my 360 wont start | FerrariChat
my 360 wont start
Discussion in '360/430' started by Giallo360, Aug 8, 2007.
  1. Giallo360
    Giallo360 Rookie
    Aug 8, 2007
    12
    Saddle River N.J.
    Howie
    I have 2004 360 today it did not start it just cranked . All lights work except trunk . Is it my battery and do I have to replace it or can I charge it.
  2. VK430gt
    VK430gt Formula 3
    1,146
    Anywhere Anytime
    VK430GT DUH!!
    From what I understand, you can charge a battery. Welcome to f-chat and fill out your profile of you want.
  3. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    If it is cranking it probably isn't a battery. Two simple ideas:
    Did you deactivate the imobilizer? You have to push the button on the alarm before you start the car.
    Is the car in Neutral? F1's won't start in gear. Push on the brake and shift to N. Then try it again.
    If you have run the battery down there are several threads on chargind the battery. Rifledriver posted on this subject several times. NOTE: you will have to turn off the battery switch or risk electronics damage. Once you do that you have to follow the startup proceedure outlined in the manual. Basically turn the key to position II for 10 seconds (I think that is right amount of time) before you start the car.
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You'll want to know if it isn't starting because you have no spark, or if it isn't starting because you have no fuel.
    The easiest way to do that is to spray some $2 starter fluid into your engine air intake.
    If the car starts with the starter fluid, then you have a fuel problem, not a spark problem.
  5. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    If it's cranking then it's not the battery. It most likely has something to do with the immobilizer (alarm on your fob). Either you're not deactivating it or something is wrong with the unit itself.
  6. dsevo
    dsevo Formula Junior
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    I'll bet the immobilizer isn't deactivated. The same thing happened to me the first day I bought my car and it freaked me out for a couple seconds until I realized what was going on. If the car sits unlocked for more than 120 seconds it will automatically activate the immobilizer.
  7. VK430gt
    VK430gt Formula 3
    1,146
    Anywhere Anytime
    VK430GT DUH!!
    according to what you guys are saying, maybe it couldnt be the battery, it could just be the alarm.
  8. RonnieF430Spider
    RonnieF430Spider Formula Junior
    Jan 25, 2006
    995
    Westlake Village, CA
    Ronnie C
    When the immobilizer is activated, the car will not crank.
  9. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Besides the immobilizer, the car also won't start if the battery was previously dead or disconnected via the trunk switch, unless the key is in the second position for at least 10 seconds before cranking. This info comes from the manual.
  10. Giallo360
    Giallo360 Rookie
    Aug 8, 2007
    12
    Saddle River N.J.
    Howie
    Correct me if I am wrong. If I hear 2 chirps on the imobilizer the car should start. Is that correct. I have the car for two years and never had this issue. Am I missing something simple. The lights are all bright the radio plays.
  11. RonnieF430Spider
    Jan 25, 2006
    995
    Ronnie C
    You are correct. Your problem is not with your key fob.
  12. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    This is not true. It will crank, just won't start.
    Jack is correct, you have to leave in II for 10 seconds. Then idle for, as I recall without looking it up, 15 minutes. Don't touch gas or anything, just idle.
  13. dsevo
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    This is incorrect. It will crank. I have done it with my car, so I think I should know.
  14. nt6d
    nt6d Formula Junior
    Jul 28, 2004
    468
    Los Gatos, CA
    Chris
    Both are correct. I think it depends on the year. My 360 does not crank if the immobilizer is activated.
  15. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    I stand corrected, sorry for stating so emphatically. I learned something new but should have guessed that there was that much variability. After all, the alarm has 3-4 different chip/flash options depending on what region it is configured for.
  16. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Foot on the brake? as well as the imobilizer off
  17. RonnieF430Spider
    Jan 25, 2006
    995
    Ronnie C
    This must be correct and is interesting at the same time. My 360 Spider is an 02, and when the immobilizer is activated, I hold the button on the fob down until I hear 2 chirps, get in the car, put the key in and turn it to the first position, and when I get an "OK" on the dash, I start the car. If the immobilizer is activated and I do not hold the button and get chirps, when I turn the key to start the car, it does not turn over.
  18. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    My 2003 Modena cranks but not start when the immobilizer is activated. This seems like a step backward from the no-crank 2002 since it wastes battery power.
    By the way, can an expert car thief start the 360 when the immobilizer is activated?
  19. RonnieF430Spider
    Jan 25, 2006
    995
    Ronnie C
    An expert car thief can steel any car that is not chained down.
  20. $$$=SPEED
    $$$=SPEED F1 Veteran
    Aug 18, 2004
    5,330
    Portland, Or. USA
    Depends who's asking
    Not to be too much of a smart ass but you will find that if you drive the car the battery will not die :)
  21. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Your right on both counts but it is a SA comment I travel a lot customer vists, plant visits and drive at weekends when I can, it does not say I dont want to drive more. I find the Battery Tender avoids the run down of the battery. I had my biggest battery issue after the major service when it was turned off to take the engine out.
  22. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Not easily. Of course you could use a flatbed but starting the car ... ok, probably not.
    The immobilizer is integrated into the ECU. Without the immobilizer code the ECU does ot function so no car. The code is encrypted so you can't just grab it. Also, you can't just buy the parts, a dealer has to purchase the parts from Ferrari and won't do so until you provide proof of ownership.
    Besides all of that, where are they going to sell one? There are serial numbers all over the place and a pretty limited market. You can't hardly part it out either.
  23. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    does the car have gas in it? :)
    Ray
  24. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    That's what I think too, but most newer cars have the same type of built-in immbolizer too. Does that mean that a lot fewer cars get stolen nowadays? There is still a popular notion that an expert thief can start any car.
