My FF PTU Replacement Experience | FerrariChat
Discussion in 'FF/Lusso' started by Scout123, Jun 9, 2025.
  1. Scout123
    Scout123 Formula Junior
    Nov 1, 2017
    574
    All,
    I thought I would start a thread sharing my experience in repairing the PTU on my 2014 FF with 40k miles. The trio of warning lights that don't go away indicated an looksie.
    I took my car to local independent Ferrari mechanic. Verified a failed PTU. My next decision was how to repair the unit. Following this great resource here, the fix was narrowed down easily to either Hollywood Mechanic in LA for a complete rebuild, or SS Autotech in Great Britain. Both shops were very responsive to my email questions and thorough in their responses. Both shops have done over 100 repairs so far.
    Here were my options:
    1. Have my mechanic drop out the PTU and ship it to LA Hollywood to perform the PTU rebuild and ship it back. Total Hollywood cost (not including shipping) was around $10,500. They required a $3150 deposit. (Note: I could have ordered their $2,750 repair kit and had my guy do it, but he did not want to commit the time to the job and correctly thought they would be much more efficient in hours they have done so many). I would also have the cost on my end of my mechanic taking unit out and putting it back in when shipped back. This will be $5-6k in my guess. While there, he will replace all belts, etc.
    2. Order a refurbished unit from SS Autotech, when received from them, send them back my broken PTU for credit. Cost in British pounds: 8,450 for the refurbished unit and shipping costs = $10,731. Plus, you pay them 6,000 pounds ($8190) surcharge. Once they receive your damaged PTU unit and confirm its a viable one for them to fix, the will refund the surcharge.
    Both explained in detail their repair process. Both are similar in most ways, and I felt comfortable going either route.
    I went with #1. Reasons: a lower cost, plus not having to deal with who knows what tariffs in what amount will be in play when this goes down. Both offered a 1 year warranty. My thoughts it being easier to get my car or PTU shipped out to LA if something comes up under warranty. Of course, #2 gets your car fixed quicker as you just bring it in when the PTU arrives from SS Autotech. Larger outlay of money, but you get a good portion back.
    My mechanic shipped out to Hollywood last week. Hollywood stated a typical turn around of 5 days (impressive). They received my PTU last Friday, and starting working on it over the weekend. See, my next posting.
    ernie, ForeverNA, Jim P and 5 others like this.
  2. Scout123
    Nov 1, 2017
    574
    Okay, so today is Tuesday. I received the following email from Hollywood after they took apart my PTU. I am proceeding with all the repairs they suggest in this email. My unit was in bad shape adding around $2,640 in additional repair costs. Hindsight, given how bashed up this one was, may have been more efficient going with SS Autotech unit since they replace a lot of what was torn up, but hindsight is 20/20, plus you don't know until you crack this thing open and start looking. I will follow their strict instructions on handling the oiler cooler, etc. when we do the reinstall. Lessons for everyone: Don't put off the very first warning lights on this PTU and don't top off hydro fluid to prolong addressing the problem. My opinion, if you have an FF that has not had its PTU fixed, do your best and just have it done preemptively.
