My Mac Book Pro is slow? Any ideas on how to speed it up? | FerrariChat
Discussion in 'Technology' started by MVDESQ, Nov 27, 2014.
  1. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    My Mac Book Pro is running very very slow lately to do anything. Driving my wife crazy. Any ideas or programs to clean it up? Purchased new in February 2013. Here are my specs:
    13 Inch Mid-2012
    2.5 Ghz Intel Core i5
    4GM 1600mhz DDR3
    OX X Yosemite Version 10.10
    Thanks in advance.
  2. sf_hombre
    sf_hombre Formula 3
    1,352
    Stimulus Bill
    Don
    Replace 4GB ram with 16GB (about $200) and replace your hard drive with a 2 terabyte drive spinning at 7200 rpm (about $120). Both can be done at home in 10 minutes with a tiny philips head screwdriver. Do a google search on how. Buy from Amazon or other; no need to pay Apple prices.
  3. TheBigEasy
    TheBigEasy F1 World Champ
    Jun 21, 2005
    18,634
    California
    Ethan Hunt
    This
  4. enzo thecat
    enzo thecat F1 Veteran
    5,824
    Midwest
    Enzo Thecat
    Yosemite really seemed to slow my machine down. Until then, it had been running like the day I bought it.
  5. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Is that 2 8 gb chips? If so, looks like $151 bucks at Bestbuy. I presume I have 2 2gb chips now? Sounds good.
    Any software programs I should run to clean up or are they gimmicks?
  6. NousDefions
    NousDefions F1 Veteran
    Nov 7, 2009
    7,635
    NC
    Brian
    Go to the spotlight search (the magnifying glass on the upper right corner), type "disk utility."
    Click on the main hard drive.
    Run "repair permissions."
    Then run, "verify disk", followed by "repair disk" if necessary.
    Virtually all speed problems on Macs boil down to bad sectors or permissions, which can be fixed with the disk utility.
  7. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Thanks that was a good idea. I had tons of permissions issues.
    Matt
  8. sf_hombre
    sf_hombre Formula 3
    1,352
    Stimulus Bill
    Don
    Yup, 2 8gb chips. Make sure the ram chips run at the same speed as the ones you're replacing and that they have the same number of pins. Simple enough.
  9. M. Brandon Motorcars
    Sponsor
    Sep 4, 2007
    1,830
    Houston, TX
    Michael Foertsch
    Also check Activity Monitor to make sure you don't have rogue processes/daemons running that are sucking up CPU.
    For example, as much as I love Google Drive, it does use up quite a bit of CPU when syncing. Same for Crashplan (which I also love).
  10. NousDefions
    Nov 7, 2009
    7,635
    NC
    Brian
    If you don't have an SSD, that is the single fastest upgrade you can make. Sorry, but you won't see THAT much improvement with more RAM unless you are running very RAM intensive programs. I run two web browsers, a text editor, accounting software, Photoshop, Illustrator, anti-virus, a proxy internet client, an FTP client, and stream HD video simultaneously from my mid-2013 Macbook with 4GB of RAM with zero issues.
    You can get a 500GB SSD on Amazon right now for under $200 (Crucial brand), which is the best price yet.
  11. sf_hombre
    sf_hombre Formula 3
    1,352
    Stimulus Bill
    Don
    Seems like that would be faster, but 500gb is not enough primary storage for me, and I don't like traveling with external hard disks that add more.
  12. zygomatic
    zygomatic F1 Veteran
    5,062
    Washington, DC
    Chris
    If your MBP has an optical drive, consider swapping it out for either a SSD (for booting and loading program - you'll see real speed improvements) or a larger HD (non-SSD) if you're after a ton of space (and already have a SSD for booting). There are a few kits out there that make swapping easy.
    FWIW, my mid-2008 MacBook with 8GB of RAM and a 60GB SSD handles Yosemite well. Boot-up slowed a little over previous builds, but other than that it runs nicely.
  13. NousDefions
    Nov 7, 2009
    7,635
    NC
    Brian
    That's a lot of storage needs! You must do a lot of video editing.
    They make zippy 1TB hybrid drives that work pretty well. It is a good balance. There are 1TB SSD's out there, but they are in the 400 dollar range.
  14. sf_hombre
    sf_hombre Formula 3
    1,352
    Stimulus Bill
    Don
    Nope, no video editing, however the docs in some of my cases (I'm a lawyer) can get as big as 80gig (Some defendants think they can hide the golden pony in a mountain of horse poop).
    I recently moved up to a 2TB drive as my primary in the macbook pro so I don't have to worry about shuffling directories to other disks.
    Good thing the bigger drives aren't heavier than the smaller ones!
  15. Innovativethinker
    Innovativethinker F1 Veteran
    9,840
    So Cal
    Mark Smith
    Then you need to buy a SSD drive, and probably more memory.
  16. becker
    becker Formula Junior
    Feb 20, 2001
    340
    Arlington VA
    Becker Cuéllar
    Try the software hints 1st if this doesn't do it then go with memory/hd upgrades
    Check there are no unneeded programs running in the backgruond in your login
    System Prefs>Users&Groups>loginItems highlight and delete
    try this too
    6 Easy Tips to Speed Up OS X Yosemite on Your Mac
  17. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    These look good I'll try them soon. Thanks.
