My Winter project | FerrariChat
My Winter project
Discussion in '348/355' started by RSD, Dec 12, 2013.
  1. RSD
    RSD Karting
    57
    hi, Just got my car jacked up on stands with all wheels off.
    Plans for the winter include;,
    1. Gold connector kit.
    2. All Bushings replaced.
    3. Schumacher sway bars.
    4. New front shocks, rear rebuild.
    5. Install challenge wheels and spacers.
    6. Brembo big Brake Kit.
    Most parts bought used right here on F-Chat from Bruce.
  2. plugzit
    plugzit F1 Veteran
    7,777
    Redondo Beach, CA
    Bruce Bogart
    My compliments! Wise to do basics first.
    Subscribe so you can post pictures!
  3. Harrydino
    Harrydino Karting
    Apr 9, 2013
    206
    London
    Harry
    I keep hearing about gold connector kits. Apologies if I sound stupid but what actually are they?
  4. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Hmmm, that question has the potential to start WWIII around here, but I'll try to answer it before you get a reply from one of the more... we'll say opinionated... members here chimes in.
    Basically some 348's (and I presume 355's) have a tendency to have electrical gremlins that cause Check Engine Lights and Slow Down Lights on the dash to come on and engine performance to suffer. It is felt by some to be caused by contact problems inside the many connector plugs in the engine wiring harness. A company in CO called SRI brought out a kit where mainly the female clamping pins in the connector plugs are replaced by new ones with a tighter grip and gold plating to theoretically improve the transfer of electrons across the connection and resolve those issues. It can be done by the owner, but it takes very precise installation (check You Tube for a video series on Ferrari 348 gold kit installation).
    There is a faction who believe it's a bunch of hooey, and that putting gold plating over a tin base is sure to cause problems down the line... thus the WWIII-like hostile banter which has ensued, but we won't go there.
    So check out the video series or just Google "Ferrari gold kit" for more info. Hope that helps.
  5. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Ooops, sorry, just realized you're from the UK, CO is short hand for Colorado. Also should have stated SRI stands for Scuderia Rampante Inc.
  6. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    #6 pnicholasen, Dec 13, 2013
  7. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    Very cool! Really ugly bumper, but otherwise very cool. Don't know if that car helped Triumph to stick around a few more years, or killed them off. It was very radical compared with all their previous offerings. I love the British stuff.
    On the gold connectors, I'm undecided. I do know from redoing a lot of the wiring on my 355 (that a previous owner messed up), there is a fair bit of corrosion on many of the electrical connectors, so it certainly needs to be addressed. Nice to have a winter project like this. You get to enjoy the car over the winter, making it better, then enjoy it all summer.
    Rick
  8. RSD
    RSD Karting
    57
    How do you do that?
  9. WATSON
    23,689
    WI
    #9 WATSON, Dec 13, 2013
    Had to do a double take. A TR wedge on the 355 forum. Very cool... That a TR7 or TR8?
    Hey, the bumper is fine if you have the proper camera angle... :)
  10. WATSON
    23,689
    WI
    Upper right hand side of the screen. Click "Paid Subscriptions" and select Silver or Rossa.
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,227
    CT
    John Kreskovsky
    Well, not to get into the same old argument again but there is one thing for sure. Your car is 13 -15 years old. If it suffers corrosion of the contacts it needs to be addressed. But the underlying fact is that even if you replace all the female terminals with gold, the tin male counter parts are still tin and all the gold in the world isn't going to stop the tin male pins from corroding in the future. Whether gold mated with tin accelerates the corrosion of the tin or not becomes moot. The tin will do what tin does, regardless.
  12. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    It's a lowly TR7. Been watching too much "Wheeler Dealers"... decided to try it myself since I ran out of projects to do on my poor Ferrari.
  13. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    I have Triumph his and hers motorcycles. When I was a little boy my cousin had a brand new TR7 and used to take me for rides in it often. Fantastic car when it was running good :)
    Good summary on the GCK.
