My "New" 348 Still having issues | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by traimpz348, Jun 29, 2005.
  1. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    It means Lord Lucas is ALIVE!!! But that's usually temporary.
    Ken
  2. indytech
    indytech Guest
    May 24, 2006
    143
    Winchester Ca.
    Ken
    My 1-4 light was comming on every so often then going out intermentaly. I discovered my water level was low. Filled it up and the problem went away.
    I highly recommend, if you havent do so, doing belts and hoses, going thru the complete cooling system. Once you are certian you have a good timing belt, water pump, and no leaks, these cars are pretty difficult to screw up in a major sort of way. Sounds to me like you have just a few little things wrong with it.
    I've just had min about a month. I intend to go thru it from top to bottom, starting with the timing belt and cooling system. These cars in my opinninion are a phonimal deal. But the rality is if you intend to own a race car, (even a street legal one), then you can resonably expect to work a little harder to keep it right.
    Indy
