My F355 engine out service | FerrariChat
Discussion in '348/355' started by Zbaroom, Jul 26, 2014.
  1. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    #1 Zbaroom, Jul 26, 2014
    Just thought of sharing...
    I took my F355 to the local dealer here in Dubai for 80K service and cam belt replacement. after a compression test we found a leaky exhaust valuve in one of the cylenders. head is out and being reconditioned.
    so far they recommended changing :
    The oil heat exchanger
    Hydraulic cam belt tensioner
    Gaskets
    Water pump bearing
    Engine mounts
    Do minimum rust proving on the frame.
    I agreed after seeing the condition of these parts. And so far the cost is around US$8,500 ….. ouch
    Anyone's been through this lately? any other parts I should consider replacing now that the engine is out?
  2. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Hey Mate! Nice. Im doing all this myself at the moment in my shop here in Aus. Check the cylinder bores for any deep marks. Replace your cylinder head nuts,put at least 3 spot welds on the lower cam drive pulley fences on each side, pay the money to have them dial in your cams upon reassembly. Upgrade to hill belt bearings. Oh and service your alternator! All the best mate,keep us posted. love the pics too!
  3. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    Thanks Andy.
    the cylinder bores look good. Good point about the alternator.
    I didn’t get the spot weld purpose, can you explain? And why is Hills bearing better than OEM?
    Sorry about the questions but this is my first engine out service.
    I have read all that is out there about this and every day there is something new.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,495
    San Carlos, CA
    Mitchell Le
    Spot welding the fences keeps them from falling out and destroying the belts leading to a engine failure. Not a must but a good recommendation.
  5. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    Got it..... thanks.
  6. Andy 355
    Jun 2, 2013
    434
    Your welcome mate! Seems im doing the exact same job. repainted valve covers look stunning. Ive just done mine. Hill bearings are supposed to be superior and i used them in my build. Good time to look at your clutch,especially if its f1. Ive built a lot of exotic machinery over the years but the 355 is just my favourite!
  7. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    F1 !! no thank you.. mine is a manual.
    any pictures of the covers?
  8. Andy 355
    Jun 2, 2013
    434
    cool. 6speed here too! red with tan GTB. only way to fly!!
  9. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    Red and black ... Sport seats ... Enjoy
  10. phrogs
    phrogs F1 Veteran
    7,339
    Kzoo Michigan
    I'm in the middle of this right now. Heads are out getting redone at the moment.
    I am resealing everything and changing out the seals.
    I am also painting what needs refreshing, once I got into it more and more needs work so
    I'm down to bare bones now.
  11. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    Johnny,
    What other parts are you replacing?
  12. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    If it's $8500 with parts and labour you're getting a good deal.If that was in states or canada at the dealer im sure it would be $ 15k if not more.
  13. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    Good to hear.it is parts and labour for the work so far ... It might hit the 10 k mark
  14. phrogs
    phrogs F1 Veteran
    7,339
    Kzoo Michigan
    I have a 95 so updating the tensioners and the tensioner bearing brackets. I can't recall the name but in order to use the hill bearings I had to update them.
    Those are the big things I'm replacing.
    I am doing a lot more than a engine out service, I will be re-plating all hardware. Repainting the car because someone in the past painted it the wrong yellow. Also repainting the engine bay and the engine cradle all suspension so on. Car will be brand new when I'm done.
  15. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    Wow.
    I sure will be waiting for pictures.
    good luck.
  16. Steve Harkness
    Steve Harkness Formula Junior
    Jul 28, 2012
    448
    perth Australia
    steve Harkness
    Hi Andy. So what part of OZ are you in.
  17. phrogs
    phrogs F1 Veteran
    7,339
    Kzoo Michigan
    Yeah I really started working on it last month, slowly going as I have other cars to work on as well but I'll keep updating as I go.
    Btw I was going through Dubai quite a bit the last couple years when I was working in Afghanistan.
    If you ever come across some cars with issues like older Ferrari's or lambos like a countach I'd love to get my hands on one haha!
    Where is the shop located your using?
    I don't know the city very well just around the airport for the most part.
  18. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    I use the dealer here... check them out.
    Al Tayer Motors L.L.C., Official Ferrari Dealer in Dubai, United Arab Emirates.
    They are a fantastic Ferrari and Maserati specialists. they also do few more brands line Jags and others.
    The do a lot of classics including. i have seen an E-type, 512 TR and a 250 GTO in the shop.
    There are few collectors in Dubai with exotic collection that I just hear about but never seen.
    Never seen a classic lambo here.
  19. Andy 355
    Jun 2, 2013
    434
    Hi Steve! Im 2hours north of sydney.. :)
  20. Steve Harkness
    Jul 28, 2012
    448
    perth Australia
    steve Harkness
    Ah ok was hoping you where in the west but never mind. Sounds like you are pretty clued up on the 355 motor! Unfortunately everyone over here wants a kidney to work on these and I don't think they are that knowledgeable to be honest. You might be my new helpline when I do my major at the end of the year!!!
  21. Andy 355
    Jun 2, 2013
    434
    No worries steve,let me know if i can be of any assistance to you.
    Cheers.
  22. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    #22 Zbaroom, Jul 30, 2014
  23. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
  24. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    #24 Zbaroom, Aug 25, 2014
    My Baby is back today.
    purrrrrrring like a cat. I had the car for 3 years but never thought a major service could make a huge different in how the 355 feels to drive. very smooth very fun to drive.
    I have driven many cars in my life but a 355 is simply the most enjoyable ride ever.
    spent $20K for a major timing belt service, 50K service, cylinder 3 exhaust leak solved. heads reconditioning new parts here and there, oil/ water heat exchanger replaced, all sticky interior done (even the ones that are still ok) and body polish.
  25. F1moving
    F1moving Formula Junior
    781
    BUCKeYe!
    Marcus
    Love the red with black interior. Black ages so good.
