MY f355 F1 my car pulls oil from the actuator | FerrariChat
Discussion in '348/355' started by clk20000, Dec 8, 2012.
  1. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    Hello Friends, I've problems with my 355 f1 from 1998, when I stop running it, my car pulls oil from the actuator (through the outlet pipe).
    How can I fix it?
  2. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    You may just be dealing with an over filled F1 pump reservoir. The proper level is actually on the low side of the dip stick. These reservoirs do not like to be over filled.
  3. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    +1 I filled mine to the line on the dipstick and that was too much, caused it to overflow.
  4. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    level is ok!!! only leaks when car is stopped
  5. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    #5 Extreme, Dec 10, 2012
    Is it dripping from the actuator itself? Is it the little black tube attached to the actuator? If so then it is a common issue with the F1 system.
    It isn't a big deal and seems to occur when the temperature drops to 40 degrees Fahrenheit or less with mine. I do not know of any fix for it.
    The black tube is a pressure relief tube and apparently when the temperature falls a spring or seal in contracting inside the unit allowing for some fluid to pass.
