My DIY Annual + Spark Plugs | FerrariChat
Discussion in '360/430' started by Eric C, Apr 5, 2017.
  1. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    #1 Eric C, Apr 5, 2017
    I decided to do the Inspections, Oil Change, Filters and Spark Plugs myself (I Just hit 30k miles). Everything looked good, but will need to change out the CV Boot heat shields at some point. They look a little weathered. Trying to decide if I want to do the F1 fluid myself. I hate bleeding brakes, so I’ll probably take it in somewhere.
    Oil change was fine, but I took a bath in oil. I tried holding a funnel under the rear drain but it just overflowed and pissed all over my face. Gross.
    Filters were a piece of cake.
    Spark plugs were unbelievably easy. Judging by the looks, I’m sure they were the original plugs.
  2. RedNeck
    RedNeck F1 World Champ
    12,587
    The CSA
    Me
    Good to see another DIY'er, and with you on brakes. Will probably do my fluids once my car is ready to come out of surgery but will probably still take it to a dealer for annual and a yearly check up with Dr. Leonardo
  3. bkthomps
    bkthomps Formula Junior
    Dec 22, 2012
    293
    i did a brake bleed on my cayenne and learned that a tool is needed to keep the ABS valves open to do a proper bleed, i wonder if ferrari is the same way, or any ABS car for that matter
  4. Eric C
    11,136
    St. Louis, MO
    Eric
    Well, the last time I did brakes was about 20 years ago when 2 people were needed and it was super messy. If there is an easy way to do it now, I'd love to try it!
  5. Skippr1999
    Skippr1999 F1 Rookie
    4,573
    For brakes get a Mitivac and shop air. Don't worry about ABS. Small amount of fluid. Just trigger ABS on gravel or leaves to mix with flesh fluid.
    Coolant get Airlift system to use with shop air.
    Both are super easy with practice.
  6. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    #6 ideloera, Apr 5, 2017
    Eric, can you please share the torque specs you used on the motor and transaxle oil drain plugs? The shop manual torque specs seem too high.
  7. Eric C
    11,136
    St. Louis, MO
    Eric
    I torqued them down to 30nm. Not much.
  8. scudF1
    scudF1 F1 Rookie
    2,919
    Long Island, NY
    Billy
    It's also a good idea to mark the plug for next time.
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    A faceful of oil. There seems to be a spaghetti western movie with that similar name.
  10. o31982
    o31982 Formula Junior
    Mar 18, 2012
    281
    Southern California
    nes
    Are you going to post a step by step DIY? Lol, or you're just sharing
  11. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    Thanks!
  12. redjeeper
    redjeeper Formula Junior
    Nov 4, 2003
    282
    Flowood, MS
    Anthony Griffin
    Daniel Hurlbert on Youtube has a good tutorial for changing the engine oil.
    https://www.youtube.com/watch?v=OujWNMpdvHQ
  13. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,620
    AZ
    Rick
    I just had a local shop do my oil....$440. I'll be doing it myself from now on.
  14. Eric C
    11,136
    St. Louis, MO
    Eric
    Yeah, my local exotic shop quoted me $1,300 for an oil change, spark plugs and air filters.
    Plugs - $80
    Oil - $100
    Oil Filter - $90
    Air Filters - $84
    Total Cost - $354
  15. Normal Guy Supercar
    244
    Austin, Texas
    Daniel Hurlbert
    I also managed to get oil splashed everywhere. That rear drain plug is huge and drains out about 7 quarts in 5 seconds. You pretty much need a high walled bucket or something similar.
    Sent from my Pixel using Tapatalk
  16. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,461
    On the Limit
    Dino
    Most owners hold out the service costs charged by dealers and shops as a badge of honor. I've had my CS since 2010, do my own work and frankly the costs have been more than reasonable as long as you are willing to get a little dirty! :)
    I will have to say that the immobilizer, clutch position sensor and the gearbox heat exchanger were 'challenging', but belts, fluids, filters etc are a cake walk.
