My 348 engine out procedure with pics | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by PassionIsFerrari, Apr 17, 2006.
  1. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    If you havent got the hose off yet,i checked to see what size it is anyways for you this morning. It is a 46mm spanner you will need,or an 18" shifter as tbakowsky mentioned :)
  2. fatbillybob
    Aug 10, 2002
    29,266
    socal
    Yeah...people on this board don't like my assortment of hammers either. I must have 20. One time as an apprentice Ferrari mechanic under the tutilage of a well known Real Ferrari mechanic he asked me how I would get this piece off this delicate distributor on a priceless mille miglia car. I looked him in the eye and said I'd give it a sharp wack with this brass hammer. He looked at me shook his head gave me the distributor and said "go for it." Apparently, I surprised him. All his previous school trained mechanics had all kinds of great ways to do this exact job. Me...I wasn't so smart...all I ever grew up with was a hammer, screw driver , and a welder so you gotta learn to make due.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yeah sometimes you have to "dumb down". LOL :p
  4. Ricambi America
    Sponsor Owner
    Oh lord.... and I think I know what your real profession is. Good thing I don't live in Southern California and need your services! Ouch!
  5. 348_project_car
    Jan 29, 2006
    80
    Chicago
    Dale
    I am stumped by the same question, what comes first bodywork or 30k engine service? Maybe body work should come first before pulling motor, that way you can clean the engine bay from all the bodyshop dust afterwards. I also thought about choice number three, both at the same time, is this a bad idea moving car to shop without rear wheels? Thoughts?
  6. MDshore348
    MDshore348 Formula 3
    Dec 24, 2004
    2,460
    Maryland
    Darron
    i wouldnt as they need to roll it in and out of spray booth. you should paint after, so you wont mess up your new finish installing the engine components.
  7. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    ok....will post pics when I get a chance to upload them....I have almost everything off...Disconnected AC lines (no pressure so I am going to have to have it fixed when I put the car back together), wheel wells and wheels off,removed rear bumper and disconnected all lights to it, oil sump hose off, radiator hose off, Emergency brake line disconnected, brake or speedo sensor, not sure (kinda hidden) disconected,
    I have 2 things left from what I see and know...
    Have to unplug the ECUs and undo the shifter cables....which leads me to my question...
    How do you remove the shifter cables....I removed the plate that covers where they go into that rubber box that goes into the gearbox (btw, what is that rubber box?), but I want to know the best or correct way to remove the cables...
    After this, the subframe gets lowered onto the dollys, then we start with the unbolting and lifting process...
    also, a couple people have talked about the difficulting of re-installing the subframe because of chassis flex, anything I can do like use a prop rod horizontally to keep this from being an issue on re-install??
    As always,
  8. Llenroc
    Llenroc F1 Veteran
    5,560
    Colorado
    Vern
    A little more support on the ajustable wrench thing, I've used one on my 348 and 355 oil lines. Those are big muthas, works fine if you are careful and as for the rubber mallet done that too, also agree one tap is better than yankin' on aluminum(aluminium for our Brit buds here) What did Jimmy Buffet say, oh yea, keep it simple stupid, Regards, Vern
  9. PassionIsFerrari
    Aug 15, 2004
    2,454
    Once I got the adjustable on it with a 14" handle, it came off with a quick yank....No big deal at all!
    Back to the shifter cables......Anyone, anyone? Bueller???
  10. tbakowsky
    Sep 18, 2002
    20,039
    The Cold North
    Tom
    Have a look toward in the opening that was covered by the metal plate. Looking up towards the transmisson you will find a 5mm allen key bolt. Remove it. Now you can slide the entire assembly off the shift shaft of the trans. I will take a bit of jiggleing but it will slide off.
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    The shifter cables are easy to remove. All you have to do is take off the two bolts (10mm iirc) that hold each cable to the selector on the gear box. That's it. The rubber box just covers the connections. When you raise the car off the subframe the cables will just hang there. If you want you can remove the tunnel cover on the bottom of the car, and then remove the bracket in the middle of the cables, that holds them to the body. This will give the cables a bit more room to travel, but it isn't necessary. Also don't forget to disconnect the throttle cable .
