In quotes from the supplier: "Your Ferrari should have a 6 hole hub adapter from factory with a 70mm bolt pattern" Will the wheel bolt right up to my Mondi? "60mm horn button opening" Can I use my Ferrari OEM horn button? Love the look of a wood Nardi wheel on our cars, black or bright spokes? I am thinking black. Opinions? Alden
From what I understand, the bolt pattern is different. I bought a Mr. Luisi steering wheel. It came with an entirely new hub. Just for grins, I tried to install the new wheel on the existing MOMO hub. Not even close. So, I think you will need a new hub. Or possibly, you might find someone making a ring adapter. I found one for the Mr. Luisi wheel (and ordered it), but they were out of stock and I haven't received it yet. sid
This is the one I was looking at with black spokes:http://www.crowderscustomizing.com/Nardi-5051-39-2300-Classic-Wheel-Wood-Black-390-p/nardi_5051.39.2300.htm Or maybe a Momo wheel will bolt up? Like this one:http://www.crowderscustomizing.com/MOMO-IND35ZB0P-Indy-Steering-Wheel-Mahogany-Wood-p/momo_ind35zb0p.htm Nardi makes adapters for about $30 or less, so no big deal. Is there a way to measure to be sure before I buy one? Alden
I think Mike (soucorp) has one in his car. http://www.ferrarichat.com/forum/album.php?albumid=1005&pictureid=7197
Nardi and Momo bolt patterns are slightly different, but enough so that they can't bolt up to the others's hubs. Both are 6 bolts, but Momo has the bolts around the 70mm / 2.75" bolt circle at 0/360*, 60*, 120*, 180*, 240*, 300*; Nardi has the bolts around the 74mm / 2.875" bolt circle at 30*, 90*, 150*, 210*, 270*, and 330* (ie offset 30 degrees between the patterns) You can use a half inch thick spacer/adapter to convert between the bolt patterns, like this one sold by Crowders: NRG Steering Wheel Spacer Adapter Kit - Nardi to MOMO and MOMO to Nardi - Black . You bolt it on to your steering column hub using the stock Momo bolt pattern, then bolt on the Nardi wheel to this adapter using the Nardi bolt pattern.
Hi Alden, You will need to get a Nardi to Momo hub adapter. Just make sure the hub comes with screws because they are a different size as well. I bought mine off ebay years ago, ~$100. see this post, best. http://www.ferrarichat.com/forum/140931982-post1.html
