My poor neglected 360 is in a very bad mood:( | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by ByeFcars2, Jan 29, 2015.
  1. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    "Here are the chain of events this morning: I had left the battery (new one) disconnected for all the time the car was parked."
    How was your hired hand expected to run the car if there was no battery connection ? Was he aware it was his responsibility to connect/disconnect on his monthly visits ?
  2. thibaut
    thibaut Formula Junior
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    I was forced to store a car of similar age (993) for 16 months. Actually restarting was fairly straightforward. I did not have the issue of immobiliser though. But my experience suggests that:
    1) The engine has no problem starting on a 16 month old fuel. Of course you will need to drive the car to a petrol station and fill up with new one but that works
    2) tires do flatspot even if I left mine overinflated. I also noted that if you put heat back in them they usually come back to their normal shape quickly (after 10-15 minutes)
    3) The brakes will feel funny like dead pedal. After a few heavy brakings, it usually goes away
    4) Yes the car is due for a service, but wouldn't necessarily get it towed to a deal (unless the car has 5-6 years old oil in it)
    5) sticky parts: normal ferrari interior aging process, unfortunately. the top soft plastic coat is not stable and will go off, just a matter of time. You should search for 'sticky no more' he will sort you out.
    In other words, once you get your eletrical issues sorted and the car is started, you probably can just fill it up, wash it and book a full service. While I would not take the car on track as is, I think its fine to drive around at normal speed.
  3. ByeFcars2
    ByeFcars2 Rookie
    Sep 24, 2010
    20
    thibaut, thank you very much for sharing your experience with your car. I very much agree with you that I should have no problems in driving this car once I get it up and running and a full service done. This car has been amazing to me, and except for one weird episode once in Germany with the transmission (that was fixed thanks to great advice from some members of ferrarichat), it has been absolutely a reliable and dependable car in every way, under any weather and road conditions and everywhere. I very much love this car and have no doubts about its reliability overall. Except for minor issues that every car of every brand has once in a while, I find the reliability of this specific model car very high. And in my case, if it was not for the immobilizer issue, I'm sure the car would have started almost immediately. Even the tires still have air, nothing really to be done except a new battery and of course a service and major detail afterward. I am just eager to be able to sort out the issue of the immobilizer that has gotten me totally stuck at this point. This morning I have tried several new tricks and attempts with the alarm remote and the immobilizer all of which have resulted in nothing. I am more and more convinced that I may have fried some sort of a relay, or fuse, or wiring somewhere as it all was working before I tried to start the car with a low battery. In fact, if anything, it's probably more my fault than the cars fault. I know perfectly well not to insist on trying to crank a car up with a low battery knowing it will infuse throughout the electrical system quick spikes in power and voltages. This is always never a good idea.
  4. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,229
    Georgia
    Wade Williams
    Have you tried using the key cycle disarm option?
    You need the secret 4 digit code for your car. Do the key cycle and try to start the car. I have had a couple of cars that won't start with the key FOB. Some have started with the code and some were just had a totally dead alarm ECU. There is a key FOB relearn procedure if it starts with the code.
  5. ByeFcars2
    ByeFcars2 Rookie
    Sep 24, 2010
    20
    Thanks Robz328. Ill carefully pull all the fuses one by one, inspect them, clean the terminals and replace any blown one. Ill also take the relays out,clean the contacts and plug them back. I wish I know which fuse is the one related to the alarm/immobilizer so i can immediately check it first.. but I have no idea which one it is..
    Thanks much for the tips F355steve. You are right and I plan to add a couple gallons of fresh gas and mix it a bit before trying to start the car. I do think the car will start. Ive always had luck with this car and has veer really failed me in any situation.
    As for the sticky parts I really didn't know cleaning them by rubbing them well with alcohol can do the trick. I thought that would smear the gunk and make it even worse. I remember a few years ago trying to clean some very sticky parts and also the large vent plastic grill on the base of the windshield inside on my beloved 348tb (gosh I miss that car so much) and I made a mess of biblical proportions. That was the last time I ever attempted trying to touch or fix anything sticky on F car.. but Ill give it a good try again now on the 360. The problem is some of the parts like the door handles will need me to disassemble part of the door trim which I have no idea how to do.. Ill try it:)
  6. ByeFcars2
    ByeFcars2 Rookie
    Sep 24, 2010
    20
    foatech thanks for the insight. I have no idea what the secret 4 digit code for my car is. Where can I get? From the original dealer in San Diego it was bought from? Thanks again!
