My 348 stopped running on the highway | Page 5 | FerrariChat
Discussion in 'Technical Q&A' started by PassionIsFerrari, Mar 4, 2006.
  1. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    It was the tensioner bearing that seperated...the inner race seperated from the outer race and flung off...when that let go, no tension...belt still stayed on...
  2. PassionIsFerrari
    Aug 15, 2004
    2,454
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,849
    Cerritos, CA.
    Hey Al Bundy, did you check out the Ferrari discusion section about a yellow 348 that's been trash? You better go there NOW
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,633
    The Brickyard
    The Bad Guy
    So are you gonna buy Plugzit's engine? In my opinion that will be the cheapest and fastest way to get your car back on the road.
  5. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,275
    MA
    If, key word, tmobileguy’s damage assessment is accurate, why wouldn’t it be faster, and a lot less costly, to buy valves, have the heads freshened, assemble and drive? Costs would be head work, gaskets, new belt, tensioners etc. Just curious.
  6. PassionIsFerrari
    Aug 15, 2004
    2,454
    That is where my thinking is going as well...I have run my fingers up down each cylinder wall, and aside from some carbon build up, they are smooth as silk...no scoring at all...
    The valve stem are for sure bent, I can bend many of them back with my hand (I'm not implying a fix!)...but NONE are broken...
    The dings on the piston heads are very small, they barely made it past the carbon deposits on the piston heads....
    I have a line on a set of heads from a wrecked car here in FL....$1500 for both...
    What my thoughts are...
    Buying the heads and bolting them back on with new head gaskets....Then testing compression, if all cylinders are holding compression then I am assuming I am back in business....YES? NO? THOUGHTS????
    Obviously, I am putting on new cam seals, new tension bearings, updating the water pump, new cam belt, and new hoses....
  7. Rifledriver
    37,335
    Sounds like a good plan if the heads are in useable condition. That is cheaper than buying a bunch of good aftermarket valves and just popping them in your old heads. Then you still have a pair of rebuildable heads you can sell or trade for ?
  8. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    Good plan. What about the metal you discovered in the oil? You should inspect the bottom end while you have it out. If it checks out, be sure to flush out the oil lines, oil cooler, oil reservoir and of course replace the oil filter. Also, blow compressed air through all the passages. You don't want something trapped in there to come back to haunt you.
    Personally, I would inspect the main bearings, rod bearings, and cam bearings. That is where you will see the evidence if anything went through the engine. Don't be surprised to see some wear in the direction of travel. But if you see any flaking, pitting, or gouges then you should replace your bearings.
  9. aj10803
    aj10803 Rookie
    Aug 5, 2005
    26
    California
    I just want to say good luck with this car. I am sure you can work it out.
  10. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Al, its good to see your back and that you are still trying to get the car up and running.
    I cant imagine a better option than nabbing a set of good useable heads for that cost. I dont see how you can go wrong on that deal. And like mentioned, youll still have an extra set of rebuildable heads. Fire that mother up!
  11. PassionIsFerrari
    Aug 15, 2004
    2,454
    #111 PassionIsFerrari, Jan 21, 2007
  12. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    you're a very lucky guy
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I wonder if there is less "interference" in our 348 engines than we've been led to believe...
    When my timing belt slipped all that happened was I that got 16 bent valve-guides and a blown head-gasket.
  14. Rifledriver
    37,335
    What were you led to believe? Also how did the timing belt problem lead to a blown headgasket?
  15. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Good question.
  16. Rifledriver
    37,335
    I am genuinely curious. As far a engine damage from a cam timing issue I have never heard a claim from anyone who showed enough knowledge to pay attention to (the rest I really don't remember because I really don't care what they say) say more than valves will bend and pistons may be damaged. In his pictures and statements that is what I get. A bunch of bent valves and slightly damaged pistons. Am I missing something? Have we been threatened with parts hanging out the sides?
