My Turbo elise is alive ... and faster than ever | FerrariChat
Discussion in 'General Automotive Discussion' started by rskdsk, Mar 16, 2013.
  1. rskdsk
    rskdsk Formula Junior
    Jun 1, 2006
    527
    #1 rskdsk, Mar 16, 2013
    My elise had a valve dump ... and need a major repair (many other issues as well). I sent it to BOE in Kansas city for some upgrades and did they ever do it right:
    Check it out: BOE Fabrication - Lotus Elise, Exige, and Evora Performance ECM Tuning Products
    This car will now fly past my 360 like it is going backwards. The best dyno run "glory run" had the car just over 335whp ... 1800lbs ... extreme!
    Here is a list of mods:
    BOE modified turbo elise with GT28R, short block, JCR head with Ferrea valves, Cosworth head gasket, IC, brake upgrade, Quaiffe Limited Slip Diff & Act Street Clutch, Cyn-r-g segmented flywheel, aluminum pro-rad, custom stainless exhaust w/ tubular turbo manifold, EFI tuned race ECU, upgraded fuel system w/ 750cc injectors, HID beams, Venture shield, carbon fibre splitter & rear custom diffuser, fuel ratio & boost gauge, clam hinge, tail BOV, K&N intake, XS boost controller, & much more.
    Once you have seen the website and pics ... you'll understand why I have removed the methane injection system ... not good with the aluminum block
  2. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,841
    SoCal
    Edward
    Very cool.
    You need to race with us in LotusCupUSA!
    335 rwhp is crazy fast. I'm curious what you did to the tranny? As you know this is the weakest link in our cars.
  3. rskdsk
    Jun 1, 2006
    527
    No ... no tranny mods. I will cross that bridge when needed, but with Quaiffe Limited Slip Diff & Act Street Clutch + Cyn-r-g segmented flywheel it should limit the impact forces on the tranny.
    I am not a dump and run guy ... and only track once in a blue moon. I am betting that I'll want to go more though now.
  4. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    A tranny is the weakest link in any car! :eek::D
    But seriously, great looking car...somewhat of a sleeper, if you will. :D
    I like the clam shell of the rear, looks awesome. Does that save any weight, or is it just easier to work on if need be?
  5. rskdsk
    Jun 1, 2006
    527
    The car is already the light weight ... no power windows ... etc... sports pac. The clam shell hinge is just for ease of repair and show.
    I do like the video link of one of the dyno runs ... the turbo just sound great
  6. rskdsk
    Jun 1, 2006
    527
    Make sure you scroll down and see the pics of the block and the dyne video
  7. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    very cool, love that it is basically stock looking on the outside, subtle and clean!!
  8. rskdsk
    Jun 1, 2006
    527
    #8 rskdsk, Mar 16, 2013
  9. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Just because it's already light weight doesn't mean you can't shed more pounds. :D
    Have you thought about doing a Supercharger/Turbo system like Ronin (Frank) did? His car was a beast, can't wait to see his car after the 2 Eleven design.
    Oh wow, those are really good numbers! To be honest, I wasn't expecting that much torque from that motor.
  10. rskdsk
    Jun 1, 2006
    527
    I was impressed by the torque numbers as well. But what is really surprising is that when the lack of a drop off in power at the switchover (6kish rpms) and then the constant rise in power until about redline. I thought the GT28R would have run out of steam before that.
