you have
  21. Qavion
    Feb 20, 2015
    14,423
    Ian Riddell
    When you did your yellow-red wire jump, did you have the handbrake set and the ignition on? The motor uses direct battery power, but the relay coils still need the ignition on.
  22. RCKSTR
    RCKSTR Karting
    Sep 6, 2018
    103
    I believe so, the relays clicked but pump didnt run. I will dig into it again this week and verify parking brake is set, it may not have been
  23. Qavion
    Feb 20, 2015
    14,423
    Ian Riddell
    I assume if the relays clicked, the parking brake would have been set. However, I did notice something strange during the wiring checks I carried out on my '98 Australian car. I always got an earth on the yellow wires (orange-black wires on the car side of the 6-pin bypass switch plug), park brake set or not. I don't know if the ohmmeter was reacting to some other part of a depowered brake system. The handbrake switch is in parallel with a few other circuits (at least on Euro-based cars). I don't think I repeated the tests with the ignition on.
  24. WATSON
    Sep 9, 2010
    23,802
    WI
    Pull the emergency top operating switch out and look at that. Find the power wires that run the top up and down.
    Using a center position toggle switch like the one below, tap into and connect the power leads from the emergency switch to each of the end connectors.
    Ground the center connector.
    That switch is now an extension of the emergency switch and bypasses the ecu and simply runs the pump in the direction selected by the switch.
    Install in the console for a better look.
    Move the windows and seats manually and then push and hold your new switch in the direction you want the top to move.
    Some day I'll fix the seat pots in mine, but this is so darn simple have just not bothered yet.
  25. Lionworks Auto
    Lionworks Auto Formula 3
    Oct 16, 2013
    1,023
    Worthington OH
    Ed
    Nice Mod! What would stop someone from same idea but run to the oem switch in center of seat switches? (I can’t recall is it not a rocker?). Then it all would act totally rationally / the top just goes up or down...Ed
