My Ferrari Mondial Coupe project ... | Page 2 | FerrariChat
Discussion in 'Mondial' started by effer, Sep 25, 2008.
  1. davem
    davem F1 World Champ
    10,209
    Stepford, Connecticut
    dave m
    Paul,
    Thanks for the compliment. As far as service costs go, id recommend you ask in the NY tri-state section for prices. Mine was done 5 years ago and i supplied the parts from T. Rutlands. Just a guess though i think the diffrence between a 3.2 and a T will be around $2500-3k for an apples to apples 30k service. YMMV
    The good news is there are plenty of good independant F shops here in this part of the world.
  2. effer
    effer Formula Junior
    Jan 6, 2004
    814
    near Montréal
    François R.
    Davem,
    your car is very nice! Unfortunately I am stucked on a red/tan combo, otherwise I'd be very interested to buy yours. I really appreciate your offer, thanks!
    About size of wheels I am tempted with:
    225 40 18 front
    245 40 18 rear
    assuming having the appropriate offsets. What would you suggest me?
    It will virtually keep the same overall circumference while increasing width of 2 cm ( i.e. aproximately a tad over 3/4 of an inch ). There is certainly enough room for, isn't it? I read that 8 and QV were originally equipped with 240 tires at every corners, so ...
  3. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Yes, without a doubt, your car is a fine example and I was so tempted. Only my fixation for a Nero Coupe prevented me from buying her.
    Anyone who is interested in buying Dave's car will be more than happy with their decision if they do. This is one where the car definitely speaks for itself. After slowly walking around it while listening to the engine’s smooth idle I already knew that a test drive wasn’t necessary. This car is that good.
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,178
    Dumpster Fire #31
    SMG
    all mondials have removable subframes, up to the 3.2 the engine and subframe stays put and you can do the major in a day, the t is longer by about 2 days. the cost delta is also about 3k more for the t. the clutch on the 8~3.2 takes about 4hrs start to finish, and there is no "goopy" flywheel to mess with either. the mondials also don't have saddle tanks so there loads of room in the bay to get work done. thermostat replacement is 10mins, water pump can be done in less than 1hr, the t is much harder for the thermostat and the pump? not happening until the motor is out.
    operating costs are higher for the t varient, it's just they way it is. but don't let it distract from the car, the t finally has the power the mondial always needed. if your not for originality adding boost to the early ones makes them scream!
  5. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    Please elaborate on "Goopy" flywheel. It was my understanding that a clutch change on the t is pretty straight forward. Unfortunately the clutch kit is about 4 times more expensive on the t.
    Thanks,
    dave
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Has anyone noticed over the past few years that Mondials, most especially the coupes, are slowly but steadily developing a very loyal following with more restorations and fan interest? It's becoming a unique Ferrari to have. Still not wildly popular, but certainly a growing following.
  7. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,683
    E ' ' '/ F
    Merritt Tockkrazy
    Could just be that y'all crazies are finding each other on the 'net...
  8. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    LOL, ha, LOL. You gotta be freaking crazy just to want to own a Ferrari, much less picking a model everyone one picks on. It's an adventure in confidence.
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Like I said... :)
  10. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,761
    US of A
    Michael
    #35 Michael B, Sep 28, 2008
    Well its about time!
    Ahhh yes. My plan... It is working! Said the mad scientist.
  11. randyleepublic
    randyleepublic Formula Junior
    Dec 2, 2007
    825
    Beautiful Reno
    The t has a "dual mass" flywheel. This means that instead of it being a lump of metal, it is a metal shell with two plates inside. The engine turns the plates, and the plates push on springs, very similar to the ones you see in most clutch disks, that push on the shell. The clutch is pressed against the shell and thus torque is transferred to the trans. Because of those springs inside the shell, t clutch plates don't have springs. Inside the shell with the plates and the springs is a special grease called Kluber. The grease keeps the plates and springs lubbed and quiet, as well as providing a balancing action on the flywheel's rotating mass.
