MSW HGTC & FHP Sway Bars (Finally!) | Page 2 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Feb 17, 2023.
  1. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    Thank you!
    May the Horse be with you
  2. tazandjan
    39,054
    No longer available. Shocks are likely fine.
    Condor Man likes this.
  3. Chupacabra
    Chupacabra F1 Rookie
    3,490
    Behind a drum kit
    Mr. Chupacabra
    Glad to see you are looking into the structural aspects, that was going to be a question of mine re: the larger diameter bar
  4. F612
    F612 Formula Junior
    Feb 5, 2018
    641
    Leeds,AL
    David D. Hood
    I’m in for a19!
  5. Cribbj
    Cribbj Formula 3
    I wish I could give you guys more objective comparisons between the OEM bars & bushings and these new ones but without knowing the OEM numbers, it's difficult. Both my friend & I searched for software to give us roll, pitch & yaw, bank indication, lateral accelerometers, etc. to no avail. And I'm sure our steel is a better grade than what Ferrari used and has a somewhat stiffer Young's modulus, and of course the poly bushings have less compliance and are harder than Ferrari's but I just don't have enough data to make a tabular comparison of the numbers. That's why our speeds through the sweepers and our subjective feels of the differences in the setups will have to do.
  6. tazandjan
    39,054
    John- Easy to make an apples to apples comparison of roll bars, but not when they are made from different steel. Have to torque both of them on a machine and measure deflection at a constant torque. Somebody probably has such a device, but not sure who.
  7. Cribbj
    Cribbj Formula 3
    Very true. If I knew the Young's modulus of Ferrari's bar, I could calculate the difference in stiffness & give an objective number, but since I don't, I can't and would have to hunt down one of those devices you described. I'm waiting to hear back from my fabricator to see if he has a setup to actually measure the stiffness.
  8. Condor Man
    4,938
    Los Angeles
    Thanks Taz,
    The guys in New Jersey thought that the car drove fine.
    I guess I will see how it is after the new rollbar is fitted.
    I did drive a 575 with FHP last weekend and it was tighter than my car. Having stated this, I did not go over any speedhumps and it was relatively short drive.
  9. Cribbj
    Cribbj Formula 3
    CM, it's a pity you're way out on the left coast. If you're ever in Austin TX you owe it to yourself to take a ride in my friend's 575M. The difference in power is amazing and his remapped F1 ECU shifts in half the time the regular one does. Pedal to the metal, there's almost no traction in 1st, not much more in 2nd and only in 3rd does he get some traction. I don't know what his standing start 1/4 or 1/8 mile times are, or the 0-100 times but I'm sure they're vastly improved over stock. And now with the MSW 19mm anti-sway bar and MSW steering ECU, the rest of the car is a fair match to the engine.
    Don't get me wrong, it's not an uncomfortable monster if you want to take it easy; it has more of a Jekyll & Hyde character. Mild mannered when you want but a real pavement ripper if you put your foot down.
  10. Condor Man
    4,938
    Los Angeles
    Thanks John,
    That is fascinating. My car is over in NJ getting a stick put in it at the moment, so I guess the ECU flash would not be helpful.
    For my 599 on the other hand......???
    Any yes when I am in Texas next, I will look you up!
  11. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,596
    My 2002 575 came with standard suspension, the porpoising effect between gear changes was very noticeable. I sourced and fitted the later suspension ECU, steering ECU and FHP springs and it made a huge difference, much tighter around corners too. I couldn’t find the fhp rear sway bar but to be honest i don’t know that i drive fast enough to notice a difference :)
  12. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,870
    MO
    Omar
    Very exciting update for the community.
    Note I also echo caution going much stiffer in the rear. Not only do you essentially lose rear end R/L suspension independence, you also run the risk of sheering off the bar under hard cornering with sticky tires. Both are a setup for a less then optimal outcome.
    I do agree these high quality bars likely match the OEM FHP rear end bars but of course that requires directly measuring loads and back-to-back seat time...
  13. Condor Man
    4,938
    Los Angeles
    Thanks Greg!
    That is awesome that you worked this out and I am going to try and source the HGTC springs. According to Jason Plato's review on fifth gear these springs were 35% which would have to help.
    BTW! The Porpoising in the OEM suspension cars was very ahead of it's time.... How did they know that F1 would follow suit in 2021!!
    I have the later Suspension ECU and Steering ECU as my car is late 2004.... So all I need now are the springs and rollbar!
    greg246 likes this.
  14. Auraraptor
    Sep 25, 2002
    13,870
    MO
    Omar
    #39 Auraraptor, Feb 18, 2023
    Please realize the HGTC is not the be-all holy grail of suspension setups. HGTC suspension was essentially designed as a revamp of the standard suspension to accommodate the new carbon brakes. With good tires and warm the carbon brakes can generate FASTER and GREATER total force which can really upset the balance of the car. (Think transient too much front bias combined with too much R/L bias) Ferrari compensated for this using the stiffer front end vs the OEM setup. This wasn't the first time they did this, as they did a similar hat trick in 88.5 with the 328 (ABS introduction) and 93 with the 512 (ABS introduction). The results varied...the 328 revision was horrible (IMHO) from a driver's POV as the car was overly stiff in the front with a new tendency to understeer with both period-correct and modern tires. The 512TR/occasionally incorrectly called 512M suspension was a far better more neutral rework.