    Okay, here is the email describing the carnage:
    "I took the PTU apart. I had mentioned to Brendan that in cases where the PTU fluid is continuously topped off and driven with the leak, the snap rings can break worse than when the initial signs of a problem (low ATF warning) and both tabs of the snap ring can break off and then they must be drilled out carefully to preserve the forks. In Brendan's PTU, two of the bushings had snap rings broken. One of the bushings had completely blown out all pieces of the snap ring and was floating free from the shift fork. On the other side of the same fork, the snap ring was initially missing one ear, but as soon as the tool applied some force to remove it, it came free from the rest of the ring. This required drilling it in half in the fork to enable removing and replacing the bushing. In addition to this complication, the metal pieces were found broken up and free floating within the PTU (see photos). The pump had to be removed to get the rest of the metal out and to be disassembled and inspected to ensure no damage to the pump (none found). This caused some of the metal to be chewed up by the gears of the 'pinion' and 'ring' of the unit. Also, a lot of the 'control' fluid was present and the unit must have been severely over filled (the entire side was black with oil leakage from the top breather and the top fork had metal covering it which is only possible if it was submerged in fluid; see photos). This 'control' oil is much thinner than the gear oil and further reduces the lubrication to the gears. These gear faces have signs of momentary high heat, but look and feel smooth enough to operate safely. We can add a gear spacing grease and assemble and spin the unit, then disassemble again to confirm this. I don't think that is completely necessary, though, as there are no rough, chipped or otherwise damaged parts of the gears. I would estimate proper filling with the correct gear oil will result in safe operation of the PTU. Continued oil analysis should be performed after 1000 miles of driving.
    As a result of these issues, there was a lot of metal free in the PTU. This covered magnets on the forks (used to sense position by the sensors, see photos) and also caused several bearings to fail. We always replace the axle bearing, this is included in the initial cost, but I see scoring on 2 roller bearings as well as pitting on 3 ball bearings and one angular contact bearing. The ring gear lock nuts are also not in the final torque position (as evidenced by the paint marks, see photos). It's recommended that these lock nuts be removed and the ring gear bearing be inspected for wear and replaced if necessary. All the bearings I can see right now are available, however, the ring bearing part number is hidden by the ring gear and must be removed to inspect and order a replacement.
    The prices of the bearings range from $34 to $85 each (of the 6 bearings I can see need replacement) and there are 3 hidden bearings that I cannot estimate cost on until they are removed. The shafts on two of the roller bearings must be removed and polished to remove the scoring that could damage the new roller bearing. This will be a machine cost of approximately $150 per shaft. The additional labor would be: 0.75 to remove and disassemble/reassemble the pump, 1.25 hours to remove the broken snap ring, 2.5 hours to replace the visible six bearings and to remove and install the shafts (to be machine polished), approximately 2 hours to remove the ring gear, inspect and replace the bearings that we cannot see. If he would like a gear face test with gear grease, it would be an additional 2 hours to apply the grease, assemble and disassemble to view the results.
    The clutch surface areas are clean and no damage has occurred to the driver side clutches. The passenger side clutches cannot be inspected without removing the ring gear (something that needs to be done) but most likely will have the same condition as the driver side as the oiling supply is from the same source.
    Given all of these details, I do believe the PTU will be repairable, however, extreme care must be taken to flush out the gear oil cooler in the car. This is something that will contain contaminated fluid that can disrupt the operation of the PTU. It is not enough to just pour oil through it. Heat and pressure from driving the vehicle will cause debris to be cleared much more efficiently. The car will need fresh fluid added, then driven 20 miles, then fluid drained/refilled, and this process repeated several times until fluid and the drain plug magnet come out clear. If this is not done, oil analysis results from future tests will not accurately show the health of the rebuilt PTU and the metal can cause continued wear or even loss of gears due to metal on the magnet on the forks.
    Please let him know of the increased costs and let me know what he wants to do. Everything has been cleaned and all the snap rings and bushings have been replaced (as it was on the schedule for the weekend). Bearings have been ordered (if he declines, we can keep in stock in case of future need) for visible bearings but ring gear needs disassembly approval before we can order those bearings."
    So in summary it looks like increased costs due to continued use of improperly operating PTU would add up to $2640 not including the ring gear bearings or the gear grease tests. This would include all the bearing replacement labor (including ring gear). Micah does think this would render an operational PTU that would still be covered under our warranty, given the gear oil cooler be cleaned out properly and an oil analysis showing that was clean and clear before leaving the shop and after 1000 miles of use can be provided.
    ernie, Caeruleus11, Phoenix1 and 4 others like this.
