My crazy 348 clock...Ideas? | FerrariChat
Discussion in 'Technical Q&A' started by Husker, Jun 24, 2004.
  1. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,790
    western hemisphere
    Ever since I bought my 348 back in February, the clock just blinks "00:00". When I try to push in those tiny little buttons per the manual, guess what...NOTHING HAPPENS. Am I missing something here? I hate to push TOO HARD on the silly control panel. Thoughts?
  2. jkuk
    jkuk Formula Junior
    Nov 3, 2003
    259
    Wirral, UK
    John K
    husker,
    You may have already done this but you must use a very fine point to change these - right on the centre indentation
    A paper clip is ideal.
    Pushing with fingers will not work.
    JOhn
  3. resnow
    resnow Formula Junior
    May 21, 2001
    653
    North Carolina
    Bob Snow
    If a previous owner pushed the tiny buttins too hard, they may have gotten stuck behind the front panel. The rubbery buttons are actually separate from the switches which are part of a PC board. The only remedy in this case is to remove the entire unit and disassemble it unless you can maneuver the buttons back into position somehow without removing the panel. I removed and disassembled mine and in the process cleaned all the contacts between the multiple layers of PC boards. Both the clock and AC/Heat control unit now work perfectly.
    Bob
