Murcielago SV stuck in limp mode- egear | FerrariChat
Discussion in 'LamborghiniChat.com' started by trainwrex, Apr 26, 2023.
  1. trainwrex
    trainwrex Formula Junior
    Sep 15, 2011
    280
    Perth, Australia
    Hi all,
    My murcielago SV is stuck in limp mode and wont shift higher than second gear.
    When i go to drive off there is beeping and the egear light flashes every so often. Above 60kph the lift starts to flash.
    I have taken car to to lamborghini dealer and there are no codes that have come up. The speed sensors are all working, abs is working. But when the ecu sees the speed its out. i.e speedo sees 60kph the ecu only sees 2.7kph.
    Any advice would be greatly appreciated. the lambo techs are stumped
  2. Curious if you can manually shift normally. The relay(s) seem to be the first thing to replace.
  3. robert biscan
    robert biscan F1 Veteran
    5,080
    Nashville and Palm b
    robert s biscan
    Call Chris at Lambo of palm beach. I had the same thing and he fixed it.
