My F355 2.7 problem | FerrariChat
My F355 2.7 problem
Discussion in '348/355' started by ahmadani, Jul 3, 2025.
  1. ahmadani
    ahmadani Rookie
    Aug 27, 2020
    16
    Kuwait
    ahmad awadh
    Hello
    I have problem my f355 2.7 engine not working I mean not starting
    The electric ok and the petrol ok
    But I can’t start the engine
    There when i try to start many time
    Exhaust make nose booooof sound
    some body said change the
    Camshaft sensor
    Any body face like this problem
    Let me know please
    What’s is the solution
  2. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    Do you have one camshaft sensor or two?
    Did this problem happen immediately after you did any major work on your car?
  3. ahmadani
    ahmadani Rookie
    Aug 27, 2020
    16
    Kuwait
    ahmad awadh
    My car have 2 camshaft sensors because my engine 2.7
    I make major service before 2 years
    And I use my car not to much
    Only 6000 km
  4. technom3
    technom3 F1 World Champ
    18,557
    Phoenix AZ
    Justin
    A video could help.
    Could be cams. Could be ignition related. Could be fuel pump
    Qavion likes this.
  5. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    838
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Are you confusing crank shaft sensors ? There are two at the front accessed from under the car .The connectors need to be clean , free from oil leaks . You have to remove a cover under the car to see them .
    First check the fuel pump fuses , relays …….then the immobiliser it sounds like a faulty immobiliser. From the info supplied thus far .
  6. Qavion
    14,259
    Ian Riddell
    #6 Qavion, Jul 4, 2025
    From engine number 38322, there was only one cam sensor, but thanks for the extra information on your car.
    I can't remember when the 2.7 switched to one fuel pump. Do you have two fuel pump relays and fuses?
    If no recent maintenance, then we can assume it failed spontaneously.
    By electric, I assume you mean "power". i.e. the battery is ok and things like headlights work (which rely on key power).
    There is no immobiliser on the 2.7 unless it is aftermarket.
    Mike Morrissey likes this.
  7. ahmadani
    ahmadani Rookie
    Aug 27, 2020
    16
    Kuwait
    ahmad awadh
    Thank you all brothers for answering
    Tomorrow I will go to check my car on garage they are trying to fix the problem
    They told me maybe the problem from camshaft sensor
    I will let you know the update for my car soon
    Qavion likes this.
  8. michaelz
    michaelz Karting
    Jul 7, 2017
    77
    Melbourne Australia
    When these cars get old the common problem is not the sensors but the wiring of the sensors. High heat in the engine bay as well as old Italian copper wiring being heat cycled.
    Anyway, you may want to look at the following:
    Cam phase sensors
    Crank angle sensor
    Ignition coils
