My 360 stereo system | FerrariChat
Discussion in '360/430' started by S F Yellow, Jan 7, 2014.
  1. S F Yellow
    S F Yellow Rookie
    Jan 4, 2014
    11
    Shreveport, Louisian
    Greg Barro
    I own an '04 360 Spider with the factory installed 6 disc CD player and the sub woofer upgrades sound system.
    The stereo worked perfectly fine up until the other day. When I turned it on, I couldn't hear any music. I turned the volume up all the way and could barely hear muffled music with low volume static coming over the speakers too. This happens whether I'm playing the radio or CD.
    Has this happened to any of you guys? If so, what is the fix?
    Thanks,
    Greg
  2. Fatty
    Fatty Karting
    Jun 5, 2010
    235
    Australia
    Any number of possibilities, but the first thing to check would be the ISO connectors at the back of the headunit. It could have come loose.
    Check all wiring, and if the wiring seems good, it could be the actual headunit itself.
    good luck.
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    I suppose this has the auxiliary amplifier to power the subwoofer? If so, I'd check the fuse to the amp since you can faintly hear the music.
    Sent from my iPad using Tapatalk HD
  4. S F Yellow
    S F Yellow Rookie
    Jan 4, 2014
    11
    Greg Barro
    Fatty, Bob, thanks so much
  5. S F Yellow
    S F Yellow Rookie
    Jan 4, 2014
    11
    Greg Barro
    Where are the ISO connections located? Behind the stereo unit?
  6. Fatty
    Fatty Karting
    Jun 5, 2010
    235
    Australia
    That's correct. Check for one of my other posts on the head unit. I've uploaded pictures of the factory connectors.
    Cheers
