my new ABS kit in my F40, and more things | Page 2 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by cirugiadigestiva, Nov 16, 2014.
  1. cirugiadigestiva
    cirugiadigestiva Formula Junior
    May 2, 2010
    357
    ibiza
    francisco vilas
  2. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    #27 cirugiadigestiva, Nov 30, 2014
    some pictures, the roberuta system are ready and work perfect, I can,t show you the video because I don,t know how I can do this.
    the ABS system are ready also and check.
    the setup, are ready the repartition of weigh,s front and rear are exactly
    Now the car go to the power bank to install the new motec ECU, and increase the power, until?
    520/530hp? I don,t know..........
    I explain you again and show more results
  3. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
  4. Arjun
    Arjun Formula Junior
    Feb 26, 2006
    330
    Francisco, is the weight with fluids? My US spec car weighed in at 2,650 lbs dry and 2,899 lbs wet (with full tank of gas), and that was after taking out the heavy stock exhaust and cats. Anyone know which pieces of additional safety equipment accounts for the 250 lb weight difference?
  5. sherpa23
    sherpa23 F1 World Champ
    10,019
    Rocky Mountains
    Bastuna
    Yes. The majority of the weight difference comes come a few places. The front crash box of the US car is a different shape and made of heavier Cromoly steel. The rear bumper is significantly heavier as it has a huge steel beam in it whereas the Euro cars do not (The whole rear of the frame is different so that it can take this bumper). Also, the rear floor is metal and the Euro cars without cats have carbon floors. That's a chunk right there.
    If you take a US car and complete restore it using all the new parts from Classiche, including all of the new carbon fiber body panels, you can end up with a significantly lighter car. How much lighter exactly? I'll tell you soon.
  6. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    #31 cirugiadigestiva, Nov 30, 2014
    or friend from colorado give us a perfect explication, and yes the car are full liquids, and 75% gasoline
    and please explain us how, we can ligther my car. with installation tha ABS system and the roberuta kit, but with the ionli battery, we loss only 5kg.
    please explain us.
    in my car I don,t have a OD exhaust, I don,t have also cat,s, my floor is is carbon
  7. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    #32 cirugiadigestiva, Nov 30, 2014
  8. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
  9. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    Next Friday 12 December in montmelo spain test drive in a track day, to check, ABS and Roberuta system, we are very very happy, the Firts test in open route are fantastic,s.........
  10. sherpa23
    10,019
    Rocky Mountains
    Bastuna
    Francisco,
    I sent your mechanic an email with info that he requested. If you don't get a satisfactory response from the people I put you/him in touch with, let me know.
  11. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    Thanks for every thing we contact you again soon
  12. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    hello the test in open route go perfect,s, the filling is the stoping power are more or less a double ad before, and we don,t losse the rear in the intensive stopping
    the positions of the roberutas are also finded, I,m very vey happy with the results, to drive the f40 is now more sure and funny.
    ad are possible I will show you videos with the driving with and without the system
  13. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    Hello today we test the car in montmelo, the enginer Mr solo do a many tours, to finish the positions of the suspensions, and the programmation of ABS.
    I can drive the car 13/14 tours, puf complicate in my bad English to explain I can find in my dream car, perfect, the stability is really upgrade with the Roberuta, but the brake power and the friability in the stopping are perfect, my car is perfect I, M really happy happy with the results, my car is a best f40 ever.
    I wait nervous next month's the ASR.......
    Now in Spanish, el coche es perfecto, increíble como frena como se aguanta, como se puede dirigir y sobre todo cundo entras pasado frenas sin piedad y nada pasa más que se para y se para sin perder nunca el tren trasero estoy emocionado y sin duda he hecho algo increíble en mi coche.
    Lo recomiendo sin duda
  14. amenos
    amenos Rookie
    Aug 20, 2014
    15
    Spain
    Jordi Amenós
    Hello everyone, i will introduce myself, I´m Jordi Amenós (D-SOLO).
