Hi Morten No it will not be ready for RaceRetro,iam still waiting on parts to finish,I will be going to RaceRetro but will use the exworks Stig Blomquist Ford RS200 ,are you going,it would be great to meet up Jim
Hi Morten You are really doing a great job on the car,good to see you are getting to the good part , biulding a great rally car Jim
Hi Jim, I planned to visit RaceRetro. Unfortunately, I can't find the time right now Concerning my project, it looks like slow progress, but nobody can imagine how much time it takes to investigate exactly how the Michelotto cars were made - as said before, my project is intended to be "no-compromises" and believe it or not, we still have to remove more than ten chassis parts, before start welding in new and different parts. When that's done, we will clean the entire chassis, and the roll cage will be fitted. Morten
Hello Morten, Please see the Fchat Technical Q&A section. There are two threads discussing rear suspension weaknesses that appear particularly in racing conditions like yours. 1) "308 Cracked rear lower control arms (A-Arms) 2) Problems with (stub) axle shaft rear wheel bearings. (shaft fatigue fail at the inner bearing interface) Both seem to have to do with inadquate design fatigue strength, and both, particularly sudden stub axle failure with most likely end in nasty accidents. Being that you are building your car for competition use, how are you going to address these issues on your car?
Thanks for the hint Marankie, I am well aware that the suspension and transmission needs to be optimized in some regards; wishbones, hubs, gearshift forks, axle shafts and more. Right now we are focusing at the body and chassis. Regards, Morten
Thanks to a fellow Fchat member, an original Michelotto pedalbox has been digged up from the past. THANKS Image Unavailable, Please Login
Yeahhh.... and when we are done with the body and chassis - the dirty cloth will be replaced by clean shirts, and we will start dealing with all the cool stuff
Here a 308 without much left - most of you, haven't seen it without roof - now we will start the cleaning and preparation for fitting the roll-cage. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Tour, Since you are mounting the pedal box think about making this a single seater with centered driver. It will be safer and better weight balance. Use nascar style bars in your cage to improve ingress and egress from that small door opening.
Hi Morten Have you tried putting a seat on the floor and trying the head room with a helmet, i had to remove allthe seat fixinrs and remove the fibre floor, and fit a alloy panel on the under side of the car, the project is looking very good Jim
Yes, I have the same issue (is 187 cm tall and quite long in upper body) so I will cut a rectangular hole in the floor, and make new seat mountings. No big deal
Apologies if you have already seen this but these guys have done a similar thing. Very nice car/pics. Found the link on Club Scuderia. http://www.mat.fi/n_index.php?nav=gallery&gallery=13
These are only lookalikes. Michelotto cars are very different, chassis, suspension, brakes, pedal boxes, gearboxes, engine, dashboard, .... are all different. It's a shame to go to lengths like these and not make a correct car. FYI here's the 308 dog engagement gearbox we made, smooth as butter: Image Unavailable, Please Login
Kari knows what he is doing, the VS car was only made for a specific event, and the Alitalia car is standard. Watch us, we aim for the superior
Hi Morten, when you told me about your project some time ago, I have to admit that I thought "What an ambitious project, let's see how far he is going to get". Now I have discovered this thread by chance, and have to say "Hats off!". This is amazing, and I am tempted to ask you to build another one at the same time for me! I will follow your progress and wish you good luck for the project! Robert (308 GTB Register)
Hi Robert, actually a little surprised that I didn't hear from you Currently we are moving a bit slower than I expected, but watch us, the project will materialize. Morten
