Mystery switches | FerrariChat
Mystery switches
Discussion in '308/328' started by drapp54, Jul 15, 2013.
  1. drapp54
    drapp54 Rookie
    May 4, 2004
    26
    My US spec 1986 328 GTS has two mini rocker switches in the back of the cavity on the leftmost side of the dashboard. The manual doesn't show the switches and I can't tell what they're supposed to do. Has anyone solved this mystery? Thanks.
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
    Post a picture so folk can see if they are standard or not
  3. ferrariman1492
    ferrariman1492 Formula Junior
    Jul 2, 2012
    311
    Scottsdale, AZ
    Eric
    My 83 308 QV has the same thing in the same place....they operate the fog/driving lights that were installed by dealer at time of delivery.
  4. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    My 308 also has 2 mystery switches, figured out one is an ignition cut installed by the dealer, other I still haven't bothered to track down. You never know what people have put in. See if they do anything obvious like kill the engine or turn lights on/off, check with headlights both on and off. If not, all you could do is trace the wires, which can be a royal pain, and why after a year one of my switches remains a mystery.
  5. rickasc
    rickasc Karting
    Sep 4, 2012
    125
    Connecticut
    Rick
    If its not to much trouble could you post a pic of where those switches are.I also have an 83 qv. Mine has fog lights which I have never been able to figure out how to turn them on. Maybe I have those switches.
  6. ferrariman1492
    Jul 2, 2012
    311
    Scottsdale, AZ
    Eric
    I can take a photo tonight....but the switches are hidden in the back of the "cavity" on the dashboard on the left size of the steering wheel that I would call "a place to put loose change." Let me know if that doesn't make sense and I can take a photo.
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #7 Crowndog, Jul 15, 2013
    There is a modification to turn on the running lights that requires two momentary contact switches. On and off that may been added by the PO. With ignition on press one then the other you should hear a click that is a relay activated by the on button then check your running lights. One switch is make contact the other is a break contact. The location described is a very common one for this modification. At least that is where mine resides.
  8. rickasc
    rickasc Karting
    Sep 4, 2012
    125
    Connecticut
    Rick
    I will check when I go home. I never looked for any switches just assumed they should work off one of the stalks on the column, which they do not. That would be great if there are switches.
  9. rickasc
    rickasc Karting
    Sep 4, 2012
    125
    Connecticut
    Rick
    I dont see any switches in the little compartment on my car.
  10. Sean308
    Sean308 Formula Junior
    Jan 12, 2011
    287
    Victoria, Australia
    Sean
    Looking forward to seeing a photo.
  11. 360gtracer
    360gtracer Formula 3
    May 18, 2004
    1,022
    Are you sure those "fog lights" aren't "flash to pass" lights? My '77 308 had what looked like "fog lights", but were the FTP lights. Pulling back on one of the left-hand stalks activated them momentarily.
    Just a thought....
    gp
  12. rickasc
    rickasc Karting
    Sep 4, 2012
    125
    Connecticut
    Rick
    Thanks for the input. I have tried that but stalks do nothing for my fog lights. I guess at some point in time I will figure it out. Fortunately they are not that important.
  13. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    drapp54 any news?
  14. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    I would guess that one of them is a switch to manually turn on the radiator cooling fans. Many of us have them installed in that location, and they are not factory, but rather something either a dealer or previous owner installed in the event that the thermoswitch fails.
  15. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,222
    Gold Coast, Aust.
    Patrick
    Manual cooling fans overrride is a popular mod - can't see that for two switches, though. Paul's parking light mod requires two switches - are they momentary on/off?
    Incidentally, there must be about 10 different ways the fog lamps were wired up by the factory; my manual says it's flash to pass, but they only come on when I flash from low beam - they come on continually with high beam
  16. Wolfgang5150
    Wolfgang5150 F1 Rookie
    Oct 31, 2003
    4,706
    My 83 does not have those switches; just an early 80's radar detector in there.
    Would like to see a photo though...
    Kevin
  17. drapp54
    drapp54 Rookie
    May 4, 2004
    26
    #17 drapp54, Jul 17, 2013
  18. Wolfgang5150
    Oct 31, 2003
    4,706
    Wild! Mine doesn't have those...
  19. Tokyo Drftr
    Tokyo Drftr Formula 3
    Jan 18, 2009
    2,461
    UA-USA-JP
    Ро&#1081
    Here's my mystery switches)))
  20. ferrariman1492
    Jul 2, 2012
    311
    Scottsdale, AZ
    Eric
    #20 ferrariman1492, Jul 21, 2013
  21. Sean308
    Jan 12, 2011
    287
    Victoria, Australia
    Sean
    I have an 83 model GTS QV, euro. No switches at all in this area. My lights only operate after pulling the indicator stalk forward, so are a flash to pass setup.
