My 348 stopped running on the highway | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by PassionIsFerrari, Mar 4, 2006.
  1. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    Ok...Update...
    Went down to Ft. Lauderdale yesterday...about an 8 hour trip. I managed to borrow a flatbed from John (sweetspotav) to take down there. Very nice of him to help me me out! Went to Shelton at 9am and picked up the car and payed for the tow ($175 TOW, CRAZY)....The guys at Shelton were very kind enough to lend me there whole valet crew to help me load the car on the flatbed. Drove it back today and tonight, me and Greg (owens84qv) loaded it off the flatbed...Greg came over the minute I called him to help out, and a big help he was...We got the car off the flatbed and back into my garage...
    Heres where it gets interesting...
    Me and Greg pulled off the 2 corner plastic covers for the timing belt and here is what we found....
    Driving side top part of the belt is intact and has tension...not frayed...
    Passenger side top part of the belt is intact and is frayed about 1/4 inch....it does have tension....It looks it is jammed maybe where it frayed and chewed up...
    When we turn the ignition on, the driver side of the belt does nothing but the passenger side actually jumps or shakes as is if it trying to spin but it is jammed...
    Our next step is to drain the oil and take the oil pan off and see what we find...
    Obviously, no matter what happens...the motor has to come out because of the fraying of the timing belt...
    Is there a possibility that the whole belt is intact?? If a belt goes does it go, or do some parts continue to have tension? I consider this a big plus, although it seems strange to me...Me and Greg were very suprised to see the belt on the cams...it looks to grooved in the cams as well...
    Ideas? I am going to try to get pics up in the next week....
    Thanks guys, and thanks Greg and John...we are probably goin to tackle the whole engine out between the 3 of us...They are both great guys and I am truly grateful to have some Fchat buddies that are helping me out with all this...
    Look forward to your responses and we will keep you updated...
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Typically the belt doesn't actually break so much as the teeth underneath get sheered off. On mine, the belt and the teeth were intact, but the belt jumped two teeth on the exhaust side and 1 tooth on the intake side (wierd, I realize).
    But this means that your pistons interfere with your valves, which is the bad news.
    Now, you should absolutely pull the engine...but...trust me when I tell you that it is cheaper to buy a running engine for $7,500 than to rebuild the top end...much less the bottom end. A competent machine shop will charge you $500 per cylinder head for machining (or $1,000 each for new ones aftermarket). Valves are $100 each aftermarket, and you've got 32 of them.
    Valve guides are another $22 each (times 32). Head gaskets are $125 each. Intake valve gaskets are $60 each. Exhaust valve gaskets are $50. You'll need 32 valve stem gaskets and a wide variety of O-ring seals/gaskets. You've got front cam gaskets and rear cam gaskets that have to be replaced.
    And then there is the problem itself (e.g. a seized tensioner bearing or a seized water pump).
    I'm just trying to save you from making my mistake. I thought that the rebuild would be cheaper than buying a running engine. I was wrong, especially when you get to sell your blown engine whole or in parts for $4k+.
  3. Rifledriver
    37,335
    If you remember the last thread of a belt failure the band of the belt was intact. The failure was limited to the teeth being stripped off. I said at that time that was the poster child for belt failure. The belt itself almost never breaks and when it does is almost always as a result of a large piece of foreign material getting between the belt and one of the pulleys overstressing the fiber reinforcement of the belt and actually breaking it.
    As I said , rare.
    Yours is far more common and because of the design of the 348 drive system I would hazard a guess that when you get the covers off you will find the teeth stripped off at the drive pulley. The crank is spinning and all cams are stationary.
    Get a look at the waterpump. From your description of the failure event the sound may well have been the waterpump siezing and overloading the belt.
    Get the heads off and have a look. A good chance that only a few valves got dinged and if so may not be a huge price to fix. Th 4 valve motors have such small thin valve stems that often they get bent doing little damage to the pistons. Sometimes the heads break off, then it's a real mess.
    Sorry it happened. Ferrari is not stupid about the life of timing belts. Many come off after many years looking great, some break much sooner. I've said here before, only once have I seen a failure inside the recommended life window, I've seen a hole bunch outside it. Sometimes it costs somebody a Ferrari because they can't afford to fix it and thats a shame. Often all because someone says you don't need to pay any attention to Ferrari.
    I make more fixing one car like yours than I do doing a whole bunch of timing belts prophylactically. I got a 348 coming in in 2 weeks just like yours. It is very avoidable.
  4. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    I thought the 348 has a (1) single serpentine timing belt for both banks?
  5. jjstecher
    jjstecher Formula Junior
    Jan 21, 2002
    962
    Rochester Minnesota
    John Stecher
    t-mobile I gotta ask did they replace the water pump at your last 30k when the belts were changed? It seems to me that when ever your see these things its always because the previous 30k didn't replace the water pump or the tensioners.
    I personally (and I stress personally) have never heard of or seen a failure of the belt or tensioners when being replaced at a reasonable interval of once every 4-5 years. I think longer than that and you are pushing it unless you get some upgrade bearings in both the WP and the tensioners.
  6. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    15,044
    Juan
    John, I just put two and two together. This is the 348 that ran down to Daytona with Janakowski-the Kicker for Oakland in the 720HP Rentech! Really sorry to hear it, a beautiful car. On another note, How's your clutch? Anyone going to Amelia this weekend? A guy from Brumus is detailing my car-I should pick it up on Saturday, then Sebring in a Few weeks.
