My 458 AVH Manettino and CST failure | FerrariChat
Discussion in '458 Italia/488/F8' started by Jackwong, Oct 31, 2018.
  1. Jackwong
    Jackwong Rookie
    Oct 31, 2018
    12
    HONG Kong
    WONG TAN
    Dear all
    I dunno if I post at the right forum but just have some issue with my 458 which I had only purchased for just over a month
    It’s a 2010 458 with 20000km on it
    Starting from yesterday
    The screen show ASH system failure
    Manettino failure and CST system failure
    I have try to switch off the car and wait for awhile and the code are gone
    But after driving a few miles then it came back again
    Feel frustrated and any comment s
    Thanks in advance
    Jack from HKG
  2. Ash Patel
    Ash Patel Formula Junior
    Dec 12, 2015
    548
    Stockholm, Sweden
    #2 Ash Patel, Nov 1, 2018
    I had exact same issue. May I ask where you're located as mine started to show up when it got more chilly outside.
    Don't worry though as for me it was only the braking light contact that caused the issue. Resolved by my tech and cost me 150 EUR :)
    I would say for the most of the time when these electrical failures shows up on the 458 I never get to worried as in my case there has always been either bad battery (very rare in my case over 4 years of different 458:s in my ownership), bad cables that needs replacement --> just minor adjustments
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,248
    Mel
    Find out the date of your carbattery: if over 2 years … replace first !
    488Julius and ca_scud like this.
  4. up4speed
    up4speed F1 Rookie
    3,639
    Long Island, NY
    Chris
    I agree with the above. On a 458, if there is ANY electrical issue that is random and intermittent, change the battery first. It's only about $200 and it's the cheapest thing it could be. You may even be able to get it prorated, so it's not all lost.
    A LOT (or most) of the electrical gremlins that happen on 458's are a result of a failing battery. It's amazing how it can have enough power to start the car, but then do other wonky things.
    Shorn355, ca_scud and Ash Patel like this.
  5. Jackwong
    Jackwong Rookie
    Oct 31, 2018
    12
    HONG Kong
    WONG TAN
    Thanks a lot guys for the comments
    I will try to replace the battery first and see how it goes
    Appreciated
    I am from Hong Kong by the way
  6. Nsd991
    Nsd991 Formula Junior
    Jul 19, 2012
    538
  7. spyder625
    spyder625 Formula Junior
    Jun 16, 2017
    726
    NJ
    i would say the same thing happened to me, Battery related. should be an easy fix
  8. up4speed
    up4speed F1 Rookie
    3,639
    Long Island, NY
    Chris
    If you don't want to pay dealer $700, buy the Interstate MTX-48 H6 battery and install it yourself, it will be under $200.
    bball16 and Ash Patel like this.
  9. Jackwong
    Jackwong Rookie
    Oct 31, 2018
    12
    HONG Kong
    WONG TAN
    Thanks a lot guys
    I took the car back to dealer and they said the battery is just fine
    They just use the computer the erased the code and told me good to go
    Haven’t have any problem since and hope it stays this way
    Once again thanks a lot guys
  10. up4speed
    up4speed F1 Rookie
    3,639
    Long Island, NY
    Chris
    I'm glad you got it fixed.
    However, don't be surprised if the issue comes back. Sometimes batteries have intermittent issues. I've had that happen to me a few times in the past, and it can drive you crazy!
    Hopefully yours stays fixed, but if it doesn't, I strongly recommend replacing the battery first, just for good measure.
    In the past, one battery I had, tested perfectly, then it would randomly die about once a week. It drove me nuts until I realized that the battery had an intermittent internal short. I know that yours didn't die, and worked perfectly to start the car, but these cars are VERY sensitive to a proper voltage when all the systems are booting up.
    My 360 would run on 1/2 the cylinders when the battery got old. It cranked perfectly strong, but the left and right bank motronics wouldn't communicate with each other unless the battery was perfect. That one also load tested perfectly, and cranked the engine perfectly strong. These cars are VERY strange, lol.