  7. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,705
    South East
    Jimmie
    Its on a piece of paper that looks a little like how you receive a bank card pin but also has brief details of your car - there are many threads describing procedure etc in detail
  8. davebuchner
    davebuchner Formula 3
    Jun 1, 2005
    2,487
    London UK
    Dave Buchner
    Sorry to hear that - but I am sure she will be cleaned up and running again in no time
  9. ByeFcars2
    ByeFcars2 Rookie
    Sep 24, 2010
    20
    greyboxer, thanks much for the tip. Let me get into it and search!
    I have started to clean up the mold inside first of all because I cant be sitting on the seats and touching things with all that stuff everywhere. So far, comes out fairly well. Some spots with heavier mold have a slight change of grey on the dark leather but I think, once I am finished, a proper conditioner will smooth out and re-moisture those areas.. at least I'm hoping..
    I have made several new attempts of resetting the battery and multiple presses on the remote with fresh battery (both of them since I have two), and no success. I have noticed that the little LED on the dash associated with the alarm on/off, now is always off. I remember when I first connected the old battery and tried starting the car unsuccessfully because of the low power, the led was blinking while the immobilizer was on along with the proper chirp sound and unlocking of the doors, all of which now is non operational. I suspect therefor more and more of an underlying electrical problem not feeding current to any of the alarm/immobilizer circuitry, fried during the several attempts of trying to start the car with the old battery that had not enough power.
    Many years ago I remember helping a friend with an Acura NSX (lovely car) that had a low battery and he did the same.. insisting again and again to try get the car started with a battery that had not enough juice. By the time we went to a local PepBoys to get a new battery and installed it, half the electrical system of the car was massively grilled. From the stereo to the electric windows, door locks, stuff on the dashboard, and issues on the ECU, it was a generalized massive destruction. So I should know better than trying to do the same a over a decade later with my car. I painfully recall the bill he got to get the car repaired at the neighborhood Acura dealer.. the cost was "Ferrari" style along with having to replace the complete factory radio/Hi-Fi unit assembly that "was not repairable". He sold the car shortly after that and never swear never to buy another Honda/Acura.
    Im keeping my fingers crossed for issues at the level of relays and fuses which is what Ii will check thoroughly next. The nightmare scenario of a major electrical mishap due to my negligence is too daunting for me to face..
  10. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    921
    Georgia
    Mark Gronsbell
    I strongly suggest that you follow the advice of the Ferrari master technician first and the recommendations of the well meaning amateurs later. I know Wade and it is most kind of him to donate his time and advice to the forum. FWIW his knowledge and expertise are outstanding.
  11. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    + one on the above, every time I try to "fix" something I know nothing about .... It just gets worse.
  12. ByeFcars2
    ByeFcars2 Rookie
    Sep 24, 2010
    20
    Understand. The only issue is Hong Kong (where the car is now is NOT like the US. There is ONE dealer in all of Hong Kong, with people not particularly helpful or in any way service oriented.. not to mention they speak near ZERO English. The mistake is the car being here. I tried to have 1 technician from the dealer come to my location to try diagnose the problem without my car being dragged there as I do think this is not a major issue.. not only I got a fat quick "no" (no matter the pay I offered for such) but I was only offered that they tow the car there under their conditions. I am on the other side of HK Island, its a 45KM haul across New Territories in Kowloon, then cross the ocean, then cross HK Island and then into Aplei Chau, on the other side on another island where the dealer is located. The ONLY thing I was quoted on the phone was "cost". They didn't even care to hear what my problem was. The numbers, the equivalent of $2500 just to get the car over there, $1800 for "diagnostic" and a minimum service charge of another $1100 (not including any work or parts).. yeah here there is a "minimum" service charge, like in most restaurants here where you don't spend a certain amount, you are not allowed to eat or even stay sitting. Ive been here too long to know how it goes. Just to give you a pale idea of the costs here, Ive compared the price of a few internal items I may need to replace like side arm rests, windows dash electric switches and ashtray, and its about 3.5x the cost of the same parts in the US. Will cost me less than 1/2 if I buy the parts there and ship them over here. But "service" I cannot "ship". They will do it and bill me laughing out loud. This is the result of the increasing absurd cost of living here (buying a dinky 350sf. rotten 1 bedroom apartment can cost you 2 or 3 million dollars) and the fact there is ONE dealer and ZERO authorized external service centers.
    The way things are operated here has nothing to do with good old California and the Ferrari world as I remember it.
