My 355 mini-Restoration story | Page 13 | FerrariChat
Discussion in '348/355' started by treedee3d, Oct 20, 2011.
  1. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Veramente non ho il tempo pero me lo so fatto per forza!!!!
    Ci vediamo martedi?
  2. bernardo66
    bernardo66 The Crazy Cat Man
    Dec 14, 2003
    26,527
    Montreal Canada
    Bernie
    Si.
    However, 6PM is too early for me. I'll be there around 6:30PM.
  3. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Nice muffler! Be sure and share a sound clip with us :)
  4. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    This thread is utterly inspiring. Great work.
  5. eyboro
    eyboro Formula Junior
    989
    Chicago
    Eitan
    I think this thread name should be changed to ”major restoration project”
    one of the best threads on Ferrari chat.
  6. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    I asked the moderators to do that for me but they never responded so I just dropped it. Thanks for the kind words....
  7. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    After putting back in most of the interior, I charged the battery and turned the key and almost nothing electrical is working at the moment.
    instrument lights and gauges: Not working
    hvac panel & fan: Not working
    Radio: Not working
    gas, fuel gauges & clock: Not working
    Brake lights: Not working
    Headlights: Not working
    Wiper motor: Not working
    Door open beeping sound: Working
    door lock button switch: Working
    Hazard lights: Working
    I'm not very good with wiring diagrams and stuff so is this going to be complicated to diagnose?
    I am so discouraged right now.......
    Looking at the workshop manual, it seems that the stuff not working all pertains to the "circuits energized by the ignition key" except for the radio
    I did kind of screw up by starting to dissasemble the interior without disconnecting the battery, I removed the radio and guauges above it as well as half the connections in the instrument cluster before realizing that the battery had not been disconnected. I therefore disconnected it at that point and continued on....
    Every connection inside the passenger compartment and doors was disconnected and the battery. Every other connection on the car was left "as is" while the car got repainted.
    I also used a spare key that I had made for the first time but it seems to work fine. Is it possible the circuit is unresponsive because I am not using my original key?
    I am not sure how to go about diagnosing the issue.......any help here will be greatly appreciated
  8. lucky73
    lucky73 Formula Junior
    Mar 13, 2008
    257
    you knew there would be one seriously depressing moment and this might be it, you've hit bottom.
    its monday morning and whole country is drinking coffee and troubleshooting this for you right now, hang tight someone will respond with something more useful than my chat encouragement.
    the nice thing about hitting rock bottom is that is gives you something to push off of...
    "I am not sure how to go about diagnosing the issue.......any help here will be greatly appreciated"
  9. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #309 treedee3d, Mar 5, 2012
    Thank you everyone for your help and kind words. All the above posts have helped me figure out the problem as well as Dave Helms and Bradan.
    I basically removed the steering column cover and looked at every single connection and they were all ok which was even more depressing. After cursing up a storm I went back in...
    I then spotted a red cable that was a little too exposed on the back side of the plastic connector so I opened the connection and, sure enough, there it was: the male from the red wire had gotten pushed back and arched crooked so there was no connection. I assume the red means power in automotive wiring so I adjusted the male, pulled it back into the plastic until it popped and placed it in line with the others.
    Popped that sucker back in and everything is working....Like everyone said: It will turn out to be something so small and stupid (and indeed it was...)
    I lost so much sleep over this issue over the weekend. what a relief!!!!!
  10. dailyferraridriver
    dailyferraridriver Formula 3
    Nov 12, 2010
    1,402
    New Jersey
    Erik
    Congrats! Glad it was something basic that you were able to solve somewhat quickly.
    Erik
  11. lucky73
    Mar 13, 2008
    257
    collective "sigh" of relief from the crowd...
  12. White Knight
    White Knight Formula 3
    Aug 22, 2011
    1,531
    Ogden, UT
    Todd S.
    As said before, it looks great!
    Best thread I've read on here in a while.
  13. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Thread count is now at 30,000+ views....amazing!
    Thank you all for following my story. Tomorrow the car should be completely put together and I will have more pictures
  14. bernardo66
    Dec 14, 2003
    26,527
    Montreal Canada
    Bernie
    Did you film it when you fired it up?
  15. JDG16
    JDG16 Karting
    Jul 25, 2011
    200
    Houston
    Justin
    I can't wait... this has been a blast to follow
  16. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Actually I didn't start it but all the lights came on the dash, the instruments, radio, hvac, headlights, etc... That was enough for me to jump for joy!
    If all goes well I should be able to start it tomorrow and let it idle for 10-15 minutes so that the car can reprogram itself.
    Once the body shop is finished, the car is going to Ralph at Monaco Prestige to install my new Nouvalari exhaust, change the power steering reservoir and remove some engine components for some Hydro carbon dipping detailing including refinishing the calipers and changing the brakes.
    I also plan on rechroming my wheel bolts
  17. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    Congrats on the fix! Can't wait to hear the sound of it running! ;)
  18. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #318 treedee3d, Mar 7, 2012
  19. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #320 treedee3d, Mar 7, 2012
    New stickers under rear hood.
    In order to make sure the car looks original, I bought a new airbag sticker as well as a new paint sticker.
    Eurospares carries a ton of Ferrari original paint stickers but unfortunately did not have the Rosso Scuderia 323 so I bought a plain paint sticker from them and added the paint code by overlaying another sticker I made with a label maker.
    Looks great!!!! I can't believe I'm at this late stage in the game that I'm actually putting stickers back on the car.
  20. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #321 treedee3d, Mar 7, 2012
  21. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #323 treedee3d, Mar 7, 2012
  22. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #324 treedee3d, Mar 7, 2012
  23. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Fab:
    You can also try Mother's "Back-to-Black" on your trim pieces. I've had very good luck with it.
    BTW, you have done a fantastic and extremely complete job. Feel very proud. :)
