360 - My turn for the heat exchanger failure | FerrariChat
360 My turn for the heat exchanger failure
Discussion in '360/430' started by mfennell70, Mar 19, 2025.
  1. mfennell70
    mfennell70 Formula Junior
    Nov 3, 2003
    596
    Middletown, NJ
    Finally failed after 14+ years of ownership. I started getting crunches going into 3rd a week ago. It was OK with double clutching and I was wondering how much a rebuild would cost. Then the temp gauge started fluctuating quite a bit one evening. Checked coolant - low. Adding brought up some drops of oil.
    Oh, right. Best guess, I drove it about 50 easy miles after it started leaking.
    Since AW Italian is 1.2 miles from my office, I guess that's where I'll pick a new one up. My intake gaskets are original so I'm going to pull it for the replacement. Car is on the lift waiting my attention.
    My daily VW has a bunch of 60k mile maintenance needs plus needs a waterpump but I punted and dropped it at my friend's shop so I can concentrate on the Ferrari. And my Ducati track bike. And my Aprilia RS250 track bike. :) It pains me to pay for stuff for things I can do myself but there's only so much time.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,700
    Central NJ
    Dominick
    Sorry to hear ...I know what you mean about not enough time to tend to all the toys and regular stuff
    If you need a hand ..I am not far ...
    Give me a shout on pm if you want
  3. Mel Spillman
    Mel Spillman Formula Junior
    709
    Sugar Land, Tx
    This is a normal Flash 32 (Dominck) response! "If you need a hand, I'm not far" This man has helped me sooooo much in the past few weeks and I can't thank him enough. We are ALL blessed to have him on this forum!! Thank you , Dominick!!
  4. jdlegg
    jdlegg Formula Junior
    Dec 22, 2009
    252
    Bryan / San Rafael
    James D
    Feel for you. Mine failed in the driveway at home right after washing the car. It took 6 weeks to get the exchanger from Italy (slow boat? row boat?) + 13 (THIRTEEN!!!) fluid flushes to clean out the coolant system and gearbox. Best of luck w/yours!
    mfennell70 and Jaymac like this.
  5. mfennell70
    Nov 3, 2003
    596
    Middletown, NJ
    Thanks! My friend JohnA mentioned that you were a lot of help with his 430.
  6. mfennell70
    Nov 3, 2003
    596
    Middletown, NJ
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,700
    Central NJ
    Dominick
    We have a mutual friend .. small world
    John is a great guy
    mfennell70 likes this.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,700
    Central NJ
    Dominick
    What is your plan in terms of flushing it
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    Is it a spider? It's a bit of a job for a spider.
  10. mfennell70
    Nov 3, 2003
    596
    Middletown, NJ
    I have no plan yet. :) Many oil changes with cheap 75w90? On the coolant side, my fingers are crossed that it's not too bad. I haven't drained it yet.
    This is what came out of the transaxle:
    This will go slowly. I pulled the side panels and airbox this morning.
    I'll probably do the trans mount while I'm in there.
  11. mfennell70
    Nov 3, 2003
    596
    Middletown, NJ
    Fortunately, it's not! I skimmed through the service manual this morning. In sterile manual-speak, it sounds pretty straightforward.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,700
    Central NJ
    Dominick
    I haven't looked into it but I thought shops use ATF for a quick clean - not on the road just a few minutes on lift in gear