  3. Jaguar36
    Jaguar36 Formula 3
    1,076
    Cherry Hill, NJ
    Thanks for sharing the info! Interesting reply from Hollywood. Can you post the photos? How long between when you got the first warning and when you sent it out? Seems pretty crappy that they are increasing the price after getting the unit (and after already performing alot of work). Did they warn you about that ahead of time?
    Did you consider GTE Engineering at all?
  4. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,356
    The Netherlands
    @Scout123 Thank you for detailing all this. I can’t remember if you had been dealing with intermittent PTU errors which were solved with top-ups or not? Can you remind us when and why the additional oil was added to the PTU?
  5. Scout123
    Nov 1, 2017
    574
    In all fairness, they’ve never had a unit come in where so many parts were torn up like this one. So it’s not fair in my opinion to hold him to their prior estimate of this repair. Also, that’s always what it is, an estimate. They correctly qualify the estimate, not knowing exactly what they’re getting into but, or based on all their typical repairs in the past.
    GTE engineering had some bad reviews on this website.
  6. Scout123
    Nov 1, 2017
    574
    I’ve owned the car for a little over three years. I’ll have to check the exact dates on my records, but a little more than a year ago, I had a small leak coming from the drain plug for the PTU oil. At that time, I had PTU oil serviced when they replaced the drain plug. The hydraulic fluid was low at that time and they topped it off. I didn’t really have any other warning lights until this one came up.
    But, in hindsight, the hydraulic fluid that was MIA had to go somewhere. And where it was going was through the defective seals and into the oil.
    ANOpax likes this.
  7. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,781
    Weston, MA
    Paul
    Firstly, thanks so much for your detailed posts, very informative! It would be great if you could post the photos.
    I was thinking it may not have been any more cost effective with SS Autotech. Since your PTU was so badly damaged, they may not have given you full credit for yours.
  8. Scout123
    Nov 1, 2017
    574
    Yes, I agree about SS. Unfortunately, you just don’t know these things until the unit gets opened up.
    Caeruleus11 likes this.
  9. Scout123
    Nov 1, 2017
    574
    I will get some photos posted Tomorrow
    Tallman1 likes this.
  10. Phoenix1
    Phoenix1 Rookie
    Jun 10, 2025
    2
    Interesting that they claim yours was more badly damaged. Seems doubtful that if they’ve really done as many as they claim that yours was actually significantly more damaged than any they’ve seen.
  11. Scout123
    Nov 1, 2017
    574
    When I asked if this was one of the worse, here is what they said:
    Hello Brendan,
    I have seen ones with more damage due to improper assembly from the factory. In these cases something pressed or tightened inside the PTU had moved. Some of these issues caused damage to the internal passenger axle shaft and we had to have it turned and balanced and custom bushings made for it. That was the worst one I've had to repair. I have not seen one where two bushings have broken the snap rings completely like yours has. I have seen one where one bushing was loose, but the other side of it was still intact. As to the metal on the magnets, I have not seen one where the upper magnet had the metal powder on it like yours does. I have also seen ones with damaged clutches, and in your case, the driver side looks great with no abnormal wear. So I guess I've seen PTUs that required more work to repair. This one has the most use after the leak began, I would assume.
  12. Nospinzone
    Jul 1, 2013
    7,781
    Weston, MA
    Paul
    Interesting that a "John Smith" (much more creative than John Doe :rolleyes:), who joined FChat today, has a disparaging first post.
    Things that make you go hmmmmmm.
  13. Phoenix1
    Phoenix1 Rookie
    Jun 10, 2025
    2
    Sorry, didn’t realize that there was positive first post rule. Not even sure what you would be implying? That I secretly work for SS and am trying to slander my competitors? :eyeroll: I apologize for what my name is… but thank you for letting me know it was public, I didn’t realize that. Very welcoming community you’ve got here.
    I’m looking to get a FF, but want to know what the options are if there is a ptu failure. Just seemed odd to me that they did over a 100 and this would be the worse one when it seems like its pretty average usage.