    I recently made all the improvements that mr. Francisco wanted to incorporate into your car, Ferrari F40. The first step was installed a complete system of ABS and full ROBERUTA Suspension kit with lifting system. The process has been very hard and demanding as it has analyzed all the details of the vehicle's weight distribution, the suspension geometry, etc.
    After installing the kit of ABS, was made the first tests to calibrate the system, verify stability, system integrity, possible failures and capacity of reset from fault mode. The ABS system includes 9 different sensitivity maps, that adjust to perfection 3 modes which I believe are sufficient (WET, SPORT/STREET, RACE) to use into the car with total security and maximum performance.
    Last Thursday, December 18th, we had the opportunity to try the car in the circuit for test the new ABS system and ROBERUTA suspension in the circuit of Barcelona (Spain), the same track that is used in F1.
    Believe me, the first contact of the vehicle in the circuit has been spectacular, the car is absolutely stable, fast and predictive. After performing the first turns and to analyze the operation of the ABS system and suspensions, i will explain my first sensations.
    During the first run, I checked able to grip limit, the tuning of the ABS, and have defined the 3-position system working , remember, (Wet, Sport and Race)
    Run 2; the objective is to setup the suspension, always thinking that the vehicle will be used on the street and sometimes in the circuit (Trakdays). I changed the front suspension setup (Rebound) to improve the response of the front axle.
    Run 3, the vehicle, now has a very fast response of the front axel, and this can produce an instability of the rear axle at grip limit conditions or low grip, I modified the toe setting of the front axle, and after several laps, I think now we have a very good car to enjoy safety in the street and on the track.
    Mr. Francisco, has tested the car for approximately 14 laps ..... the best of all day, is look when it arrives at garage Mr. Francisco driving his F40, look at his face and receive warm congratulations for all the work done on your car.Amazing, awesome!!
    The next step is to install an engine ECU Motec, improve engine management map and design a map traction control (ASR). With this option, I'm sure we'll have a perfect car for all conditions, can enjoy F40 as this driver assistances that have been installed, we guarantee additional safety, allowing us to at all times when driving on the street, in the circuit, etc., that you can feel within us the spirit of Ferrari Cars. ... without having to worry about anything that might distract us from our greatest moment ......, drive our F40.
  15. jvecchi
    jvecchi Formula Junior
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    Very interesting. Thanks for sharing your progress.
  16. omd78
    omd78 F1 World Champ
    Dec 26, 2005
    13,252
    Breda, Netherlands
    Martin
    Thanks for posting gentlemen!
    Gr. Martin
  17. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    mr solo, is a great enginer and his work in my car is absolute profesional, now to drive my f40 is funny and absolute more secure. For the purist, only a very very expert eye can see the modifications, and it,s possible to put off to recuperate the authentic f40, but one thing, when we drive some km with the new system, any people can like to back to origine car is more fast, and absoluty more secure.........
  18. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
  19. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    Next date, 12 janury we install the new Motec ecu, I will show you the bank power results
  20. philipd385
    philipd385 Karting
    Jan 26, 2009
    61
    What wheels are on your car? They look much bigger than standard but still keeping close to the original shape?
  21. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    Yes the idea is to conectec the motec ecu with the Bosch ABS to used the ASR system for the moment the result with the ABS system and Roberuta suspensions are fantastic.
    Our idea also with the new ecu is to win some hp to arrived more or less 520/530 hp
  22. cirugiadigestiva
    May 2, 2010
    357
    ibiza
    francisco vilas
    The wheels are from braid wheels 9x18 front and 11x18 rear....
  23. sherpa23
    10,019
    Rocky Mountains
    Bastuna
    I think you mean 13x18 for the rear...
  24. Garretto
    Garretto F1 Veteran
    Sep 3, 2003
    5,079
    Bilbao, Spain
    Rodolfo Di Pietro
    Thanks for sharing Francisco, you are very passionate about this hobby of yours, and that's the greatest part!
    Two comments as a casual reader: I don't like the wheels much, I would prefer stock or OZ/Enkei. And the suspension looks a bit high for a race track, I would suppose it should be lower?
