My 30k engine out service. | FerrariChat
Discussion in '348/355' started by speedracer1610, Jun 14, 2007.
  1. speedracer1610
    speedracer1610 Formula Junior
    Aug 25, 2006
    332
    nor cal
    Craig D
    #1 speedracer1610, Jun 14, 2007
    The last major engine out service was done at Ferrari of San Francisco in 2001. The car has about 15k miles since.
    I ordered the parts from http://www.ricambiamerica.com
    I will be changing the trans oil to Royal purple.
    It took quite a bit longer to remove the engine than expected. About 7 hrs to be exact. This was my first time at removing the engine and I wanted to ensure that I was doing everything correctly.
    The flywheel was leaking quiet abit. Flywheel disassembled and was repacked. A big THANKS to (Motob) Brian Brown from Patrick Ottis Company
    1220 Tenth St.Berkeley, CA who let me borrow the 60mm wrench and clutch alignment tool that I needed to do the job. Brian called me to see if i had run into any snags along the way.
    I just sent the valve covers out to have them powder coated red.
    Going to have the guy in Mississippi rebuild the water pump even though it appears to be fine.
    I am doing this work with the help of my friend Chris who owns A Bauer Porsche repair in Oakland CA.
    I also noticed that my fuel filters in my spider is smaller than in other 348's.
  2. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Nice pics Craig. Any more? :):)
  3. fatbillybob
    Aug 10, 2002
    29,161
    socal
    #3 fatbillybob, Jun 14, 2007
    Be careful with those fuel filters. There is a guy on ebay claiming to sell 348 filters that are bosch and will work but are too small in diameter. It is very important that you either get the right diameter or fab new secure brakets. If the filter is allowed to wiggle up and down it puts more stress and increases possible breakage failure in your fuel lines. Such a failer can spray fuel on hot headers and you will burn!
    In this pic is the correct bosh filter and next to it is the improper small ones
  4. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    Some of the very later cars did have smaller fuel filters.
  5. fatbillybob
    Aug 10, 2002
    29,161
    socal
    Thank you! Does anyone know the cutoff year for the small filter?
  6. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    I know when I did my engine service recently the filters Ricambi sent where the larger and did not fit. They had to be smaller. mines a '94 MY.
  7. cscott67
    cscott67 Formula Junior
    May 13, 2007
    418
    Milwaukee
    Scott
    I have to do the flywheel-packing thing this weekend. Keep posting sir! Scott
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    ATA boy Scott!
    I just love it when guys man up and do their own work.
  9. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Cheers FBB! Interesting to know. :):)
  10. speedracer1610
    Aug 25, 2006
    332
    nor cal
    Craig D
    My car is a 95 and uses the smaller one shown in the pic. I was told the earlier 348 use the bigger ones.
  11. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Yeah mine is a '91 model and I run with the large filters
  12. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,456
    On the Limit
    Dino
    My '89 uses the larger filters
  13. fatbillybob
    Aug 10, 2002
    29,161
    socal
    Well if any later 348 owner who uses the small filters wants some I've got 2 new ones. I paid 60 bucks for the pair. Or if someoen has the large ones and needs the small ones I'll swap. I'm too lazy to make a new bracket so I keep buying the big ones when I need them.
  14. tchaic
    tchaic Formula Junior
    Jul 11, 2004
    601
    Florida
    Chris M.....
    Tell the truth... when you had everything out did you get a sick feeling in the bottom of your stomach that you might not get it back together ok? Love the pics but you are a braver man than me doing all that work!
  15. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Be sure to use some Hondabond HT on ALL the gaskets. If you want your car to be leak free, go get a tube, and apply it conservatively. All you need is a thin layer, just enough so that it barely beads out when you tighten things down. Be sure to put it on both sides of the gaskets.
  16. speedracer1610
    Aug 25, 2006
    332
    nor cal
    Craig D
  17. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Nice! They look sweet! :):)
  18. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    yeah they look awesome!
  19. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Nice powered coating job. I had mind done the same way. I like the shiny look better than the crinkle. Plus it's way easier to keep clean. Just wipe it down with a wet cloth.
  20. rspike
    rspike Karting
    May 5, 2007
    156
    queens ny
    bobby
    I've rebuilt very large nordberd marine diesels in power houses using 10 ton over head box cranes to lift the crank 10,000 of an inch for the thrust bearing removal and I would be scared to attempt this if I had a f car of my own .My question is where did you get the shop manual, spec's etc...
  21. speedracer1610
    Aug 25, 2006
    332
    nor cal
    Craig D
    Daniel at http://www.ricambiamerica.com sent me the manual on cd.
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    If you have done that, then working on a 348 will be a snap. I just got done pulling the heads of my Integra and putting in a new head gasket. It was harder to work on that thing than on my 348. The 348 has WAY more room to work with, even with the engine in stu, than the Integra does. Everything is crammed in there.
    Don't be scared of the name, is still an internal combustion engine. The nuts and bolts don't know what they are on. Lefty-loosey, righty-tighty. Nothing to it. :D
  23. rspike
    rspike Karting
    May 5, 2007
    156
    queens ny
    bobby
    what did the job cost , how much savings? Time ,effort, level of difficulty,etc are you a mechanic?
  24. speedracer1610
    Aug 25, 2006
    332
    nor cal
    Craig D
    I am into the parts for about 2000.00 give or take a few bucks. This includes allthe parts and fluids as well as some additional things I did power coating the valve covers $130.00.
    A little difficult because it is the first time working on this car and rechecking everthing as it comes apart and goes packing the same way. More so time comsuming than difficult.
    Im not a mechanic, but my friend thats helping me is.
