My Testarossa DIY thread | Page 5 | FerrariChat
Discussion in 'Boxers/TR/M' started by mikael82, May 26, 2015.
  1. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    Today I spend lot of time to open thermostat housing.
    It was tight so I took it out right away.
    That black stuff is factory rust protection.
    To unbolt I had to use gas burner and all kind of mirracle oil, Even used cordles power tool to get that little movement, warning to all; thermostat housing corrodes tight.
    After hours of try I did manage to get them seperated, toughest one is to remove housing from cooling pipe.
    Heat is what did the trick.
    It is sealed only by thermostat seal.
    Original thermostats are plastic, they can get stuck and I had feeling one side might not close correctly.
  2. mikael82
    Nov 18, 2007
    869
    Finland
    Mikael
  3. mikael82
    Nov 18, 2007
    869
    Finland
    Mikael
    Lamborghini Diablo
    Intake
    before TDC 27 decree
    After BDC 73 decree
    Exhaust
    before BDC 70 decree
    After TDC 10 decree
    Compared to Testarossa:
    Intake
    before TDC 16 decree
    After BDC 48 decree
    Exhaust
    before BDC 54 decree
    After TDC 10 decree
    turbo-joe likes this.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,921
    romano schwabel
    thank you very much mikael :)
    so the valve opening times at the lamborghini are much more than the testarossa. I wonder why the lamborghini then has a really low idle rpm and running very smooth with such long opening times?
    you know perhaps the wight from the flywheel? I´m not very familiar with countach, only had 1 customer anbd he already sold this car, but I always have been surprised how smooth the countach engine in very low idle was running, a carb version
  5. mikael82
    Nov 18, 2007
    869
    Finland
    Mikael
    Well they did not come out, exhaust valves came out with that lever -style tool, but intake side I could not make enaugh force to brake valve spring locks out.
    So I made this very simple and effective tool. Much more solid and cheaper from those purpouse made valve compression tools.
    It still needs little tap to brake contact.
    Tool got kind of spring tension when you tighten clamp, so little tap with hammer and valve lock opens. I got all kind of valve compression tools, but this is my favorite.
    Valves and springs, with rest of valve mechanism.
    TestaDDS and Jakuzzi like this.
