348 - Muffler install and window issue…… | FerrariChat
348 Muffler install and window issue……
Discussion in '348/355' started by JLF, Jul 31, 2022.
  1. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
    Can I install my Tubi muffler without removing the bumper on my 348 tb?
    Yesterday when I washed car for first time waster poured in through the tops of the windows. Is there an adjustment to make them press tighter to the seal or are they not going up all the way?
  2. marknado
    marknado Karting
    Mar 4, 2021
    51
    New Zealand
    Mark
    Tubi install is very straight forward with the bumper still attached.
  3. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
    Do you know if the top muffler has to come out from the top. Or can I also remove that from below?
  4. marknado
    marknado Karting
    Mar 4, 2021
    51
    New Zealand
    Mark
    Ahh I'm not sure sorry, I swapped a custom aftermarket exhaust out for the Tubi, I have dummy fitted my stock 2 piece muffler and from memory I slid it up as one unit from underneath. Someone else will confirm that for sure.
  5. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
    Ok thanks.
  6. Aeroflop
    Aeroflop Karting
    Mar 1, 2022
    62
    Finland
    Eero Ahonen
    Your window doesn't seem to get fully closed. On my car the last 5mm or so slows down quite much and it's easy to mentally mark "ok" while closing them before they are closed. I think there's a bunch of threads about window problems here.
    There's some links at 348 DIY thread:
    348 Do-It-Yourself threads
  7. Qavion
    Qavion F1 World Champ
    14,343
    Ian Riddell
  8. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    Just out of curiosity....
    If you leave your doors ajar when putting the windows up do they go up just that little bit higher?
    My windows have 2 "settings" - how far they go up with the doors closed (normal use) and how far they go up with the doors open - "valet mode" ;-')
  9. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
    Thank you I’ll look into these things today and report back.
