Name those brakes | FerrariChat
Name those brakes
Discussion in '360/430' started by davidevo1, Jun 24, 2014.
  1. davidevo1
    davidevo1 Rookie
    Mar 9, 2009
    20
    #1 davidevo1, Jun 24, 2014
    Am thinking about 360 brake upgrades, I seem to have read a lot that to upgrade the discs/rotors on a 360 then you need to get 19inch alloys. But these seem to be 18 inch with some tasty looking discs too.
    Any ideas on what they are, and if they're any good?
    David
  2. davidevo1
    davidevo1 Rookie
    Mar 9, 2009
    20
    #2 davidevo1, Jun 24, 2014
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,527
    Charleston, SC
    Curt
  4. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Don't think so... Stoptech slotted rotors are more traditional. I've been told that on other cars certain 18's will allow the stoptech st60 caliper.
  5. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    ...I think those look like the stock size brembo 2 piece racing rotors?
  6. davidevo1
    davidevo1 Rookie
    Mar 9, 2009
    20
    #7 davidevo1, Jun 24, 2014
  7. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Those look like 19" Strad wheels with CCM brakes (converted to steel rotors).
  8. davidevo1
    davidevo1 Rookie
    Mar 9, 2009
    20
    pretty sure they're 18s... the 19s have that little diamond cut between the spokes, no?
  9. tazandjan
    39,164
    355 mm rotors and larger calipers fit under the 18" wheels fine. Several makers out there that offer slotted, drilled, or a combination. 380 mm rotors fit fine under 19" wheels, like the OEM CCMs up front. Larger rotors may or may not fit. Scud wheels are designed to accept 398 mm rotors and those rotors and calipers are a press fit under 19" CS/F430 wheels.
  10. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Look like 19's to me...
  11. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,025
    Sarasota, FL
    Andy
    Those look exactly like my 19" CS wheels.
  12. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    i dont think they are the 19" cs wheels, which all areas between the spokes are the same length toward the center. Those look more like the bbs ch wheel or challenge wheel with the spokes at different lengths.
  13. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    #14 cm2, Jun 24, 2014
  14. X-TNSIV
    X-TNSIV Formula Junior
    May 2, 2007
    347
    Irvine, CA
    Allen
    #15 X-TNSIV, Jun 24, 2014
    davidevo1 is correct. These are the 18" BBS Challenge race wheels... I have a set as well.
    If you compare them to Nathan's (CM2) CS wheels, they are different. The easiest way to tell is the shape or cut between the spokes, towards the center of the wheel...
  15. up4speed
    up4speed F1 Rookie
    3,693
    Long Island, NY
    Chris
    They look just like the 430 challenge wheels to me
  16. tazandjan
    39,164
    Allen- Now that you mention it, there are some pretty significant differences in the two types I never noticed before. Thanks for the tutorial. Already had all the sizes and offsets, but that makes vis ID easier. Usually, I just look for the decals.
