My car sounds like a Cement mixer! | FerrariChat
Discussion in '308/328' started by Anthony bentley, Mar 17, 2010.
  1. Anthony bentley
    Anthony bentley Formula Junior
    May 20, 2006
    560
    London
    Anthony Bentley
    My car sounds like a cement mixer its coming from the belts side i'm hoping to inspect tomorrow. Any ideas? Anyone?
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    Cement mixer = cam drive bearings.
  3. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    Can i lubricate easy or is it a case of replacing?
  4. Tony K
    Tony K Formula 3
    Jun 7, 2006
    1,778
    Tony K.
    Can either of you elaborate on "cement mixer"? :)
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    Sadly if I am correct they will have to be changed....
    Have a look, I can be wrong!
    Other candidates:
    Air conditioning compressor
    Alternator
    Water pumps
    Alternators normally ignite the dash light when they fail, and I have had water pumps go to siezure with out much noise.....
  6. BigTex
    79,386
    Houston, Texas
    Bubba
    "rocks in a bucket" sound.....
  7. Tony K
    Tony K Formula 3
    Jun 7, 2006
    1,778
    Tony K.
    Got it -- thanks. :)
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    How about timing belt tensioner bearing?
  9. Maranelloborn
    Maranelloborn Karting
    Nov 16, 2009
    227
    New York
    Remund
    #9 Maranelloborn, Mar 17, 2010
  10. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    That would have been my guess too - also a lot less hassell to replace
    If you are really lucky, it will be the ac tensioner, then the water pump.
    Don't drive it any more - if it is the drive or tensioner bearing, a failure could hose the engine.
    good luck,
    chris
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    A failing tensioner bearing "squeels", the balls are not big enough to "rattle"......
    That would be happy news though, if so.......
  12. Maranelloborn
    Nov 16, 2009
    227
    New York
    Remund
    #12 Maranelloborn, Mar 17, 2010
  13. BigTex
    79,386
    Houston, Texas
    Bubba
    Do they have A/C in England???
  14. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    We have at least one week of sunshine per year and i want to be ready for it!
    Its more of a mettalic grinding noise than a bucket of rocks than a sqeal.
  15. BigTex
    79,386
    Houston, Texas
    Bubba
    Whew! That's good news!
    I was definately afraid for you, what's the mileage on this one??
    You may want to check a pulley isn't rubbing on a coolant pipe or something....best of luck on "Summer"!!!!
  16. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,515
    Honolulu
    Kevin
    Scariest sound I recall from an engine was a water pump giving up the ghost.
  17. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    25,000 miles. The belts were changed just a couple of years ago, but whether he changed bearings etc i don't know.
  18. Glassman
    Glassman F1 World Champ
    I agree, the water pump makes the cement mixer noise also.
  19. Kevin Rev'n
    Nov 29, 2009
    24,515
    Honolulu
    Kevin
    That....and then there was the time my universal joint broke on my drive shaft on an MGB...upon acceleration!. This made a noise from the tunnel, which was right next to my hip, that almost made me give up the ghost! A great memory!
  20. jcinflorida
    jcinflorida Formula Junior
    Oct 24, 2009
    331
    Melbourne Florida
    Mine was making a chattering sound and it turned out to be the cam drive pulley as Big Tex said. I could see it through the wheel well. It was a failed bearing and it tore up the oil seal behind it so there was some leaking oil when the engine warmed up. Fortunately the timing belt did not slip or I would have really hated life. I had just had the timing belts
    replaced 3 months prior so it could have been bad luck or an over-tensioned belt. $1800 to
    fix and that included new belts again along with the pulley, bearing, and oil seal. Definitely do not drive or run the engine. Good luck!
  21. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    That looks painfully familiar.
  22. Davvinci
    Davvinci Karting
    Dec 11, 2009
    162
    California
    DavidoSpeedo
    Think that was an OPTION on most Euros, wasn't it? Like the right hand mirror was on a Porsche or Mercedes in Germany. Not sure about the mirrors on Ferrari's in Italy.
  23. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Anthony, try removing the AC pump belt and running the engine - see if it sounds the same. The later 308/mondial AC pump belt has some plastic cordage embedded in it and this breaks down over time and can make a heck of a noise - sounds like all the cam tensioner bearings are rattling and about to seize. I know this potential "fix" sounds a bit hokey, but it's worth checking.
  24. Maranelloborn
    Nov 16, 2009
    227
    New York
    Remund
    #24 Maranelloborn, Mar 18, 2010
    It may look a little familiar....
    Well I'm happy to say I didn't have to do the work this time, this was done by Verell and John Wise back in '04, you can follow the thread here, it's a good read....and should prove to be very insightful on the method used to tackle the repair. I personaly think if your in there replace all 4 drive bearings and have piece of mind. http://www.ferrarichat.com/forum/showthread.php?t=28437
    Please let us know what it turns out to be and share what you can, a video with sound would be great. I wonder if Cam Drive Bearing issues are more common on QV's just a thought.
    I purchased my car a Euro QV also, from the PO in Vegas 2 month ago, amazing car, Euro QV’s are the best 308s in my opinion, just look at the numbers..I do wish sometimes they had carbs though.
    Performance Comparisons
    Model 0-30 0-60 1/4 mile Top Speed
    308 GTB Euro 2.3 6.5 17.0 154
    308 GTS Euro 2.5 6.6 16.6 150
    308 GTB US 3.1 7.9 21.1 140
    308 GTS US 2.3 7.3 19.8 145
    308 GTBi US 2.5 7.6 22.6 140
    308 GTSi US 2.9 7.9 22.1 140
    308 GTBi QV-Euro 2.1 5.7 14.3 154.5
    308 GTSi QV-US 2.3 7.4 18.5 144
  25. ClydeM
    ClydeM F1 World Champ
    11,910
    Wayne, NJ
    Clyde E. McMurdy
    Mine sounded like a diesel truck & it was 1K miles after the major. The noise came out of nowhere when starting it one morning. I had it flat-bedded to a Ferrari shop. $1800???? I LIKE your mechanic. Mine was over $4K and the mechanic groused when I asked him to do it with engine in. My thread is in the archives somewhere.
