My TR won’t start | FerrariChat
My TR won’t start
Discussion in 'Technical Q&A' started by procure95, Dec 29, 2007.
  1. procure95
    procure95 Formula Junior
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    It is completely dead. I charged the battery and that didn’t work. Thinking I had a dead battery, I changed the battery and it is still completely without power. Any suggestions will be greatly appreciative.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #2 2NA, Dec 29, 2007
    Battery disconnect (part #41) switch turned off?
    Loose or corroded connections at battery/ground terminals?
  3. Steve Magnusson
    26,933
    Can you clarify "completely without power"?
    1. headlights do not work (with key "off") and when I turn the ignition key "on" there's no dash light activity, or
    2. headlights work (with key "off"), but when I turn the ignition key "on" there's no dash light activity, or
    3. headlights work (with key "off"), and when I turn the ignition key "on" there's is dash light activity, but it won't start, or
    4. something else?
    Certainly, as a first act, try opening/closing the battery cutoff switch a few times to "wipe" the contacts, but give a little more detail please.
  4. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    where is the battery disconnect switch? the connections to the battery are clean and tight too. thanks
  5. Steve Magnusson
    26,933
    #5 Steve Magnusson, Dec 29, 2007
  6. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    1. headlights do not work (with key "off or on") and when I turn the ignition key "on" there's no dash light activity. No activity at all.
    I didnt see that diagram before i posted my last responce 2NA. i see it on the diagram but where would you find it on the car?
  7. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Bullet connector on fram rail ? Mine did the same thing until I cut the connectors off and put lug connectors with a bolt .
  8. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    The switched did it. I never knew it had a switch. I turned it a couple of times and tried to turn it on but it didnt work. :( then i switched it the other way and the car started right up.:) THANK YOU FOR FIXING MY PROBLEM IN LESS THAN A HOUR. That alone is worth the price of admission. Have a Happy New Year!!:D
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Ready to "Rock and Roll"!!
  10. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    #10 PAP 348, Dec 29, 2007
    It's money in the Bank :p:p
  11. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    I am so happy, i can ride my car again! These guys are great!
  12. Ed_Long
    Ed_Long Formula Junior
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    I learned years ago from my friend who can fix anything that when an engine won't start to first look at the battery then gradually work your way to the solenoid and starter motor. It is important to tell the people you are seeking advice from if you can hear a clicking sound in the engine bay. That sound indicates that the solenoid is getting some juice but not enough to engage the Bendix and spin the engine. Always an important clue.
  13. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    there was no clicking sound or electrical power going anywhere in the car. It seems like after i turn the disconnect switch "on and off" it worked fine.:p
  14. simpleton7890
    simpleton7890 Karting
    Apr 10, 2006
    244
    Global
    glad it wasn't costly to fix!
  15. PAP 348
    Dec 10, 2005
    100,232
    Pap
    We don't hear that word often enough Ed ;) Nearly forgot what it was called myself :eek::eek:
  16. wetpet
    wetpet F1 World Champ
    10,210
    he didn't get tim's bill yet.
  17. Night life
    Night life F1 Veteran
    7,309
    The city that rhymes with fun in Canada
    Roberto
    Curious if you didn't know you had a switch then who turned it? dant dant dant
  18. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #18 2NA, Dec 31, 2007
  19. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    I did....:)...Steve and Tim directed me to the right spot....:D
  20. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    i owe Steve and Tim a beer and a steak dinner
  21. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    Wow i am a
