Murci Question | FerrariChat
Murci Question
Discussion in 'LamborghiniChat.com' started by LAMBOJOE, Apr 27, 2007.
  1. LAMBOJOE
    LAMBOJOE F1 Rookie
    Nov 2, 2006
    3,190
    Brooklyn NY
    Joey
    is it true if you peel out on a Murci in E-gear Or Manuel the clutch will go immediately.
    meaning in e-gear turn all traction off and hit the gas, watch the car rev up and peal out.
    Joey
  2. rush109
    rush109 F1 Veteran
    May 26, 2005
    8,103
    Montreal, Quebec
    Joshua McRae
  3. wildshirts
    wildshirts Formula Junior
    Mar 8, 2007
    302
    That one seems to work well lol
    I dont think it will go there and then but do it enough times and it will get expensive!
  4. LAMBOJOE
    LAMBOJOE F1 Rookie
    Nov 2, 2006
    3,190
    Brooklyn NY
    Joey
  5. ADON
    ADON Formula 3
    Feb 8, 2007
    1,059
    Probably. But if you do that in any car, the clutch is gonna be toast.
  6. pdisme
    pdisme Formula 3
    Oct 9, 2006
    1,036
    Tampa, Florida
    Dave
    E-gear has a 'launch mode' where you turn off traction control, turn on sport mode, put it in first and then stand on the gas when you're ready and it will dump the clutch at the appropriate rev. Not sure how many times you can do it but yeah, obviously dropping 550 hp on a clutch in a 3500+ pound car from a stop is not going to be easy on it. If you're driving manual, you just better get it right because you need the tires to slip a bit, if you bog it you're going to end up breaking something.
  7. GDautosport
    GDautosport Formula Junior
    Nov 5, 2003
    612
    NJ
    yea its true
  8. Peter2
    Peter2 Karting
    Feb 9, 2007
    200
    Palm Beach, FL
    Peter
    No. You heard wrong. The clutch is very strong and can handle abuse very well.
  9. **nismo**
    **nismo** Karting
    Dec 16, 2006
    174
    Hampshire (U.K)
    Chris Williams
    i should hope so on a car that cost that much, would also think drivetrain would have to be pretty strong to on a car that weighs as much as the murci does and with its power.