    All that said if anything, the FHP is much, much more neutral (and as a result can be more punishing to a novice/immature driver).
    Hence if you are targeting something, that is what I would target unless you are running a special brake system.
    I may switch to carbons at some-point (tragically most parts are now NLA) but I have really enjoyed the setup I have now as it doesn't overload the car or steering in most normal conditions.
    Edit: Found the specs from an old post. Again recall stiffer front = more understeer; stiffer rear = more oversteer:
    "HGTC
    Front Springs: 35% Stiffer
    Rear Springs: 15% Stiffer
    19.5 mm Rear Anti-Roll Bar: 73% Stiffer
    FHP
    Front Springs: 32% Stiffer
    Rear Springs: 12.5% Stiffer
    21 mm Rear Anti-Roll Bar: 133% Stiffer
    ______________________________________________________________________________________
    below find the spring rates for both the FHP and HGTC springs
    HGTC
    #208678 400 lbs. fronts
    #208679 245 lbs.
    FHP
    #175886 375 lbs. fronts
    #175887 245 lbs.
    using a tape measure, both versions measure to be identical in coil thickness and sizing but for the height of the fronts :
    HGTC fronts are roughly, 10.25"H x 5 1/16" wide
    FHP fronts are roughly, 9.50"H x 5 1/16" wide
    Original Stock Springs FHP HGTC After Market in Car
    Front: 320 375 400 445
    Rear: 235 245 245 325
    Themaven likes this.
  15. Cribbj
    Cribbj Formula 3
    I would still think reflashing of the engine ECU might be of interest to you, along with either Fabio's or Supersprint's headers & exhaust. With this setup you could probably outrun your 599...
    For myself, I had never driven an F1 shifting car, prior to my friend's 575M, and I must say I think I'm in love! I don't know that I'd ever want to buy another stick shifting car.
    With F1 there's no heavy clutch to tear up my aging knees, no heel & toeing on inclines, no launching issues with a hair trigger on/off clutch, etc., etc. For me, it's the perfect setup for 90% of the driving I do in a city environment.
    His 2nd Ferrari is a 512TR with a fairly heavy clutch and a recalcitrant gearbox that doesn't like to downshift without good rev matching. Driving it for only 15 minutes made me long to get back in the 575M and he even admitted that he's only good for about an hour in it (his knees are in worse shape than mine)
  16. Condor Man
    4,938
    Los Angeles
    John,
    I initially purchased the 599 to covert to Manual, however after driving it like a manual car it is very charming as you still have to time the gear changes with the throttle and of course it takes the pain out of having a clutch to deal with in traffic.
    When the new style dual clutches came out there was a lot of negativity towards the old F1 transmissions.... I was certainly a detractor.
    I will be interested to see in 10 years time what everyone's thoughts are.
    Mirek likes this.
  17. tazandjan
    39,054
    John- Mine is in the shop right now with Trevor and your friend's latest software for Fabio's 6-1 headers, along with my HGTC TCU bought years ago. 135171 has FHP with the last actually fitted pre-52556 shock ECU (201674), so not much help needed there. With the big brakes, she will be pretty much a hot-rod that can stop. Only missing the steering position sensor, which cannot be retrofitted.
    CM- You might be able to upgrade the TCU on your 599 to HGTE specs (85 ms vs 100 ms) with a little help from Trevor. Not sure it is possible to do GTO (60 ms) without hardware changes.
    -K1- likes this.
  18. Auraraptor
    Sep 25, 2002
    13,870
    MO
    Omar
    My 137318 is in several ways your car's sister (also FHP w Fabio headers>H pipe> SS axle Pipe > OEM HGTC). She should likewise be ready by the end of the month with similar ECU update w the proper 32bit TCU....barring yet another surprise snow storm
  19. tazandjan
    39,054
    Yup, you even have the steering position sensor.
  20. Chupacabra
    3,490
    Behind a drum kit
    Mr. Chupacabra
    What brake setup are you installing?
  21. tazandjan
    39,054
    Been installed for 10 years or so. Mov'It CERs.
    Here are numbers I crunched a while ago. They match the factory spring numbers and the anti-roll bar numbers are calculated.
    575M HGTC vs FHP Spring Stiffness
    HGTC
    FHP
  22. Condor Man
    4,938
    Los Angeles
    Thanks Taz,
    My car was fitted with the HGTE kit in 2010 by the dealer. So it already has this.
    Someone took the wheels off car sometime before I bought the car.
    And yes 60 would be nice!
  23. Condor Man
    4,938
    Los Angeles
    Mine is also a late car being 139115.
  24. Cribbj
    Cribbj Formula 3
    Yes, we're both engineers so we looked at these bars and the fitment from a safety as well as a performance perspective. A 2 ton car going through even a well banked 45 MPH sweeper at a buck ten or twenty can put a helluva load on these bars and the bar will simply transfer that load to its mounts. Granted the end mounts are substantial, but the bushing (D block) mounts can get quite a bit of non-uniform twisting force and we definitely don't want those to be a weak link.
  25. Chupacabra
    3,490
    Behind a drum kit
    Mr. Chupacabra
    Absolutely, these cars are beasts! I’m sure you guys will produce a great product, and I’m eagerly awaiting it’s arrival
