My car is running great - thanks for the help | FerrariChat
Discussion in 'Technical Q&A' started by Sean F., Apr 4, 2004.
  1. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    Thanks to all who offered advice, etc. while I was doing my 30K service, and to those whose post's I found in the archives that helped me get this work done.
    The car is all done and runs FANTASTIC. Actually better than when I started b/c the carbs were not quite right when I bought the car.
    Just to note, the following was done over the last two months..
    New timing belts
    New tensioner bearings
    Old Fuel lines replaced
    New water hose
    Reset timing to 7°BTDC
    Synchronized Carbs (wow, what a difference that makes!)
    Lots of cleaning
    The only thing I did not do was replace the seals b/c they did not leak (and still don't after ~ 50-miles).
    The worst part was taking the A/C out! Everything else went pretty smooth.
    A friend helped me with the carbs today and after about 2-hours it ran really smooth. Pulls nice all the way to redline and does not stumble at all when cruising in 5th and flooring it.
    It's amazing how big the smiles are when you do a job like this and it all comes out right in the end.
