My 360 running strange-less power, brake is strange | FerrariChat
Discussion in '360/430' started by Rock-46, Jul 2, 2012.
  1. Rock-46
    Rock-46 Karting
    Jun 3, 2010
    77
    Slovenia-Europa
    Rok Pogačnik
    I noticed on my car that when I turn the ignition car runsof normal in all eight cylinders, but the brake pedal is hard, as that there is no servo brake.... Then after about 30 seconds the car starts to run a little more weird,like it would get too much gasoline or somewhere pulling the air ...
    anyone know anything before I go to the tester
  2. eric355
    eric355 Formula 3
    1,228
    Toulouse (France)
    Eric DECOUX
    Check the vacuum line between the intake manifold and the brake booster.
    If there is a leak there, it could explain both the hard brake pedal (no vacuum to assist) and poor engine running (unmeasured air in the intake).
  3. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Sounds like you have a vacuum issue. There are two check valves fitted to the front of the inlet on the Modena and the rear of the inlet on spiders which are problematic, or you could have an issue with the diaphragm in the booster itself. Either way I'd not drive until you have had the issue addressed as it is potentially dangerous...
  4. Rock-46
    Rock-46 Karting
    Jun 3, 2010
    77
    Slovenia-Europa
    Rok Pogačnik
    Does anyone have pictures where to look exactly?