  7. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    To answer my own question the 348 has one timing belt for both banks that runs the water pump as well, one side moving or turning makes no sense, not to be the bearer of bad news but both banks could have damage with this design. Probably as stated the water pump froze creating a chain reaction.
  8. pistole
    pistole Formula Junior
    Jan 31, 2005
    771
    Malaysia
    #58 pistole, Mar 8, 2006
  9. SFchallenge
    SFchallenge F1 World Champ
    Jun 28, 2004
    11,945
    Sgp, KL, HK & London
    Jon Wijaya
    Oh man, good to hear your car is back & you've got some great help along.
    Now, I'm starting to worry. When they did my 30K major few months ago, they said the water pumps are working fine & doesn't need rebuild, didn't know they can cause a belt seizure as well. :(
  10. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    You have to remember,that if a competent mechanic looks at the water pump and deems the water pump bearings ok,then 9 times outta 10,it wont be replaced by him. On the other hand,everyone here swears that is should be replaced and the tensioner bearings because they can seize and cause major drama. Its a little price to pay for the water pump and the tensioner bearings compared to a engine as in this case? If need be?? Id still trust my own judgement in this area when i do my major/belt change around mid year. :p You would be a god if you could predict when parts/bearing failures happen,but thats impossible unfortunatley ;)
  11. henkie
    henkie La Passione...
    Apr 13, 2005
    10,517
    Deil,The Netherlands
    henkie
    Tmobileguy, I am very sorry to read all this.
    You helped me out a lot when I got my 348 and had some minor issues going on, and I cannot believe that this actually happened to you now !
    I hope you will get your car running again soon.
  12. sweetspotav
    sweetspotav Karting
    Nov 21, 2004
    122
    Florida
    John Cawley
    I have to give credit where credit is due. The trailer was a loan from a good friend of mine (DerekFSU) on here. Other than that, I know Greg was there in a heartbeat to help, he has been for me. I am sure that we will get into it more soon and get pictues and then we all can make a more educated decision. All I know is that I am getting my major done early!
    JDAVID - Same guy! Clutch is good. Seats and interior leather is out for a full restore!
  13. pistole
    Jan 31, 2005
    771
    Malaysia
    totally off topic , but :-
    there was this old trick of putting one tablespoon worth of brake fluid
    into the coolant to act as a lubricant for the waterpump oilseal.
    don't know whether anyone still does this though.
    Hey , JON :- how is yer car treating you ?
    cheers.
  14. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Again, I'll be the voice of hope (not reason). Maybe the belt shredded and bound up against the engine block stopping the motor from running. Then the starter broke its engagement gear and is just spinning, but not engaging the flywheel. Maybe??? Probably not I know, but maybe???
    BT
  15. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    After looking at it last night, this was my voice of hope as well. One of the things that led me to this same thought is the drivers side has zero slop on the belts. The passenger side has a slight amount of slop. Also, when you try to start the car, the drivers side belt and cam pulleys don't move. The passenger-side exhaust cam pulley tries to move (e.g. tugs at the belt), the passenger-side intake came pulley doesn't move.
    Maybe my thought process is all wrong...I'm a 308 engine guy.
  16. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    My only second thought is you can tell by the sound that the starter motor engagement gear is not broken and not just spinning. It sounds as if it is definitely trying to turn the motor over.
  17. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Drop that engine and tear it down. The suspense is killing me!
    BT
  18. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    You'll need a special wrench to get at the head bolts. You can fab one with a 15mm offset boxend and a 1/2" drive extension if you're a good welder or get one from Baum tools. If you don't have one, you might as well go ahead and order it.
  19. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Does anyone have a picture of this tool? I have access to a welder...
  20. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    I don't have it formatted for the forum, but I can email it to you hi-res. Send me your email address
  21. PassionIsFerrari
    Aug 15, 2004
    2,454
    Update...
    John and Greg managed to secure a 6,000 sq. ft. garage to use with a hydrolic lift through a friend of theirs...we are going to flatbed the car up there and put it on the lift sometime in the next week or two and start the process of getting the motor out...In the meantime, I am probably going to getting some of the preliminary stuff out of the way like disconnecting the airbox, muffler, pipes to make our engine out job a little easier...
    Greg has a couple of an engine out procedure for a 348 off of F-chat....
    Question: as far as the ac system is concerned....Are you supposed to disconnect the compressor from the motor and leave the system intact or empty the system and disconnect the lines from the compressor?
  22. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    You have to evacuate the a/c before removing the engine
  23. Ricambi America
    Sponsor Owner
    Hell with the tree huggers... just cut the lines with a hacksaw.
    (Just kidding. DO NOT DO THAT!)
  24. resnow
    resnow Formula Junior
    May 21, 2001
    653
    North Carolina
    Bob Snow
    Right, Daniel. All you really need is a tubing cutter.
  25. PassionIsFerrari
    Aug 15, 2004
    2,454
    I assuming that these cars had r12 when they were first released...I am also assuming that during any major, they have to evacuate the system...Do most mechanics convert the system to r134 at this time...Is it a tough process to convert the system to r134? I have done it in my chevy, just not sure about the Ferrari.
