Awesome, can't wait to see it!
I love this car so much! My only quibble is the gearing is absurdly low, is there any fix to that? Perhaps a different diff or different gears in the diff?
You get used to it .It gives extra agility especially in hilly roads with tight corners . In the U.K. race series they used to fit the 308 ( both inc GT s ) racers with the lower final drive of the 208 . I guess it’s possible to go the other way ? Drive it for a year then decide .
Page 13 of this - . https://www.veikl.com/d/Ferrari-Dino-208-GT4-Owner-s-manual-1975-EN-FR-IT-15647/13 Image Unavailable, Please Login The 15/69 ratio at the top of this page .
The gearing gives it the same acceleration off the line as a 308 GT4. In fact having owned both, I would say the gearing is equally well matched to the engine output in both cars. I suspect if you changed the gearing it would feel very slow in acceleration in order to give you lower rpm while cruising in top gear. As suggested give it some time to get used to it or you may find yourself spending a lot of money on a mod that makes the driving experience worse.
I met Rich this past weekend, we swapped cars and I got a chance to drive his beautiful 208. Hung out till almost 11pm, had a great time, looking forward to more drives. Image Unavailable, Please Login
You guys didn't call me?! Offended! Let me know next time the meeting of the Dinos takes place and I'll be there (with an Alfa or 964 to barter rides with...)
Late to the thread Amazing car. Well Played sir. Love the color. I actually think the 208 sounds better Congrats. Sent from my iPhone using Tapatalk
Welp, it's been an eventful ownership with the 208 so I thought I'd chronicle some of the journey so far. Upon receiving the car it went to a shop for a once over and it needed some work done: Rebuilt steering column, brakes, various electrical items, re cored rad, heads tuned and a few other minor jobs. I drove it a bit and it still wasn't 100% and had developed a few new issues (major oil leak from the transmission linkage for one) so back to a shop it went. The tranny linkage got sorted, new bushings, new motor mounts, rebuilt shifter, A/C system fixed, a seat tear fixed, more electrical fixes and a ceramic coating and color correction. OK at this point I'm thinking the car is ready for prime time! Picked it up and all seemed good. On my next semi long drive (2 hrs+) the motor started to overheat dramatically. I pulled over to find I had developed a major coolant leak and the alternator wasn't working. Back to the shop! (That is after a 6 hour wait for a tow in the middle of nowhere as it was a Sunday night). They determined the water pump had seized and caused the belt to snap disabling the alternator. A new water pump, new coolant reserve tank, hoses and belts were installed. On the way home from the shop THE SAME issue occurred again! Fortunately this time I was able to coast into a rest stop and it was weekday and midday. I had my wife pick my up and left the car at the rest area for the tow service to pick it up. The shop discovered the reason the issue reoccurred was that a heat shield that was supposed to be in between the exhaust and the water pump belt was missing, so the heat from the exhaust melted the belt and the alternator was no longer working as well as the water pump. The correct shield was fortunately sourced and the car was repaired. OK now I'm feeling like this car is truly ready for some hard miles. On the drive home from the shop I heard a loud rushing air sound coming from the engine compartment all of a sudden, then the car lost power and died. I was on the side of the interstate this time but fortunately my wife was driving behind me this time as we met at my folks house after picking up the car for dinner. I left the car on the side of the interstate (secretly hoping it would be stolen), and went home. The tow service was engaged and the car went to the shop. I just found out the issue this time was that the timing pulley disintegrated. So we'll be replacing all the pulleys to be safe and will be inspecting the head to be sure there was no damage. The funny thing is despite all this absurd suffering, I still look forward to driving the car next time it's ready! Fortunately this isn't my first rodeo with a vintage car (I own a few) so I know shaking out a car can take some time, but man the 1-2-3 punch of these breakdowns has been painful.
Geez. That’s a terrible string of misfortunes. Hope you have some uneventful years of ownership ahead! Sent from my iPhone using FerrariChat
I bought mine 2017 at auction .It’s was put in by a classic car club syndicate.Circa 25 cars they keep them for between 3-5 yrs .Depending on use age patterns from the “ members “ churn them through classic auction sites U.K. .Replace them for something else .This 208 was sourced in salt free southern Italy . In the mean time in the U.K. it was Ferrari approved work shop maintained and had a file of invoices .Not an Indy a “ Ferrari approved “ FWIW . So it had its usual stuff done or commented upon needing doing soon . Has been on a Euro hoon around the Swiss alps , a Swiss classic rallye and various U.K. classic rallye s . I’ve done bits to it Eg brakes , AC regass , fix the Ariel , dismantle and fix the bumper rubber sagging , replace the header tank , replace a few hoses and even replace the exhaust ( was shot ) and the alternator. New steering rack .Strip and lub the wiper motor All DIY . Used a respected U.K. Indy ( restorer ) to do the cam belts , tune the carbs and fix the gear shift oil seal .Used a local BMW racing prep shop to re bush the suspension, there’s nothing special about its suspension btw . It’s value has risen since 2017 to cover what I have put in . Retired having had ( while working ) a Testarossa back in the day and 2001 a 360 F1 .just wanted seeing as I have the time DIY er F car . Hard to believe to those who have never had Ferraris but this GT 4 is the best driver handling balance wise , most fun than the other two .Being analogue easy to work on .
Pocono Sportscar, very respected Ferrari only shop. I can't blame them, it's just been bad luck they couldn't have anticipated. Plus because the 208 GT4 is such a rare car here in the US, the heat shield was something they weren't familiar with so I credit them for sorting that one actually.
"Non c'e due senza tre"... hopefully smooth sailing now and you can make it to Peter's Dino GT4 meet in October.
Sad to read about all of your troubles. / Glad to read that you are an experienced vintage car owner who knows that the problems can be resolved once and for all.
It sounds like your car may not have been driven much prior to purchasing. These cars are pretty reliable once everything is settled. Good luck with your new car.
I agree that these are great cars to drive and that one quickly forgets all the grief. They ARE very reliable, once sorted. The problem, as always, is when the car is new (to you) and you need to discover and clean up all the lingering issues. I'm glad to hear you're going to pull through this and enjoy the drives. Great color!!
I must admit I had a similar experience with my low miles 208 GT4. It looked great but as I drove it a lot of issues surfaced. I sold it in the end and bought a high miles 308 GT4 which has been very reliable. I do get it serviced every couple of years and there are always a few things picked up which need doing. But I feel I'm on the front foot in that the things that get done are preventative rather than fixes. And that's a far nicer experience than getting regularly stranded by your car.
Thanks all for the encouragement, I've come this far so I'm in for a penny, in for a pound... and as mentioned I do love driving the car so I'm hopeful I'm at the tail end of this nuttiness.
Want to feel better about your day? Here's what I learned today about my 208 to add to the story: - The pulley disintegrated only because a valve broke and went into a cylinder. The motor will need to be rebuilt, may as well replace all the sodium valves so the issue doesn't occur again. Plus new piston(s) (I want to go higher compression to add some ooomph) etc etc. Hoping the estimate is doable.
Man that sucks. But you have a lovely car and will be even better with a revitalized engine! Sent from my iPad using FerrariChat