  11. Jackwong
    Jackwong Rookie
    Oct 31, 2018
    12
    HONG Kong
    WONG TAN
    Thanks a lot for your comment
    I may just replace a new battery next time for servicing
  12. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    829
    Michigan
    Tony
    I agree with the others who replied to you. Replace the battery. I also had a dealer test my battery and said it was good. But it wasn't good because I also had intermittent warnings. Replaced the battery and now the car is happy.
    ForeverNA likes this.
  13. ForeverNA
    ForeverNA F1 Rookie
    2,513
    Yes. Very likely it is the battery when every system is listed malfunction simultaneously.
  14. Jackwong
    Jackwong Rookie
    Oct 31, 2018
    12
    HONG Kong
    WONG TAN
    But out of curiousity
    What are the most common problems 458 likely to have and any way to avoid it?
  15. daflk
    daflk Formula Junior
    Jan 27, 2013
    257
    Hong Kong
    I’m in HK too
    The most likely is battery
    But if it’s consistently same message it’s a sensor issue, brake light, speed or ABs sensor
    Go to dealer or other mechanic with Leonardo computer to get a reading, it should be very quick check. I can recommend someone PM me
    Ggear likes this.
  16. Jackwong
    Jackwong Rookie
    Oct 31, 2018
    12
    HONG Kong
    WONG TAN
    Thanks a lot dalfk
    I got it fixed and so far it’s fine and I hope it stay this way
    Driving this car is somehow a bit scary and I hope not major break down anytime soon
  17. daflk
    Jan 27, 2013
    257
    Hong Kong
    Don’t worry it’s a reliable car, just electronic sensors and battery are timed life and need to be replaced once in a while
    Mechanically sound car gearbox and engine are quite bullet proof
  18. Jackwong
    Jackwong Rookie
    Oct 31, 2018
    12
    HONG Kong
    WONG TAN
    Thanks a lot Dalfk
    I am really enjoy the car and plan to keep for a while
    daflk and up4speed like this.
  19. Ggear
    Ggear Rookie
    Aug 26, 2017
    38
    Hi,
    How did you get it fixed?
  20. Ggear
    Ggear Rookie
    Aug 26, 2017
    38
    I have the same issue in HK. How to fix?
  21. Melvok
    Jul 25, 2008
    14,248
    Mel
    Exchange battery first ! You may look in my YOLO thread …. how to do that yourself.
  22. IloveGT
    IloveGT Formula 3
    2,419
    I will still just change the battery, like what everyone said. Trust me. It will save you many headaches. And put the battery tender on, ALWAYS!
    Also hope the riot in Hong Kong is over soon! It even made the news over the ocean.
  23. daflk
    Jan 27, 2013
    257
    Hong Kong
    Sometimes CAN errors can occur randomly that’s not sensor related which triggers mannetino errors.
  24. Yellowgallardo1
    Yellowgallardo1 Karting
    Sep 19, 2018
    143
    marcus
    I had a similar issue that I had diagnosed . I ended up having to replace a wheel speed sensor
  25. sampelligrino
    sampelligrino Formula 3
    Apr 16, 2017
    1,245
    Updating this thread as I just ran into the similar manettino failure/wet mode/flashing warnings with my 2014 458 Speciale (~16k miles)
    Doing *ahem* spirited driving and mid corner my car sh!ts the bed, higher revs and warm temps outside in manual mode. I got the same manettino wet mode warnings/failures, noticeably along with limp mode power and actually what felt like a big loss in brake boost
    Car is on CTEK tender 100% of the time it's not being driven, on an aftermarket AGM batt
    Turning car on/off trying to reset on the side of the road did nothing, but when I was able to make it to a gas station to get gas 30 min later that reset the car back to normal all warnings gone (so maybe needed more time off to reset/initialize reset)
    Dealer says they isolated the issue to a faulty accelerator pedal sending "all kinds of performance and warning issues", which had to be replaced FWIW ($1000...)
    MANDALAY and AlfistaPortoghese like this.