  12. PassionIsFerrari
    Aug 15, 2004
    2,454
    Got the throttle cable earlier, as for the shifter cables...are the 10mm bolts under the rubber cover?...also, Tom has said there is a 5mm allen bolt and you are saying that there are 2 10mm bolts...It's confusing me so can I get a little clarification from either of you....Is there more then one way to remove them?
  13. PassionIsFerrari
    Aug 15, 2004
    2,454
    ok...got it out....I unscrewed the 5mm allen screw first but couldn't get it to come out...So I unscrewed the 10mm bolts and it came out with easy...I was looking under the metal plate that I removed with the screws, not realizing that you all were talking about the smaller metal plate that is held in place by the rubber boot!...After I removed the metal plate to the rubber boot, you can see easily how the connections are secured....
    Thanks guys, only thing left is disconnecting the ECU's and then the car gets lowered on to the furniture dollys via the subframe...Everything has been very straight forward to this point.
  14. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Glad you figured it out.
    The ecu's are easy to disconnect. Use shorty standard screw driver to open the push locks that hold down the cover. Just a half turn will unlock them. Once you have the cover off you will see a metal bar on the side of the ecu's. After you remove the retaining screws, holding the ecu's in place, grab the bar and lift it off. It will unplug itself from the ecu's. Then unplug the test buttons (US models), and the other small test connection on the ecu's.
  15. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yeah it can be a bit of a pain to get it out, if you don't have it in the right position. One trick you could have tried is to put the tranny in 3rd. This slides it forward so that you have better access to the allen screw. When you put it back together you'll see what I'm talking about. Be sure not to clean off the grease, or better yet put fresh grease in the slider slot.
  16. PassionIsFerrari
    Aug 15, 2004
    2,454
    Well, its out...there was one hose I forgot to do but as I was raising the car I saw it and got to it...The other thing that happened was the washer on top of the shock mount got stuck to the frame...So I had to lower it again and free the washer from the shock tower...there is also one electrical connection that is still connected..it is zip tied onto the 2 hoses that come from the charcoal canister...
    The jacks that had to use don't go high enough to get enough clearance to wheel the motor out from behind, so I am going to get another set of larger floor jacks that will give me another 6-10 inches...Thats what I need to clear the rear of the car....Almost there!!!
  17. PassionIsFerrari
    Aug 15, 2004
    2,454
    Realized that there is still one more thing connected....the brake line...
    I CANNOT get this thing off!
    Is there a trick or a tip to get the brake line off??
  18. fatbillybob
    Aug 10, 2002
    29,266
    socal
    put wd40 on it and heat it for about 30 seconds with a propane torch. let cool and remove. If that does not work spray more wd40 and repeat. It worls everytime.
  19. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    And take a picture of the flame-on-brake connection! You know that will make for a great shot in the 348 Primer!
  20. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Are you talking about the brake pipe?? Have you also tried using a pipe spanner?? Its like an ring spanner,with a slot cut in it,to slip over the pipe and it gives you more bite on the pipe,instead of rounding the fitting using an open ended spanner. If you know what i mean? :)
  21. PAP 348
    Dec 10, 2005
    100,232
    Pap
    And dont forget the pic of the "burning 348 in the garage" to uplink to www.wreckedexotics.com :D lol
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Did you remember to rotate the subframe 90deg? You need to do that so that the shock towers can pass under the bar that the exhaust heat shields are bolted to.
  23. PassionIsFerrari
    Aug 15, 2004
    2,454
    not yet, have to get the brake line off first....then have to get it up about 6 more inches...Another Fchatter is bringing me some floor jacks so we can get the car higher and slide it under.
  24. PassionIsFerrari
    Aug 15, 2004
    2,454
    Isn't WD40 flammable??
  25. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yes it is.
    He's not saying to make a flame thrower with it. Just spray some on let it soak for a few seconds, then, hit it with some heat.
    Which connection for the break line are you trying to get off, because there are two. Well actually one goes to the top of the trans. But the one on the bottom left, in between the two beams on the subframe, can be taken off using two open end wrenches. At least thats how I did it. If you want, remove the bracket holding it to the side, then you can move it a little bit to get the wrenchs around it.
    Sometimes you have to cuss at it to get it to come off, LOL. :p
