Moving car while engine is out | FerrariChat
Discussion in '348/355' started by thirteendog, Oct 23, 2015.
  1. thirteendog
    thirteendog Formula 3
    Mar 6, 2008
    1,587
    Nashville, TN
    Has anyone figured out how to move the car when you pull the engine? Let's say you have a two car garage and a "portable" lift and you'd like to drop the motor for a major. Then put the car on the ground and move it back into it's parking place so you can use the other side of the garage to do the engine out service?
    Nick
  2. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    You should be able to use wheel dollies and wood blocks.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,629
    San Carlos, CA
    Mitchell Le
    under the car, right ahead of the gas tank.
  4. plugzit
    plugzit F1 Veteran
    7,785
    Redondo Beach, CA
    Bruce Bogart
    #4 plugzit, Oct 23, 2015
  5. Eric C
    11,136
    St. Louis, MO
    Eric
    I'd be interested in buying a pair of those. ;)
  6. plugzit
    plugzit F1 Veteran
    7,785
    Redondo Beach, CA
    Bruce Bogart
    I bought the metal plates and casters at the local metal dealer, and had a guy weld them up for me. Total cost was around $100. The plates were precut, including the brace, But I had to do the drilling.
    They sure make it easy to move the car around.
  7. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    I just built a Wood dolly for mine. The metal casters are the ticket for the engine out if you need to have it mobile.
    I'll make some one day but for now the 355 that needs to be mobile and is still apart is on a body dolly.
  8. yelcab
    Nov 29, 2001
    13,629
    San Carlos, CA
    Mitchell Le
    Ha, I thought about those but I have a 4 post lift so I really do not need to move the car-cass anywhere.
  9. thirteendog
    Mar 6, 2008
    1,587
    Nashville, TN
    Brilliant!!! Thanks guys. Still looking for the perfect 348 for myself, but I have found this place to be a wealth of knowledge and still find myself spending hours reading old how to threads.
  10. wiley355
    wiley355 Formula Junior
    539
    Vancouver, WA
    Wiley
    #10 wiley355, Oct 23, 2015
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I love those custom rear quarter covers.
    I had some similar casters built several years ago at the request of a 348 owner. Might need to consider a set for myself as well.
  12. Delta_Lima
    Delta_Lima Karting
    Aug 30, 2014
    151
    Hoorn, Netherlands
    Daan
    Were are they made of? Those custom rear covers?
  13. wiley355
    539
    Vancouver, WA
    Wiley
    I don't know the material. The covers belonged to FoS. The inside material must have been very soft (micro fiber?) as there were no visible scratches after all was said and done.
  14. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Someone's wrapped up the fuel pipe from the filler to tank with heatshield.
    Good idea
    This is where a dangerous leak happens
    Heat protection may avoid the hose/seals from failing