    So, being that the car has not been driven for 2 years and its a given that they will find 100 other "mandatory" things that are "wrong" with it without which the "immobilizer issue cannot be addressed", I am REALLY, REALLY interested in having the car started myself, and getting it over there by my own means for the basic necessary service, under my conditions, not theirs.
    They'll eat me for breakfast, burp me for lunch and s**t me for dinner:)...
    PS - I forgot, but the taxes are low and no need tipping..haha:):):)
  13. Col. Kurtz
    Col. Kurtz Formula Junior
    Jun 20, 2013
    276
    New England
    Walter E.
    I agree with you. Research the symptoms properly and see what you can do yourself. I knew nothing about the electronic system of my Japanese hi-performance import, but the cost made me look into it and get good enough to fix whatever issues I had or at least understand them and by-pass them if/when necessary.
    The costs quoted are ridiculous, so take in all the advise the FChat experts can supply (you'll soon find out who knows their stuff and who doesn't) and even call the San Diego F service center who - I hope - you have a good relationship with, and see what they have to say.
    The worst that can happen is you're confused and need to bite the bullet with local servicing and repairs if the fixes are too involved and beyond you. If not too arduous, you'll save yourself a ton of $$$ and get to know your beautiful car a little better.
    Just my 2cents…
    Please keep us posted.
  14. ByeFcars2
    ByeFcars2 Rookie
    Sep 24, 2010
    20
    Thanks for the feedback and kind words. Your 2 cents definitely taken in and appreciated! Super amazing the support and interest I get from all you guys and I can't thank enough for your knowledge and wisdom on Ferrari matters.. and for the time taken to try steer me in the right direction. Endless people here know vastly more about the true ins-and-outs of these cars and their particular model personalities than LOTS of Ferrari technicians that more and more do positively NOTHING but connect the cars to their computers terminals and just faithfully execute whatever the software tells them to do. Inspiration and true master technician troubleshooting, is all mostly a thing of the past. Repair shops have become obedient subjects of what the computer screen tell them to do, and religiously bill everyone mathematically for what gets done. A few more years virtually NO ONE at ANY repair shop will have any clue on how to diagnose or fix anything just as people have no idea what to do with computers when they crash except wiping and re-installing the OS, or buy a new hardware. One of my good friend's BMW here had a virus on his new car a couple weeks ago. Imagine.. now cars have viruses. Who has the anti-virus? The dealers? The mechanics? He had to replace 1/2 of the car's computers that were sent to Bavaria for further investigation. My advice to him? Enjoy the car while there is a warranty and run like hell when it's over. My dear 360 is at least virus immune. I feel privileged. Every day I love older Ferraris more (old cars in general). New cars have become as exciting and "special" to me as the thrill of a new laptop or cellphone.. that is, before it stops working or the "new" model comes out.
    Again, thanks to all in this community for the awesome help. You guys are worth more in combined knowledge and true passion for what Ferrari truly means than all dealers and mechanics combined :)
  15. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,809
    wisconsin/chicago
    bo
    Fly a mechanic in from the states for a weekend. Sounds cheaper.
  16. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Holy cow! $1800 for diagnosis? Think ill open a shop over there!!
  17. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    I hate to add to your woes, but the 360s seem to be depreciating at an increasing rate. Have you considered that it might be cheaper to ship the car to the US to work out a deal to repair & sell? (Assuming it is left hand drive.)
  18. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,026
    Sarasota, FL
    Andy
    Any update ?
  19. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    1USD ~7.5 HKD
    About $250US
    BTW, no start up yet?
  20. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    If you somehow tripped the immobilizer you'll need the SD3 to reset it.
    Can give this newly opened independent garage a call. It's run by ex-IMSS staff. No affiliation by the way, but I've known Ben for close to 20 years since my first 355.
    We are Musketeers Motorsports Services
  21. 24000rpm
    24000rpm F1 Rookie
    #46 24000rpm, Feb 22, 2015
    The service in both Hong Kong and mainland china can only be spotty.
    I was in an official dealer in mainland to diagnose a f1 problem about a 1 year ago and guess what, they performed all the procedures under the phone direction of an Irish guy in Shanghai headquarter. The man in the dealership acted like a robot and did whatever the guy on the phone told him to do. Later, all pictures taken by a second technician were downloaded and emailed to that Irish guy in Shanghai and the Irish guy starts to analyse the data.
    The dealer asked me to wait for about 30 min and printed out a piece of solution and service guideline of some sort.
