My garbage disposal smells like a water buffalo died in it | FerrariChat
Discussion in 'Other Off Topic Forum' started by Bullfighter, Mar 30, 2010.
  1. Bullfighter
    Bullfighter Two Time F1 World Champ Lifetime Rossa Owner
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    I never cook, always run the disposal after pouring anything down there, never leave food in the sink, etc.
    But it smells. I've tried running Lysol through it, letting the detergent sit after I've cleaned the sink. Nothing helps. I bought a lemon, sliced that up and crunched in the disposal, didn't help for more than a day.
    I'm tempted to just replace it, or maybe live outside in a tent.
    Any ideas?
  2. Jedi
    Jedi Moderator Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,280
    Seattle Area
    Dave
    Just replace it - $100 at Home Depot - takes 1 hour at the most. Had the same
    thing happen here - stinky gunk gets trapped inside and never purges.
    Or just WAIT. And keep dumping baking soda down the hole.... it WILL go away
    if you do that long enough.
    Tents CAN be had for cheap, though ;) :D
    Jedi
  3. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    Run lots of ice thru it along with some water. It breaks up all the crud.
  4. Jedi
    Mar 18, 2008
    32,280
    Seattle Area
    Dave
    ...yes... but will it break up WATER BUFFALO????
    Jedi
  5. CAS
    CAS F1 Rookie
    Nov 6, 2003
    2,683
    San Diego, CA
    Clint
    Fill sink with hot water and lots of bleach, then take out the drain plug, turn on the disposal, and let it suck down the water until it is gone.
  6. Bullfighter
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    Will try this tonight.
    My weekend project if nothing else works this week.
  7. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    My understanding was that the ice sharpened the blades. No idea who told me that, that's just what I had heard.
  8. JAM1
    JAM1 F1 Veteran Rossa Subscribed
    Oct 22, 2004
    8,709
    FL, NY, and MA
    Joe
    We use a bunch of ice and bleach every month or so... seems to keep ours clean.
  9. CAS
    CAS F1 Rookie
    Nov 6, 2003
    2,683
    San Diego, CA
    Clint
    How would ice sharpen the blades?
  10. tx246
    tx246 F1 Veteran Owner Rossa Subscribed
    Nov 4, 2003
    6,670
    Texas
    Shawn
    The ice will sharpen the blades, but not much else unless there is something jammed in the disposal.
    Unless there is a specific reason you are saying the disposal smells, I would guess that it is a plumbing issue with something in the drain pipe.
    I have been building homes for a long time and literally dealt with 1000's of warranty issue, but never this. Have you checked the p-traps?
  11. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    I have no idea :eek:
  12. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The dishwasher (assuming you have one) typically discharges into the disposal. It's possible that the smell is from that hose. Run a load or two there (no dishes required), maybe add a little bleach to the water.
    No need to buy a new one, it can be cleaned.
  13. Bullfighter
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    Yes, it does discharge into there.
    Sounds like everyone here works for Clorox.
  14. Bullfighter
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    No. Does smelly crap accumulate in traps under the sink? Wouldn't be hard to check.
  15. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    If your drain is properly vented and the water drains quickly, the trap should be full of water (to prevent sewer gas from entering). It wouldn't hurt to check the trap(s) but if the drain is used frequently it shouldn't smell.
  16. GuyIncognito
    GuyIncognito Nine Time F1 World Champ Silver Subscribed
    Jun 30, 2007
    99,966
    This is Fchat. buy a new house.
  17. wax
    wax Five Time F1 World Champ Lifetime Rossa
    Jul 20, 2003
    52,426
    SFPD
    Dirty Harry
    Make sure Bleach has gone away . . . then:
    Step 1: Mix Baking Soda & Salt. Pour.
    Step 2: Pour Cheap Vinegar. Admire bubbly cauldron.
    Step 3: Pour Hot Water to rinse away [salt is corrosive].
    Cost: $3
  18. anunakki
    anunakki Seven Time F1 World Champ Owner Rossa Subscribed
    Oct 8, 2005
    78,999
    Las Vegas Nevada
    Jerry
    :D
    Best. Answer. Ever
  19. Bullfighter
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    I'm not moving. I have an In-Sinkerator 16M, which is 26% faster than plain model. Believe me, you'd notice the performance.
  20. GuyIncognito
    Jun 30, 2007
    99,966
    yeah....but the belt service is a killer.
  21. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    There is a tablet made to put down the disposal that will help break up the residue and deodorize it. Just drop in once a week and fuggit about it........Seriously, get some of these little yellow gel tablets and it should help. I replaced ours about two months ago and when I had the p-trap off I noticed it was pretty gunked up. But the disposal had not been changed in 20 years....
  22. Bullfighter
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    Once a week? How much residue could build up in a week?
    The bleach idea seems to have worked -- at least this morning I didn't notice any odor.
    We'll see if lasts more than a week...
  23. SrfCity
    SrfCity F1 World Champ
    Nov 1, 2003
    10,142
    Orange County, CA
    I just pour bleach directly down there and let it sit. Later run it with lots of water and that'll get rid of the smell.
  24. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    The once a week is to keep the smell down, not cutting down so much on the residue....Kinda has a lemon scent.
  25. CAS
    CAS F1 Rookie
    Nov 6, 2003
    2,683
    San Diego, CA
    Clint
    I am a disposal tech by day...
