Mysterious engine sound 308 GTB | FerrariChat
Discussion in '308/328' started by Andreas Engesvik, Aug 11, 2025 at 5:23 PM.
  1. Andreas Engesvik
    Mar 4, 2020
    150
    Oslo, Norway
    Andreas Engesvik
    The sound occurs only when cold starting - and then It disappears after a few minutes. The engine runs fine - euro dry sump 77. Thanks
  2. DanielGA
    DanielGA Karting
    Mar 19, 2018
    159
    Midwest
    Daniel A.
    Well audios in videos are not ideal for this but.....
    1. sounds like a loose screw....but that going away would not be expected.
    2. could be a crack/hole that upon warm-up seals...I had a maybe similar noise because one for the airpump plugs in exhaust header got lose...easy fix.
    3. you are pointing at the water pump...is that where it is coming from? if you put your hand on it, does it vibrate?
    Andreas Engesvik likes this.
  3. Andreas Engesvik
    Mar 4, 2020
    150
    Oslo, Norway
    Andreas Engesvik
    Thanks - sound both like a loose screw - small stone caught somewhere - and almost like static electricity. I have driven the car approx 500 km since this sound first appeared last week.
    No vibrations from the water pump either. The sound is difficult to locate. I will check the air pump plugs.
  4. Dockboy
    Dockboy Formula Junior
    614
    Maryland
