My easy Euro bumper replacement,not as easy as I had hoped | FerrariChat
Discussion in '308/328' started by Euro Quattro, Jun 13, 2009.
  1. Euro Quattro
    Euro Quattro Formula Junior
    Apr 20, 2005
    344
    Vancouver
    Kent
    #1 Euro Quattro, Jun 13, 2009
    Well I just got my new rear bumper this week from eurospares to replace my old cracked one. I was really pleased to see it’s a exact replacement for my original one, or so I thought….It appears someone has done some modifications on my old one and my quick replacement isn’t going quite so easy. It looks like it was modified to push it in further but the distance looks correct to me. Although I have not compared mine to other euro models, I like the way it looks like it is. Before I start cutting on my new bumper I would like to get a some opinions on what other 308 owners think.
    Should I cut out the new one so it will be in the same distance as the old one? or
    fab a new bracket moving it out about a 2 inches. Here are a few pictures of the old & the new, just curious if anyone has seen this done before on a euro model. Since I don’t have access to a welder and fab equipment im thinking im going to cut out the new one, but I hate doing it to such a nice new bumper. Thanks in advance
    Formerly Kents308
  2. Euro Quattro
    Apr 20, 2005
    344
    Vancouver
    Kent
    #2 Euro Quattro, Jun 13, 2009
  3. bigodino
    bigodino F1 World Champ
    13,198
    The Netherlands
    Peter den Biggelaar
    #3 bigodino, Jun 14, 2009
    See here for pictures of my Euro rear bumper:
    http://ferrarichat.com/forum/showthread.php?t=231461
    It seems someone has fabricated some extra metal strips on your bumper brackets. I would just cut those off*.
    edit: unless it's original on a qv (mine's a 1978 carburretor).
  4. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    Your original looks like a factory unit. If I had to guess, I would say that the new bumper you got is probably for an earlier model. Looks to me as though Ferrari may have added some additional structural integrity to the bumper later in the run, by making the reinforcement bar extend the length of the bumper. At this point it seems as though you may have 2 options: source out the original type bumper with indentations for the reinforcement, or cut off the reinforcement bar just leaving yourself with the 2 shock absorbers. If you go the second route, I cant see why your bumper would not sit in the same position as it does now. Also, there would not be much fabrication, just hacksaw off the bar(and paint up the bare metal edges) and you should be set.
  5. thecarreaper
    thecarreaper F1 World Champ
    18,128
    Savannah
    when i purchased my euro GTb QV QV, it came with an extra rear euro bumper, but it was cracked in half in the middle. i still have it and will take pics of it off the car, and of my QV for you.
  6. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    #7 airdelroy, Jun 14, 2009
    I have an 85 euro and my bumper seems to sit out a bit further than yours. However, I think it can be adjusted a little more in. I was out looking at it earlier and I dont recall that long bracket across the whole bumper. That bracket looks to be the reason for the cut outs.
    Aaron
  7. Euro Quattro
    Apr 20, 2005
    344
    Vancouver
    Kent
    Yours looks about the same distance as mine not being cut out. I am wondering if this was done to make the bumper stronger on the later models. When I ordered it, it was supossed to be for a 85 QV but when went to checkout it said it was for a 80 GTB, something to do with a part number change. I kept emailing them to see if I ordered the wrong one but they wouldnt respond,after 4 emails I gave up & it was at my doorstep. I kind of like the metal re-enforcement bars since the bumper is basically made of plastic. At this time I think I will make a cardboard pattern and cut the slots out. Im going to try a cut off wheel on my die grinder for cuttting in the sides but not quite sure on the bottom cut,I will have to think about that part. It looks like it was done with a grinder but knowing my luck I will slip and gouge it or something. I was surprised it was painted and everything.
    Thanks for the help guys..
  8. Euro Quattro
    Apr 20, 2005
    344
    Vancouver
    Kent
    #9 Euro Quattro, Jun 16, 2009
  9. BigTex
    79,406
    Houston, Texas
    Bubba
    Just watch your exhaust tips, that's the only trouble I see with having them too tight to the car!
    I have a ANSA like that on mine..
    But I agree, the US mounting hangs them out past the line in the bumper obviously intended to mate to the shroud lines...yours looks great!
    I also agree the bumper standards were advancing thru the years even in the Euro countries....no specific knowledge though.
  10. Euro Quattro
    Apr 20, 2005
    344
    Vancouver
    Kent
    Thanks for the compliment,I never thought about the exhast tips...glad you brought that to my attention. I will be very careful backing up,I can see where that could get costly too.
