Mystery air hose? by battery in 360? Can someone help identify? | FerrariChat
Discussion in '360/430' started by CyclingPeaks, Sep 1, 2009.
  1. CyclingPeaks
    CyclingPeaks Formula Junior
    Jun 11, 2006
    361
    Big Island, Virginia
    Hunter Allen
    #1 CyclingPeaks, Sep 1, 2009
    Hi- My battery was dead when I went to drive my beauty yesterday, so got out the trickle charger and recharged the battery.
    In doing this, I noticed this black air hose(?) with an "L" shaped connector on the end. The hose goes back into the firewall and for the life of me I cannot locate where this should connect to under the dash. I have looked everywhere.
    Does anyone know what this is and a general location that it connects to I can find that and re-connect it?
    Hunter
  2. M39976
    M39976 Rookie
    Aug 20, 2004
    43
    Grand Haven
    That is the overflow drain hose for the battery. It should plug into the battery and drain downwards.
  3. CyclingPeaks
    Jun 11, 2006
    361
    Hunter Allen
    Many thanks!
    Hunter
  4. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Overflow? I thought it is used to vent hydrogen.
  5. nerd
    nerd F1 Rookie
    Oct 12, 2003
    2,535
    Coronado, CA
    RSK
    Hydrogen is not easily contained by battery cases or plastic tubing....it readily escapes through most seals. While I suppose there may be some intent to vent Hydrogen with that line, it is really for the rare event of an overcharged, overfilled or agitated battery venting fluid. Here is a typical patent for such a design: http://www.google.com/patents?id=spcUAAAAEBAJ&zoom=4&pg=PA1#v=onepage&q=&f=false
  6. Rifledriver
    36,821
    They are required on batteries placed in the interior to vent hydrogen. Those batteries have more than enough interior space for fluid expansion.
  7. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    The MTP-91 Interstate battery comes with vent tubes that connect to the OEM vent.
    Quite important to have connected.
  8. M39976
    M39976 Rookie
    Aug 20, 2004
    43
    Grand Haven
    He just wanted to know where the hose goes not the anatomy of a battery.
  9. Rifledriver
    36,821
    And you informed him. But you did not stop there without misinforming him its reason for being so we really have you to thank.
  10. Bob’s 360
    Bob’s 360 Rookie
    Mar 30, 2018
    22
    Cocoa, FL
    Bob DeCardenas
    Where does the hose vent through, when i pulled the battery out unfortunately the hose came with the battery
  11. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,589
    San Jose
    dc
    Most likely through a hole to the ground. I thought it was for fluid as I've seen battery trays in other cars rusted when the tube is not connected. Hydrogen should just float away.
  12. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,932
    Melbourne Florida
    KGC
    Am I wrong... but do these "sealed" batteries even need that? Is there even a vent port on the battery for it ?
  13. GogglesPisano
    GogglesPisano F1 Rookie
    3,056
    East Bay, California
    Joe
    According to the interwebs, even sealed lead acid batteries could encounter circumstances which cause out gassing.
    Rifledriver likes this.
