355 - Muffle heat shield repair | FerrariChat
355 Muffle heat shield repair
Discussion in '348/355' started by johnk..., Nov 17, 2020.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    While doing a little maintenance on my 355 I discovered that the muffler heat shield was damaged. Apparently the muffler had become dislodged and was rubbing against it wearing through the aluminum foil and buring off the resin in the shield substrate leaving only the glass fibers is spots.
    After checking the price on a new shield ($1000) I decided I would repair rather than replace. Using glass mat and resin I covered the worn areas and then painted with aluminum paint.
    After a little research I found some suitable heat shield material from Design Enginering Inc. (DEI). 10 mil aluminum bonded to a fiber glass heat mat with high temperature adhesive backing. The finished shied is shown below with old covering. Total cost, about $100.
    DEI makes a wide variety if heat and sound shielding. Highly recommended. Check it out. (No affiliation.) https://www.designengineering.com/
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    #2 MAD828, Nov 17, 2020
    Nice work John!
    What is the insulation heat rated to?
    I tried something similar with adhesive backing and the adhesive did not withstand the heat. Did you use rivets as well as per factory to secure it?
    kenguru likes this.
  3. johnk...
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Thanks Elliot. Admittedly, looking at your car has been a motivating factor for me. This all started when I decided to repair and refinish all the under trays on my car.
    MAD828 likes this.
  4. lanab
    lanab Formula Junior
    Feb 21, 2016
    510
    Stockholm, Sweden
    Where can you those lower brackets on the shield that attach to the bumper?
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    No wear that I have seen in a very long time
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Which exact stuff did you buy as I am not clear when looking at their stuff
  7. johnk...
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Thankyou