  14. PTC
    PTC Karting
    Mar 30, 2010
    145
    Fairfield County, CT
    Peter Timan Clark
    #15 PTC, Jun 10, 2025
    For anyone who has read any of the FF PTU Threads from front to back knows we are all extremely grateful for Hollywood's postings on YouTube. There are more than enough threads that all boil down to that shift fork retainer circlip failing over time, and then we go grenade, and whether we cover it thru Warranty, thru Hollywood, thru Parkes Performance in Warwickshire UK, or thru GTE in NJ, we should all just please be respectful and learn as much as possible as these issues are sorted. As a pioneer in showing us more & more, thanks Hollywood for all your postings on YouTube. As a 5-year owner under warranty, I hugely appreciate your input and educational videos on these PTU rebuilds. TYVM, ptc in CT
    NbyNW and jblaw like this.
  15. papou
    papou Formula 3
    1,736
    plantation Fla
    daniel ross
    So very well put, Micha is truly one of the good guys we’re very lucky to have him.
    ernie and jblaw like this.
  16. Nospinzone
    Jul 1, 2013
    7,781
    Weston, MA
    Paul
    Hope this answers your question.
  17. m5rlz
    m5rlz Rookie
    Jun 1, 2025
    5
    On a current hunt for a lusso or FF a few option's on the market have had PTUs replaced within the last 12-24 months have you gotten any feedback that PTUs failing in different ways can risk further damage to the overall transmission? Is it better to buy a vehicle that had the entire trans swapped vs. a lower milage car with just PTU replacement /repair
  18. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,356
    The Netherlands
    Welcome to the forum.
    I see that you’ve asked this question twice but failed to receive a reply. I think it’s because your question suggests an element of confusion.
    To be clear; the PTU and DCT are completely separate transmissions. So the replacement or overhaul of one is completely independent of the other. Also, the failure of one will not impact the mechanical integrity of the other. But if you find cars with both PTU and DCT overhauled then that’s a bonus as you should be good for another decade of motoring.
    With that out of the way, when looking at FFs or V12 Lussos, the clear issue when considering the longevity of the PTU will be who replaced or repaired the PTU.
    Ferrari - will be prone to the same original failure mode as no upgrade takes place.
    GTE - they don’t tell anyone what they do so it’s anyone’s guess as to what they do. Reports on the longevity of their repairs are mixed.
    Simon Furlonger - they upgrade the seals and this seems to do the trick.
    Hollywood mechanic - he also fits upgraded parts and has been a wealth of knowledge and information on the PTU.
    Parkes/SS Autotech - they go to the trouble of manufacturing upgraded forks from forged billet which effectively addresses the original weak points in the PTU design. IMHO, this is the gold standard.
    Good luck with whatever you find.
    350MH83, Wazzer, papou and 2 others like this.
  19. m5rlz
    m5rlz Rookie
    Jun 1, 2025
    5
    Thanks for straightening it out and yes clearly I was confused as I thought they were interconnected in some way or within the same assembly...
    Much clearer and given thats the part most prone to fail I'll make that my focus far more than a fresh DCT box.
    Thank you again for taking the time to clarify
    ANOpax likes this.
  20. Scout123
    Nov 1, 2017
    574
    Update on my repair. Had to order more bearings, most of which are coming in next week. I believe all my bearings were pitted due to metal in oil. However, they are having trouble sourcing one bearing. Are supposed to continue search next week.
    picture of my pitted bearings compared to what they are supposed to look like.
    PTC, Nospinzone, NbyNW and 1 other person like this.
  21. phishgoldy
    phishgoldy Karting
    May 12, 2014
    115
    NYC
    I’m sure this has been discussed plenty, but I still cannot believe that Ferrari takes no responsibility for this obvious design flaw, or that owners haven’t organized a class action. Maybe not worth being black listed…?
    papou likes this.
