My 348 stopped running on the highway | Page 4 | FerrariChat
Discussion in 'Technical Q&A' started by PassionIsFerrari, Mar 4, 2006.
  1. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    It's easy. Go here: http://webpages.charter.net/aircover/348/1994Ferrari348Spider.html#AirConditioning and then scroll down to the "Converting" section.
  2. Rifledriver
    37,335
    R12 is getting less expensive every month while R 134 is going the other way.
    In addition Ferrari is not known for the greatest A/C and R134 reduces it's efficiency even further. I have found no reason given the small difference in the expense between R12 and R134 over the life of the car verses the expense (however small) of converting and giving up A/C capacity in the bargin.
  3. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Tim Stanford recommended me to stay with the R12. He said it uses lower pressures, and has larger molecules that won't leak as easily as the R134.
    BT
  4. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    ok..started some of the preliminary engine out steps....Loosened the bumper, removed the airbox, muffler, and pulled the clutch pack out to have a look...I will probably have the plates looked at and material added since I have them out already....
    I assuming that the parking brake cable needs to come off to remove the subframe...What is the best way to remove parking brake cable?
  5. MDshore348
    MDshore348 Formula 3
    Dec 24, 2004
    2,460
    Maryland
    Darron
    it seems we are all going to learn alot from this unfortunate situation ... please post pics along the way so we can document it!
  6. PassionIsFerrari
    Aug 15, 2004
    2,454
    Drained the oil today...There are metal shavings in the oil..They are very very small and not abundant though you can definitely find them and see them if you are looking for them...
    Thoughts???
  7. pistole
    pistole Formula Junior
    Jan 31, 2005
    771
    Malaysia
    probably bits of piston(s) and valve(s).
    hope its not too bad.
  8. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Obviously not a good sign. If you want speculation, that is the result of a piece of valve that has found its way past a piston. Not good for the piston or cylinder wall. But frankly, you don't want the metal to be coming from the bottom end. That would be even worse. Hopefully, you have just a few bent or broken valves and only one bad cylinder. Just think how smart you were to go with a 32-v 348. Nowhere near the potential for disaster that a Testarossa has!
  9. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,632
    The Brickyard
    The Bad Guy
    Oh man, now that will really take a chunk out of the check book.
  10. pistole
    Jan 31, 2005
    771
    Malaysia
    I seriously think that it would be way better to buy that
    rebuilt 348 engine - put that in , and then part-out the
    individual parts from this grenaded engine.
    if there are metal bits in the oil as its being drained out
    from the sump - thats a very bad sign already. Ie , you
    did not get lucky with just a couple of bent valves/guides.
    sorry but that is the way it looks now.
    really hope you come away from this okay.
    cheers.
  11. PassionIsFerrari
    Aug 15, 2004
    2,454
    thats the route I am looking at right now...pricing a couple of motors from around the country.
  12. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    In the end, you'll be on the road quicker...and be able to offset the 'new' motor cost by selling some of the good motor parts.
  13. ajide
    ajide Karting
    Sep 1, 2004
    215
    Fairfax, VA
    Andrew
    don't forget to call these guys to see if they still have the motor to sell.
    http://www.italianauto.com/page2.html
  14. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    15,043
    Juan
  15. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,686
    LA & OKC
    Kevin
    Ouch! Sorry to hear about your mishap. I hope everything works out but if you do decide to sell it, I'm interested.
  16. pistole
    Jan 31, 2005
    771
    Malaysia
    hi.
    any updates with this ?
  17. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    #92 PAP 348, Oct 13, 2006
    He hasnt had any activity on fchat since 29-9-06 at 7.38am and he never replied to Juan-Manual's post from the 27-3-06 about an update. Maybe he threw in the towel and MVP has bought his car. :)
    Here is a pic of his lovely 348 with blown engine. :cool:
  18. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Well, he did allude to some other difficulties he had going on besides the car, so it may be shelved for a time. Hope it all works out.
  19. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    I'd love to find a 348 with a blown engine.....
  20. PAP 348
    Dec 10, 2005
    100,249
    Pap
    That can be arranged.......;);)
  21. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,109
    Wellington, FL
    Duane
    Had dinner with Aaron & another FChatter about a month ago. He had located an engine and was working on a deal to purchase it. I believe he's been in the process of moving, I'm sure he'll update us all soon.
  22. pistole
    Jan 31, 2005
    771
    Malaysia
    good to hear.
  23. Fpassion
    Fpassion Formula Junior
    Jun 1, 2005
    599
    Hope this helps never owned one myself(on the hunt) but good luck in your engine fix. :)
    Year
    Part
    Model Description Miles Part
    Grade Stock# US
    Price Dealer Info Dist
    mile
    1994
    Engine
    Ferrari 512 TR-LS-13 331 MI-TARGA-5 SPD- II0500 $Call Silver Star Recycling USA-CA(Rancho-Cordova) E-mail 1-800-783-4911 2374
    1994
    Engine
    Ferrari YELLOW-ENG CAB FIRE-35 659 MI-SPYDER II0500 $Call Silver Star Recycling USA-CA(Rancho-Cordova) E-mail 1-800-783-4911 2374
    1994
    Engine
    Ferrari 348-YELLOW-FI-SPYDER - II0500 $Call Silver Star Recycling USA-CA(Rancho-Cordova) E-mail 1-800-783-4911 2374
  24. PassionIsFerrari
    Aug 15, 2004
    2,454
    Sorry, it's been so long...I have been PM'ing with Plugzit from time to time... Ok, I will get pics up when I get my camera back but here is the skinny...
    Finally pulled the heads off today (had to move, new job...a.k.a...got put on the backburner) and here is what I found....
    No broken valves...all valves are intact...80% of them are bent (to be expected)
    you can see where the valve pinged the piston heads on about 3 of them.
    No cracked pistons
    Cylinder walls look ok, no scoring that I have found yet....
    Oh yeah, Plugzit send me the special tool to pull the heads off so just wanted to say "thank you very much" and let everyone know how much I appreciate it...
    Everything functions properly when I hand turn the crank...thus all pistons move correctly...
  25. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    Sorry for your misfortune. Did you determine what REALLY failed? Belt, bearing, or tensioner? I'm betting on the water pump. Or possibly a loose belt that jumped a couple of teeth.
