My F430 F1 Drops Out of Gear When Stopped | FerrariChat
Discussion in '360/430' started by KPete, Oct 3, 2025 at 5:30 PM.
  1. KPete
    KPete Rookie
    Aug 16, 2010
    43
    Pompano Beach
    Kim
    When the engine, etc. of my F430 is at operating temperature, it will occasionally drop out of 1st gear into neutral when waiting at a red light. Attempts to re-engage 1st are difficult, sometimes requiring that the engine be shut off and restarted several times. Most annoying (particularly for those trapped behind me), and my mechanic is warning that this may be a VERY expensive repair (and requiring used parts due to Ferrari not stocking many OEM components for the F430). We're now discussing a transmission swap to a manual 6-speed as a possible curative.
    The car is out of town, so the error code has yet to be pulled, but I'm wondering if anyone might have encountered a similar issue? The clutch is at 50% and the car has ± 24,000 miles under its belt. Any thoughts would be much appreciated!
  2. boostedt0y
    boostedt0y Formula Junior
    Dec 25, 2014
    831
    Bay Area, CA
    Have them check the line pressure on the trans. I had a similar issue on my scud and it ended up needing a new accumulator and actuator. The accumulator is relatively inexpensive so you could start there. Once I changed the two parts, I didn’t have any issues with the trans going into neutral.
