Just got my MSD 6AL in today with Blaster coil for a my BB512i. For those of you who have done these, is the MSD to Dinoplex wiring swap as follows? (From a previous thread herein, asking the same but without answer.) MSD Heavy Red to starter cable (from battery) MSD Heavy Black to frame (ground) MSD Violet (from Mag PU positive) to dinoplex #1 green (Distributor trigger) MSD Green (from Mag PU negative) to dinoplex #2 black (Distributor ground) MSD Black to dinoplex #3 red (coil negative) MSD Orange to new dinoplex #4 yellow (this is the yellow going to the coil positive that has to be seperated from the other yellow going to the ignition switch and positive battery- both were originally together as dinoplex #6) MSD Tach Out to dinoplex #5 brown (tach connection) MSD Red to dinoplex #6 yellow (remaining yellow in dinoplex #6 going to the ignition switch and positive battery) I'd also like to get a new 6 wire female and male connectors for the new igintion harness conection to MSD box. Any sources? Thanks SO much in advance. (I posted this on Technical Q&A also.) If you have a link, or a document of any sort detailing this install, you would make my weekend complete!
