My 83' 308 QV has a Brake Failure warning light? | FerrariChat
Discussion in '308/328' started by 308 Grigio, Aug 16, 2014.
  1. 308 Grigio
    308 Grigio Rookie
    Sep 11, 2007
    21
    St. Louis, MO
    Albert Stix
    So my son and I are headed back to the hangar where I keep my car, after a quick Friday afternoon visit to the barn to watch my two daughters ride, when a strange red light pops on. "Brake Failure". Hmmm.......never knew the car had that light to begin with and I've owned this thing since 1992 so I just figured that it might be some sort of electrical fault. On our little outing today the driver's side window decided to stop going up or down again (a problem since it was about to start raining pretty hard) and also the blower fan decided to stop blowing air. Truth be told that window has been giving me trouble for a while and the blower switch has not been moved in a long time so I'm not sure when that quit working. I assume there's probably no connection between the window, the blower, and the Brake Failure light but I'm glad I was near the hangar and slowing down because when it came on, it was not kidding. Within about 30 seconds of that light coming on, I had no brakes. Anyone had their Brake Failure light come on? Thanks in advance for any help or advice
  2. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    I did not see this warninglight in my car either:):)
    It might be the one for low fluid level. I know the container with brakefluid is wired. So btw is the splitter/biasvalve with the line to the rear
  3. pshoejberg
    pshoejberg Formula 3
    1,818
    Denmark
    Peter H
    #3 pshoejberg, Aug 16, 2014
    As mentioned by Steven it could either be the fluid level sensor or the differential pressure sensor in the hydraulic splitter manifold.
    First check if you are low on brake fluid or if the fluid level sensor for some reason is faulty.
    Then check you splitter manifold: The sensor on the manifold will indicate if you loss pressure on one of the brake circuits (Hydraulic leak), however the pressure sensor is known for giving false indications and the sensor is prone to get stuck due to dirt and/or corrosion.
    The splitter manifold is located in the front of the car just next to the steering rack. You will have the access it from below via the small aluminum access plate.
    Good luck with the fault finding.
    Regards
    Peter
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Bleed, top up fluid.
    Check fuse on the window thing.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Is that splitter/tubing in the picture original? The pic makes it appear that the tubing is standard copper - like you'd find in a hardware store. Or is the copper appearance in the pic a function of the lighting?
  6. pshoejberg
    1,818
    Denmark
    Peter H
    It's copper piping bought in bulk length and cut to fit. Originally the piping is made from galvanized steel as I remember it.
    Peter
  7. AaronMeisner
    AaronMeisner Formula Junior
    Jul 15, 2014
    267
    Baltimore MD USA
    Aaron Meisner
    I'd be very interested in knowing what the cause of the actual brake failure turns out to be. Usually these lights come on for some stupid reason that rarely turns out to be an actual brake failure. In this case, you had a real failure--so that's scary. Is it possible that you have original brake lines that finally gave up the ghost?
    Regarding copper brake lines, my experience is that copper is extremely brittle and doesn't generally like automotive applications where you have a lot of vibrations and strange forces.
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Hmmm... Steel tubing or copper/nickel tubing is used for brake lines. Plain copper tubing for brakes is illegal in the US though perhaps that's not be the case in other countries.
    Perhaps what you have there is copper/nickel though it looks like standard copper. If it's standard copper, it could not pass a safety inspection in the US...not that it matters since it's in Denmark! :)
  9. ClydeM
    ClydeM F1 World Champ
    11,876
    Wayne, NJ
    Clyde E. McMurdy
    I've had it on four times with my 83 qv
    1) Low fluid level - brakes were fine
    2) brake fluid level float got stuck - brakes were fine fix: rap it lightly a couple times.
    3) brake balancer (show above) had a poor electrical connection - brakes were fine. fix: clean the contacts.
    4) Brake was dragging on the caliper. Fluid boiled. Brake pedal went to the floor (scary - but I was only doing like 20 pulling up to a traffic light). fix: rebuild LR caliper.
  10. pshoejberg
    1,818
    Denmark
    Peter H
    #10 pshoejberg, Aug 16, 2014
    I've had this discussion with Americans several times....-:) Standard automotive copper pipe has been approved and used for brake lines in Europe with no issues for many many years and are still fully legal, at least in Denmark. I use copper/Nickel on my Dino 246 project primarily to avoid any confusion/questions. The price is nearly the same, but pure automotive copper pipe is easier (Softer) to work with.
    You can buy it here:
    http://www.biltema.dk/da/Bil---MC/Bilreservedele/Bremsesystem/Bremseror-og-Nipler/Bremseror-316-66482/
    Best regards Peter
  11. 308 Grigio
    308 Grigio Rookie
    Sep 11, 2007
    21
    St. Louis, MO
    Albert Stix
    Thanks for the responses! You folks are very helpful, as usual! Raining hard today so it will be a good day to have a look and see if I can figure out what happened. Like ClydeM noted above, in this case not only did the brake failure light come on but the brakes really did more or less fail as I was pulling up to the hangar. I don't recall the last time a warning light came on in a car that I was driving and it actually meant something specific was wrong.
  12. pgarossino
    pgarossino Formula Junior
    Nov 19, 2009
    307
    Houston Tx
    Paul G.A. Garossino
    I had this light come on in my 308. It was telling me the fluid was low in the master cyl reservoir. I topped it off and the light went out. BUT....where did the fluid go. About a week later I got my answer as just before a ride I noticed some fluid behind the passenger rear tire....yep, brake fluid. The pass rear caliper was leaking. I rebuilt all 4 calipers, it had never been done, and all is well now.
    Bottom line....don't ignore that light :)
    Paul
  13. umsneeze
    umsneeze Formula Junior
    Nov 16, 2004
    449
    Knoxville, TN
    Don't ignore it. Mine came on (similarly hadn't noticed it had this light after 12 years of ownership). Had a nice drive, parked it for a few weeks. Started it up, light on. Pass side rear caliper leak. Everything rebuilt, lines and calipers.
  14. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Straight soft copper is a definite NO NO, and always when flaring, use a double flare. I did a Google Search and found the following:
    The soft copper tubing you can find in the local hardware store would be deadly if used in hydraulic brakes. Don't use it.
    There is a modern brake line that is a copper-nickel alloy that has a copper look. It is apparently used in some high end cars and some imported cars. It is fully certified for use as a brake line and you should be able to find it at a good brake supply company.
    You use the same double flare ends on it that you would use on steel lines.
  15. Ehamilton
    Ehamilton F1 Rookie
    2,633
    Durham, NC; USA
    Eric Hamilton
    Brake line repair made easy. Where to buy brake line, fuel line, Brake line flaring tools, brake line nuts and brake line fittings, for example.
    it's a bubble flare, not a double flare, on the 308.
  16. Crallscars
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
  17. pshoejberg
    1,818
    Denmark
    Peter H
  18. Crallscars
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Hey, it's only brakes, all they do is slow you down.............