  22. m5rlz
    m5rlz Rookie
    Jun 1, 2025
    5
    I guess I'm more shocked it wasn't fixed/ updated on the Lusso.... At the same time I think if you go through most platforms they almost all have an Achilles heal that enthusiasts of that specific platform had to deal with from HPFPs on N54s, Crank Hub on S55's, Mag ride/ sub frame on the the R8s, early 991.3 GT3 motors, Mclaren eating actuators, GTR and bell housing... It would be great if they addressed it with recall/ part upgrade but I won't fault them as if they're the only ones
    Good thing is its a known issue at this point and you either want the car and will deal with it or now know enough from the early adopters to make a decision based on personal finances.
    ANOpax likes this.
  23. Scout123
    Nov 1, 2017
    574
    They were able to source all the bearings at Hollywood mechanic. My PTU should be shipped back on Monday.
    NbyNW and Jaguar36 like this.
  24. Scout123
    Nov 1, 2017
    574
    Forgot to give total cost at Hollywood Mechanic. It was $10,281.77. Just a bit more than estimate due to excessive damage to other bearings in box that needed replacement. I will post my total cost from my local mechanic for removal and reinstallation.
    Also, for those of you who are doing the take and reinstall yourself, here are the notes from Hollywood on proper method:
    Micah said everything matches (except the one bearing that we are using a bearing where the calculated max rpm of the shaft it is mounted on, to be less than the reference speed) and look like it will be as good as new. He did want me to let you know, you will need to fill the gear oil, let the vehicle warm up, drive the vehicle at low load (never above 40% throttle and/or 4500 rpm) for about 50 miles (this will heat the fluid and pressurize the gear oil cooler), put the car back on the lift, and drain the gear oil and fill with new. This process may need to be done a couple of times. You will be looking at the drain plug magnet and cleaning it each time until you get a clean and clear plug. I would use the cheapest 75W90 limited slip fluid you can buy for this process. Once you have completely removed any debris or metal from the system (primarily the oil cooler as it is not here), we recommend filling the PTU gear oil with either Motul 300V 75W-90 LS or Red Line 75W-90. Make sure you do not use the Red Line 75W-90 NS for non slip applications. The synchros and clutches in the PTU are not yellow metal synchros and are designed for slip fluid. If you run the non slip fluid, you will get faults for clutch and gear engagement issues, especially when starting the vehicle already warmed up. Make sure to follow fill procedures according to the repair manual which is easily found online for $50 or less at a site like emanuals.com or ebay.
    We are including the new seals in the box for your shop to install if desired. They are easily replaceable in vehicle, so if you want to do it at a later time, you can, but it just makes sense to do them now. Make sure whomever is installing the o rings, especially on the solenoids, is careful to put them in the correct positions. The solenoids look the same but some have a yellow label and are on off control and some have a white label and are variable control. If mixed up, they will not work correctly. Also, O rings need to be in the correct positions and smoothed out. If they "roll" them into place, they may twist. We recommend you lubricate the solenoids with the DCT fluid, lubricate the o rings as well (all with clean fluid) and then spin the o rings once they are in place. This must be done to allow any twists and subsequent high spots to be evened out. At that time, push the o ring to the back of the slot (nearest the electro magnetic end of the solenoid) and make sure it sits flush against the back against that back edge. This will be a good indication if it has any twists and when it's being pressed into the valve block, they don't try to roll back, they will be up against the edge that they are pressed against.
    We recommend testing the gear oil after 6 months/1000 miles of driving to detect any bearing issues. Be sure to replace your gear oil every 3 years/12000 miles and always perform oil analysis (this should go for any oil you change except the PTU control fluid, as it doesn't do anything but control). Oil analysis is key to giving you the best chance of identifying component failures before they become un repairable. If you wait until you can hear the fault, most of the time it's too late for cheap fixes.
    PTC, ANOpax, Nospinzone and 2 others like this.