    Just wondering.
    Ferrari motors especially the 4 and 5 valves have very low lift (don't need much lift with small valves) to do anything very dramatic when you have a piston-valve interface. That and the small diameter stems pretty well insure the valve heads just get pushed out of the way.
    As for your head gasket, pretty rare problem on these motors. Can't think of any connection to a timing belt/bent valve problem.
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Well, you got me on that one. My original theory was that me laying on the intake plenum to remove the cam-belt inspection cover caps caused my head-gasket problem, but I caught so much flack for that theory here that I had to believe that I was in error.
    My head gasket was blown at the same time as my cam belt slipped. As to the cause...I don't know. From your words it appears that a slipped cam-belt would be an unusual cause of a blown head-gasket. I had an alternative theory, but that theory was dissed unanimously.
    It's a mystery. No big deal, but in relation to this thread I was merely trying to show that I had experienced very little damage from a very similar problem, too.
  18. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    I've never had a problem with a Ferrari, but I had a couple of E-types one slipped a timing chain. it just made a mark on a couple of the pistons and bent a few valves. the work to fix it was more than the cost of the parts.
    bad things happen when the valve head gets broken off.....
    saw a dino engine that did that. looked like someone took a ball peen hammer to the inside of the cylinder.
  19. PassionIsFerrari
    Aug 15, 2004
    2,454
    I would think thats where you get your catastrophic damage. If that valve actually breaks off, then I could imagine some serious stuff going on in there..mainly destroying the cylinder walls...
    Do engine designers build interference motors like this on purpose, to make valves bend easily to save damage but to not actually break?
    The only thing I can't see is the actually piston breaking....how does it actually break the piston?
  20. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    Looks like it wasn't going to be long before you needed some valve work anyway. From the photo, I see a couple of marginal valve seats.
    Also, looks like you're burning oil. Are you going to replace the valve seals on the heads you're getting?
    Were those two outer cylinders already clean? Or did you do some cleaning?
  21. PassionIsFerrari
    Aug 15, 2004
    2,454
    Did some cleaning myself, going to get them all cleaned up...burning oil, is that from valve seals leaking oil into the combustion chamber?
    As far as the valve seals, is this a ferrari weak spot...the new heads only had less then 10k miles, so I was planning on just bolting them in...
  22. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    Here's some items that will break a piston.
    1. Sucked valve. Valve retaining clips coming loose (usually weren't installed properly), or extreme rpm's causing the valves to float enough to contact the pistons and allow the clips to come off.
    2. Broken ring. Extreme rpm's or overheating are possible causes.
    3. Detonation. Preignition caused by incorrect timing, fuel, or overheating.
    4. Foreign object sucked in through the intake manifold. (once, I found a bolt imbedded in the top of a piston.)
    Never had a piston break because of a broken timing chain or belt. However, I wouldn't say it couldn't happen if the conditions were right, but it would be pretty tough to do.
  23. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    Good, at first I thought you may have been sucking water into those two cylinders.
    Valve seals or oil rings.
    Don't know if it's a weak spot, but most likely caused by lack of use and age. After all, they ARE 16 years old. I can't remember who posted the statement "You're going to pay for the maintenance whether you drive it or not, so you might as well drive it". I agree whole heartedly.
    Anyway, I'd replace the seals, easier now then later.
  24. WRAITH
    WRAITH Rookie
    Jun 25, 2006
    25
    COLUMBUS OHIO
    PM me if you are interested in selling your old heads
    This is typical damage for belt failure on 348s I have repaired two others with same damage. 30 valves bent each time.
    I have also seen the timming belt drive bearing fail. Ferrari upgraded to a better bearing design at some point. Probably early in production.
  25. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    So timing belt failure isn't generally "catastrophic," but something a little less disastrous.
    Bent valves. Damage to heads? Pistons still re-useable. Cylinder linings OK. Crank OK. Rods OK.