  14. GarageWarrior
    GarageWarrior Karting
    Aug 15, 2013
    93
    Westerly, RI
    I thought the problem with Ferrari connectors was purely mechanical - e.g. clamping/fit on female contacts getting loose? I observed that first hand in another application while charging LiPo batteries. Timaya and Molex connectors would start to become unreliable (intermittent loss of contact) after several connects/disconnects. Pin and sleeve connectors are the worse. I think Ferrari uses AMP superseal? I had to reconnect one loose connector and that's what it looked liked to me. If so, they are not as bad as Timaya and Molex.
    For oxidation - there is deoxit contact cleaner that I heard good things about, I know previous owner's mechanic used it on my car a few years back before putting SRI kit. Also on exposed connectors silicone grease would help to seal out any air/moisture that causes oxidation. I've used silicone grease on connectors for remotely-controlled subs and it seemed to work pretty good and unlike petrolum jelly, did not cause rubber to swell.
  15. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Why the bigger brakes? Looks?
    Kai
  16. RSD
    RSD Karting
    57
    Just got the car earlier in the fall. Always loved this model. Though there is faster stuff, this car is still relevant and can run with the new Hi-Po cars with un matched looks. I think it is rare in this regard.
    At the moment, this car has Challenge Grills/ Tubi/Hyperflows/aftermarket headers/GruppeM intakes and the ECU has been mapped for this set-up.
    Car is fast and stock looking. Which with the exception of the Challenge wheels I picked up (which are at least period correct) it will remain.
    I intend to have the challenge wheels painted the stock silver.
    To answer the question, during a spirited drive on a back road for an extended period, I noticed serious brake fade and also the wooden feeling as though they were overheated.
    I am not a professional race driver nor do I want to be so my technique will be buffered by this upgrade. Also, they give the car an updated look and are big time bling. ESPECIALLY with the Yellow Calipers which are kind of the latest look. Now that I have the car off the ground and the wheels off, the stock set-up even looks very under spec'd for such a powerful car.
    Will post pics once I sign up. What's the difference between Silver and Rossa? What do you recommend?
    I have a front set of Stop Tech big brake for sale and would like to advertise them here.
  17. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    I've never had fade on the street, but they faded pretty badly on the track. I'm thinking a pad change to a track oriented pad should fix that, though.
    Rossa gives access to the Rossa forum, larger avatar and allows for more ads and a few other minor things.
  18. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #18 drbob101, Dec 16, 2013
    Well if you don't sell it Paul we may have to have a Triumph meet somewhere :)
    Love the color to BTW
  19. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    It's super tossable and fun to drive, but certainly doesn't have the collectability of your beautiful TR6. You can't beat those Michelotti lines, plus you get a few more horsepower.
    The color is called Carmine Red... one of 3 different reds Triumph offered at the time.
    I guess this should be on Triumphchat....
  20. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Yes mine is Carmine Red. Great fun to drive, easy to work on and lots of parts available.
  21. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    #21 bcwawright, Jan 12, 2014
    Time to get this thread back on topic...lol
    Jeff Has installed the rear Brembo BBK....he is working on the fronts which will be a hybrid, He can share all the goodies when he gets everything back from the machine shop....how do you say "really big" in pig Latin?????
    Maybe we can encourage him to put some TLC on that black paint...haha
  22. RSD
    RSD Karting
    57
    It just got warm enough to install the rear Brembo Big brake Kit That I bought from Bruce earlier this year (great transaction and great guy)
    Bruce will be posting the pics so far of the progress since I cant get them to load.
  23. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Good morning :) Nice to see some progress here. Bruce is a terrific guy! I also recently purchased a few of his tasty 355 spares.
  24. RSD
    RSD Karting
    57
    Initially, I had planned to install this kit completely but the Rotors from my StopTech Front Kit are MASSIVE so I thought I would Drill them the same way as these rear Discs. I'm waiting to get them back from the machine shop.
    In the picture, the snow up here is melting and the car is covered in condensation. Not to worry, this car is loved and cared for.
  25. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Jeff, what part of the country are you in? I'm from Ottawa, Canada and the Snow is also melting here but it won't melt enough to take a Ferrari out for a drive. Probably another 2 or 2.5 months before that will happen.
