My engine is in pieces! | FerrariChat
Discussion in '348/355' started by Nicksta, Aug 1, 2007.
  1. Nicksta
    Nicksta Formula Junior
    Sep 16, 2006
    535
    DC Ranch & NY, NY
    Nick Ingle
    ...because its in the middle of its 30k miles service. I checked in on the car today, but I wondered, while its torn down, is there anything specific I should check on? The heads are off, so can I see if my valve-guides are still up to par? Would it be obvious if they were not? My car is a 1995 with 32k miles. This is the second 30k mi service.
    I did see that my catalytic converters look good inside; my headers are good, my fuel rails look good, my water pump spins freely, and my fuel lines were updated. My plug wires on the 1-4 bank were not good and the spark plugs were shot - so that explains an occassional misfire right before the service. I was told that when they drained my radiator fluid, it smelled like a skunk and stunk up the whole shop. What's up with that.
    Thanks for weighing in - I figure while the car is in this many pieces, I might as well sort and upgrade everything.
  2. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    I have seen people add pepper to a cooling system to stop leaks, then when I come along to repair/replace the cooling system I found it smells the same too :p Maybe someone did the same to your cooling system at sometime?
    I have even heard people cracking raw eggs into there cooling system too but most common is pepper ;)
  3. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    Make sure they replace ALL the leads, and not with OEM. At $200 a lead it's a quick way to financial ruin.
  4. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    The heads are off for the timing belt change?? Is that normal, or were they looking into a valve guide issue??
  5. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,619
    The Brickyard
    The Bad Guy
    Since the heads are off, why not get a good port and polish job? At the very least get them port matched.
  6. Nicksta
    Sep 16, 2006
    535
    DC Ranch & NY, NY
    Nick Ingle
    The condition I saw the engine in was to have the cam covers removed (they are being powder coated) and the cam gear was open underneath. I could see between the cylinder walls and see the lobes of the camshaft. We're doing more work than the standard 30k miles service, but as long as we're in tear down, I wanted to check around. The leads are all being replaced and they are not OEM crap. If the heads were 100% off, what would it look like? I'm mechanical, but not that mechanical.
  7. ernie
    Nov 19, 2001
    22,619
    The Brickyard
    The Bad Guy
    If the heads were off you would be able to see eight pistons. Then you would be able to see the valves on the bottom of the heads when you turned them over, and in your case 20 on each head, or 5 per cylinder.
  8. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    yeah sounds like you just have the valve covers off...do post pics of the paint job before and after if you have them!
  9. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,053
    There is nothing wrong with the stock, factory oem spark plug wires (other than the outragious price!). They are made from Beru wire, with Beru connectors on each end. But you can order a set of replacements from www.kingsborne.com for $250 or so, and they use the exact same components.
    The problem is the enviroment where the wires are situated, all cramped in the valve covers, and it's hot in there!
  10. truman bond
    truman bond Formula Junior
    Sep 9, 2006
    321
    No, no, no PAP - you put the eggs in the petrol tank - all those amino acids make her go faster you know..., pepper is just for Friday nights
    ahem.
  11. PAP 348
    Dec 10, 2005
    100,224
    Pap
    :eek::eek: You would be shocked what I hear people using to try and reseal their radiators after ploughing through a pack of kangaroos 500km's from nowhere :D:D
    Araldite.....concentrated fabric softerner....bbq sauce....cooking oil and also free range eggs :p:p
  12. truman bond
    Sep 9, 2006
    321
    cool, just as long as they are free range or organic....
  13. PAP 348
    Dec 10, 2005
    100,224
    Pap
  14. ernie
    Nov 19, 2001
    22,619
    The Brickyard
    The Bad Guy
    Hay Pap,
    Is that the guy that torqued down your lug bolts?
    HAHAHAHAHAHA!
  15. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Sure was, only cost me a case of beer too :D:D
  16. truman bond
    Sep 9, 2006
    321
    Man, that is bad; I mean shouldn't a mod pull that? - I'm not sure I'll sleep tonight after seeing that. Even after typing this, the image is burned in my head
    sheez, so great therapy PAP - I get it, he didn't torque your lug bolts, instead a pro-active great way to take your mind off what happened to you and onto something far more stressful
    this thread should be a handbook for dealing with PTSD - commonwealth style...
    as in, you think that's bad, when I were a lad, we ate cold gravel... et al.
  17. 355
    355 F1 Rookie BANNED
    Jan 4, 2005
    3,643
    Toronto
    Frank
    Well he will never be in need of a bottle opener for those beers.