    There are three Teflon rings that seal the shaft that goes through the tranny on its way to the flywheel so that transmission oil stays put. Those seals get tired - apparently no one ever bothers to change them until the damage is done - anyway, they get tired, allowing tranny oil to contaminate the Kluber grease. Once it gets contaminated enough, it loses viscosity and runs out inside the flywheel housing.
    In two days, I will be able to say how easy this is to repair. The parts were not costly at all < $100.
  12. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    I think you'll see even more interest in them now that there is another V8 2+2 back in the line up...
  13. effer
    Jan 6, 2004
    814
    near Montréal
    François R.
    Sorry for revealing my huge ignorance, but which Ferrari model are you talking about? The new California?
  14. judge4re
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Yep. It is the new Mondial. Regardless of what the Ferrari marketing folks would have you believe...
  15. effer
    Jan 6, 2004
    814
    near Montréal
    François R.
    #40 effer, Sep 28, 2008
    And what about wheels like these( I think they do preserve the spirit of Ferrari wheels of that time )
  16. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    why do you feel this is the case...i would think the coupes would rise in value because they are rare now
  17. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    I agree, only it is the "flash" Mondial instead of the classic that we adore.
    What I am saying is that while I am sure that driving a California would be a lot of fun, I don't like its styling at all.
  18. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    Both will, although perhaps the cabs more because people like to put the top down. If I had had a selection between a cab and a coupe when my Ferrari window of opportunity opened, I would have bought a coupe. But I didn't so I bought a cab. Still, I have to admit that when the weather and the road are suitable, there is nothing quite as pleasurable as rolling along in the Mondial with the top down. The rest of the time I wish that I had a coupe. (Bad weather - too hot, too cold, raining. Bad roads - too bumpy, too twisty.) So, a lot of the time I wish for a coupe, but every once in a while it sure is sweet driving the cab. Is the trade off worth it? I can't honestly say - that's a hard call, but the market says yes.
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    That is part of what I am saying.
  20. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,854
    Long Island, NY
    Sam
    Nice looking Mondi.
  21. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Well, we need to define "rare" since, overall, there were more Coupes produced, even if you exclude the Mondial 8 (of which all were Coupes).
    Numbers aside it is very apparent that Coupes are much more difficult to find and compared to Cabs rarely come up for sale.
    The following data is courtesy of NNO:
    http://www.ferrarichat.com/forum/showpost.php?p=137847617&postcount=92
    Mondial 8
    Production started: 1980.
    Production ended: 1982.
    Total production: 703, 145 RHD.
    Mondial QV
    Production started: 1982.
    Production ended: 1984.
    Total production: 1,145, 152 RHD.
    Mondial QV Cabriolet
    Production started: 1983.
    Production ended: 1985.
    Total production: 629, 24 RHD.
    3.2 Mondial Coupe
    Production started: 1985.
    Production ended: 1988.
    Total production: 987, 91 RHD.
    3.2 Mondial Cabriolet
    Total production: 810, 57 RHD.
    Mondial t Coupe
    Production started: 1988.
    Production ended: 1993.
    Total production: 858, 45 RHD (3 Valeo).
    Mondial t Cabriolet
    Production started: 1989.
    Total production: 1,017, 51 RHD (5 Valeo).
    Excluding the Mondial 8; Total Coupes: 3278, Total Cabriolets: 2588
  22. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    SO, why is it you rarely see a coupe for sell?...and that is why i thought coupes were rare...i am interested in a red coupe(first color choice, second black) 3.2 or t...and none that i have found...13 on ebay only 2 are coupes and one of those is an 8...none on autotader.com
  23. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #48 Wade, Sep 28, 2008
    As every Coupe owner here will tell you, "They're keepers!" I've been looking for a blk/tn for over two years, even offered a $1000 finder&#8217;s fee. During a brief lapse in determination (brought on by frustration) I whittled away my reserves on a few other toys including a new Ducati 1098S. During that time I missed out on CopterJon's beautiful car.
    But now I'm ready again :)
  24. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I may be wrong, but it's my feeling that Mondial coupes are much like 206/246 coupes, they have two fates:
    1. They are being held onto and cherished by appreciative owners
    2. They've already died from neglect and gone to the great winding road in the sky
  25. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    davem has one for sell thinking of going to look at it
